Old 05-27-2020, 01:13 PM   #1
randomthoughts
Drives: 2014 White BRZ
Transmission Input Shaft
Anyone know how much movement to expect on the manual transmission input shaft? I am working on my hydraulic bearing and noticed the shaft has a bit of play and dont remember it being like that before. I don't find the transmission service manual to be very clear.
randomthoughts is offline   Reply With Quote
Old 05-27-2020, 07:15 PM   #2
vladniko86
vladniko86's Avatar
Drives: FRS
Got a video?
vladniko86 is offline   Reply With Quote
Old 05-28-2020, 01:42 AM   #3
There's some play until it's mounted to the engine. The pilot bearing supports the input shaft, maintaining coaxial alignment with the output.
Old 05-28-2020, 09:45 AM   #4
MattWll
Drives: BMW M5 e90
Do you have more information?
MattWll is offline   Reply With Quote
Old 05-28-2020, 07:25 PM   #5
randomthoughts
Sorry for the delay. I have been tied up the last couple days
Not sure how to embed a video so here's a link.
It seems worse in the video after I watched it. lol
There are no signs of leaks from the seal or any other abnormal noises or symptoms. The transmission service manual only has radial clearance checks for the input shaft to the output shaft.
The input shaft bearing check is with the shaft removed and only specifies that there is no abnormal feel in the movement, binds, abnormal noise or loose fit. This really can't be checked unless the shaft is in hand holding the bearing with the shaft.
As Ultramaroon indicated once installed it is supported by the pilot bearing.
Seeing how I had no other symptoms at this point I think I will install it and monitor.
Old 05-29-2020, 01:45 AM   #6
It's fine.
humfrz (05-29-2020), solidsnake11 (05-29-2020)
Old 05-29-2020, 07:16 AM   #7
solidsnake11
Drives: brz
It's fine.
solidsnake11 is offline   Reply With Quote
The Following User Says Thank You to solidsnake11 For This Useful Post:
Ultramaroon (05-29-2020)
Old 05-29-2020, 09:51 AM   #8
randomthoughts
It's fine.
Famous last words lol. But yeah I think so too.
Thank you.
Old 05-29-2020, 06:41 PM   #9
solidsnake11
Drives: brz
Thank you.
The input shaft is held by the input bearing and a small ~ 14mm needle bearing. It floats around until it goes in the clutch and pilot bearing.
Old 05-29-2020, 06:53 PM   #10
Bubba says, no problem, as long as the oil doesn't puddle up.
Old 05-29-2020, 08:31 PM   #11
randomthoughts
That's good to know. Thanks
Old 05-29-2020, 09:04 PM   #12
jk it's fucked
Old 05-29-2020, 11:07 PM   #13
randomthoughts
jk it's fucked
Lol guess I'll find out.
Transmission Synchro/Output Shaft Noise After a Concerning Sound Rybot Engine, Exhaust, Transmission 7 07-01-2022 12:06 PM
Should I let dealer change propeller shaft/transmission. ItsReiko Issues | Warranty | Recalls / TSB 7 01-16-2020 09:16 PM
Steering rack input shaft - oily / leak? 1Cor10:23 Issues | Warranty | Recalls / TSB 2 09-21-2015 05:17 PM
Possible Transmission Problem...Input Please wawawoowee Issues | Warranty | Recalls / TSB 11 05-24-2015 02:11 PM
Transmission selector shaft removal Nigelr32 DIY (Do-It-Yourself) Guides 0 12-29-2014 05:34 AM
