Old 06-07-2020, 01:28 PM   #1
Sur_vey17
Drives: -
Question GT86 Manual Shifter Knob Construction
Hi All,
New here.
Hoping someone knows the answer about the construction of the stock gear shifter knob.
I want to get the stock one re-wrapped in new leather, and the plastic silver disk around the gear indicator face, and the base of the gear shifter, i wamt to make some replacement aluminium replacements.
So 2 questions:
  • How is the gear face and plastic disk mounted to the gear knob itself? Just glued or riveted in or?
  • Is the plastic disc (originally silver) around the gear indicator face removable from the indicator face?
Thanks guys!
Sur_vey17 is offline   Reply With Quote
Old 06-07-2020, 01:30 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
sure seems like a lot of work:
https://www.ebay.com/itm/Manual-Shif...wAAOSwLyVZ27Z5
JD001 (06-07-2020)
Old 06-07-2020, 01:34 PM   #3
Sur_vey17
Drives: -
It is but it's a project.
I've looked at at aftermarket, the one linked has the TRD tag punched into it which i dont psrsonally want.
Old 06-07-2020, 01:43 PM   #4
norcalpb
norcalpb's Avatar
It’s all glued together.
Old 06-07-2020, 01:45 PM   #5
Sur_vey17
Drives: -
Interesting... thanks for that.
Do you know if the disk around the gear face is a separate piece?
Old 06-07-2020, 01:59 PM   #6
norcalpb
norcalpb's Avatar
Yes, the bottom ring and top disk can be pried off. I had Sweidit do my shift knob, he’d probably have a better idea of what was involved.
sweidit86@gmail.com
Old 06-07-2020, 02:13 PM   #7
Sur_vey17
Drives: -
sweidit86@gmail.com
Many thanks!
Made contact.
Old 06-07-2020, 06:07 PM   #8
norcalpb
norcalpb's Avatar
Many thanks!
Made contact.
Just reread your post and I don’t believe the upper silver ring is removable from the plauque with the gear numbers on it. You may have to buy a gear indicator plaque that’s the same size as OEM to cleanly remove the upper silver ring.
Old 06-10-2020, 11:21 AM   #9
Sur_vey17
Drives: -
just in case you were mildly interested. Gear number plaque is removable from teh silver disk around it:
Back side of Gear indicator disk + Silver Ring:
So the Silver ring is actually just a round holder with the gear indicator plate nestled in it.
The gear indicator disk is just taped / glued in place. So it is removable.
The Following 2 Users Say Thank You to Sur_vey17 For This Useful Post:
norcalpb (06-10-2020), Thefalls (06-12-2020)
Old 06-10-2020, 01:58 PM   #10
norcalpb
norcalpb's Avatar
Good stuff!
Old 07-13-2020, 11:37 AM   #11
Sur_vey17
Drives: -
So just an update on this project so far.
Got the shifter re-wraped in calve leather, with red stitching to match, the stock one results below:
Got a skilled leather craftsman to re-wrap it in calves leather, he did a great job:
Then got another guy who makes metal parts for a living:
Then he put the pieces together:
Now i just need to get it shipped back to me, and ill take a few more glamour shots. Think it came out well!
The Following 9 Users Say Thank You to Sur_vey17 For This Useful Post:
bcj (07-13-2020), Compelica (07-14-2020), daskaman (07-13-2020), Irace86.2.0 (07-20-2020), JD001 (07-19-2020), Jdmjunkie (07-13-2020), JonAvalon (07-29-2020), norcalpb (07-20-2020), soundman98 (07-14-2020)
Old 07-19-2020, 03:42 PM   #12
Sur_vey17
Drives: -
Couple more updates to come. Had the bottom piece made too!
Above is the bottom cap being formed from the Aluminium.
Below is it finished ready for fitting:
I will be getting the bottom cap anodized so it can match the existing faux metal bits in the car already but I will leave the top cap in its raw finished state as per the above post.
Then Ill install it for the final shots.
The Following 3 Users Say Thank You to Sur_vey17 For This Useful Post:
Irace86.2.0 (07-20-2020), JonAvalon (07-29-2020), Pedro13 (07-24-2020)
Old 07-19-2020, 05:14 PM   #13
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
That looks fantastic!
Any chance your guy is willing to make more sets of those aluminum parts? I’d totally pay for a set!
Old 07-20-2020, 05:11 AM   #14
Sur_vey17
Drives: -
Without a doubt he would be. I've absorbed the cost of paying for the 3d design already so now it would just be a case of plugging the design in and clicking start. Im not based in the states but if that's not a deterrent then you can DM me and we can discuss.
daviddgaf21 (07-21-2020), radroach (07-24-2020)
custom, gear, knob, replacement, shifter
Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? soulstice Cosmetic Modification (Interior/Exterior/Lighting) 52 01-24-2016 08:20 PM
Manual shifter rattle? Frs32907 Issues | Warranty | Recalls / TSB 15 05-11-2015 12:25 AM
Manual Shifter Boot rpope1127 Interior Parts (Incl. Lighting) 2 07-22-2014 12:44 PM
WTB: OEM Manual Shift/Shifter Boot FRS_Jack Want-To-Buy Requests 7 03-10-2014 01:10 PM
