Old 06-11-2020, 03:46 AM   #211
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
Originally Posted by radroach View Post
How many miles on the old plugs?
Aren't the brown marks up the middle of the plug from the coil packs grounding and burning it? Thinking you might need new coils soon.
175,000km... they needed a change. the coil pack looked to be in fine shape honestly, wish i snapped a pic. even when i was measuring them for depth they looked really good on the inside.
i think the discoloration you are referring to is corona stain.. but maybe someone more educated on the matter can chime in
RickyRacer is offline   Reply With Quote
Old 06-12-2020, 08:32 AM   #212
Halo_2
Drives: 2014 MY15 86 GTS
Originally Posted by 86TOYO2k17 View Post
Spend the extra 20mins jacking the engine up to save you several hours and dozens of scratches next time. Not necessary but 10times easier.
It defiantly looks way easier on the video
Halo_2 is offline   Reply With Quote
Old 06-12-2020, 09:00 AM   #213
So, what is everyone's objection to jacking the engine to do this anyway? Is it mostly just not having the equipment?
Seriously curious. I personally wouldn't attempt it without doing it that way, just seems simplest and less knuckle damaging approach.
Dadhawk is online now   Reply With Quote
Old 06-12-2020, 11:17 AM   #214
86TOYO2k17
Drives: 2017 toyota 86
Probably have never jacked the engine up, so they think it is way harder then it actually is.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
Dadhawk (06-12-2020)
Old 06-12-2020, 11:44 AM   #215
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Childhood fear of worms, don't want to have to lay on the ground
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Dadhawk (06-12-2020), venturaII (06-12-2020)
Old 06-12-2020, 03:02 PM   #216
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Wow...big difference between that and mine at 65k miles... How would you describe your driving style?
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 06-12-2020, 07:23 PM   #217
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
for the first 165,000 km, i would categorize it as crawling on the 401 at 5km/h 5 days a week :P
The Following User Says Thank You to RickyRacer For This Useful Post:
Old 06-12-2020, 09:50 PM   #218
soundman98
ProCrastinationConsultant
soundman98's Avatar
i was gonna say, those black looks like low rpm, rich condition. white-ish looks like it's running a little hot, but mostly normal.
i've been practicing for owning an L24 240z with webbers...
LimitedSlip (06-13-2020)
Old 06-13-2020, 04:04 PM   #219
venturaII
venturaII's Avatar
i
Webers are a lot of fun, as long as you don't mind fiddling with them on a weekly basis. Very sensitive to weather and engine health, but when they're dialled in, they're great. Just takes a few minutes as long as you stay on top of them. I've had DCOEs, DCNFs, and IDFs in probably half a dozen vehicles...
The Following User Says Thank You to venturaII For This Useful Post:
soundman98 (06-13-2020)
Old 07-18-2020, 11:27 PM   #220
86TOYO2k17
Just changed my plugs.
It’s a sub 2hour job going slow and steady
IF you jack engine up.
Prep the engine bay, remove strut braces, removing ecu, fuel rail covers, and i moved/ziptied every wire/hose out the way. Only thing extra you need to do in engine bay to jack engine is undo intake pipe.
Then put front on stands. Remove skid plate, and the 1 bolt on each engine mount. undo the one bolt on front pipe hanger to allow exhaust to move more freely. Then i used a 12” 2x2” on the exposed engine mount bolt on engine side to jack that side up one at a time. Be careful and go slow when jacking up to make sure nothing gets snagged up. Was about 20 extra mins to jack engine up and then took 10mins per side to change plugs and coils with ease.
Zero scratch job. Plenty of space for a torque wrench this way too.
The Following 4 Users Say Thank You to 86TOYO2k17 For This Useful Post:
bcj (07-19-2020), Ghost of Akina (07-19-2020), humfrz (07-19-2020), Wally86 (07-20-2020)
Old 07-29-2020, 08:47 PM   #221
Halo_2
Do you need to undo the shifter or linkages when jacking up the engine (auto)
The intake pipe you speak of is that the over pipe?
Old 07-29-2020, 08:54 PM   #222
86TOYO2k17
Didn’t touch shifter link (also auto). I undid frontpipe hanger bolt (not sure if necessary but easy and better safe than sorry). Intake pipe to throttle body (again not sure if necessary but easy and better safe than sorry.)
Old 07-29-2020, 10:31 PM   #223
Halo_2
Have you got a pic of the front pipe hanger bolt.
I get what you mean with the intake pipe now.
Old 07-29-2020, 10:52 PM   #224
86TOYO2k17
The Following 2 Users Say Thank You to 86TOYO2k17 For This Useful Post:
bcj (07-30-2020), Halo_2 (07-30-2020)
Spark plugs for turbo whitefrs Forced Induction 88 05-05-2018 10:18 PM
boosted spark plugs? 350matt Forced Induction 9 08-09-2014 04:54 PM
Spark plugs Triumphrider Engine, Exhaust, Transmission 12 06-19-2014 11:47 AM
spark plugs subaruferrucci Engine, Exhaust, Transmission 22 04-10-2013 12:24 PM
