#113 |
Drives: Scion FRS
#114 | |
aeiou
Drives: WRB BRZ
Has anyone road raced with this oil pan? Or compared oil temps before and after?
#115 |
Drives: WR Blue BRZ
any ideas if this would clear an jdl twin scroll manifold?
#116 |
Drives: Scion FRS
| The Following User Says Thank You to FullBlown For This Useful Post: | fareastbrz (08-22-2014) |
#117 |
Go Gators!
Drives: FRS White-out "blown up"
Did I miss the group buy on this?
FA20 Turbo + HRI Tune + FA20 Flex fuel + FA20club intake + SRT headerback exhaust + FA20 headers + KW3's + Hotchkis front and rear sway bars + Cusco strut tower bar + Perrin oil cooler + Perrin pulley & brake stop thingy + GFB water & alternator pulleys + Crawford air/oil separator |
#118 |
Drives: 2013 FR-S Whiteout MT
So I'm assuming the drain plug is the same as oem, however I did use a fumoto drain plug in my oem pan. Since the fbm pan is larger, has anyone used the fumoto plug with this pan and does it fit with the undertray on?
When in doubt, throttle out!
#119 |
Senior Addict
Drives: 86 GT
@FullBlown is the oil level within the pan above the oil return hole? I'm thinking of fitting the pan first with a plug in oil return hole, then later on swap plug with AN fitting. Just need to know if oil is going to gush out from that top hole lol
#120 |
Drives: Fr-s
This pan specs are not accurate and its instructions MUST help customers to avoid ov
The only reliable measuring level of oil for this pan is the drain hole. If you leave it to the OEM dipstick to gauge the level IT WILL OVER FILL. The turbo drain will impeed the oil returning from turbo making it seem that the crank case is over pressurized and therefore the turbo will begin to spit oil. On top of all this to find safe oil level compliance without proper instructions nor ensuring the true explanation and meaning of this 50% more capacity, is impossible to have a safe engine like that. And it is full blown responsibility 2 makeup for any damages. Moreover, the OEM dipstick is garbage with the installation of this pan. But the good news about the oil pan is that it cools the oil quicker but bear in mind that you have to ensure that the Turbo oil drain hole is above oil level. So if you try to measure the oil level through the dipstick youll get a very low reading but this is the full mark now. Such as about a half of a centimeter from the tip of the OEM dipstick is now the new full, with drain hole above oil level. Lastly, you may say that this is crazy, well when you change the oil next time find a tube extender and attach it to the turbo drain hose and blow air through it and if it bubbles, you need to take oil out. Hope this helps. Last edited by Tormenta; 04-14-2018 at 02:29 AM. |
#121 |
Drives: 2013 - Scion FRS
Can confirm, the oil level (when full with the FBM pan) does not even register on the OEM dipstick. I called MAPerformance to see if they had an alternative solution for monitoring the oil level and they came up with cutting down the factory dipstick tube by like an inch or so.
I haven't tried this yet and I'm not even sure if you can cut it down enough for that to work but figured I would chime in just in case anyone was wondering. |
#122 | |
Drives: 2017 Subaru BRZ
A little while back I asked full blown how much oil to put in and they replied "Our oil pan holds 50% more than the OEM pan. So that is about 1 quart". If oem capacity is 5.5 qts then it should now be 6.5 qts. I also have fbm's oil cooler, which I'm assuming holds an additional quart, but that oil wont drain during an oil change so I'll disregard it. |
#123 | |
Drives: Scion FRS Firestorm
@FullBlown any thoughts on this? My FBM pan is in the mail and just purchased the fitting and hoses for my FBM turbo kit. Want to make sure I'm not going to have any issues with my dipstick, or if I will, want to be prepared with an alternative method of checking oil level.
#124 | |
Drives: 2017 toyota 86
I see no reason a larger oil pan would change anything in relation to the dip stick. |
| The Following 2 Users Say Thank You to 86TOYO2k17 For This Useful Post: | blackfireball5 (05-23-2020), Joveen (05-23-2020) |
#125 | |
| The Following User Says Thank You to MotoX16 For This Useful Post: | 86TOYO2k17 (05-26-2020) |
#126 |
Drives: 2016 Series.HyperBlue BRZ
For the love of everything holy please do not cut your dipstick tube! You're trying to bring oil level up to the dipstick, not lower the dipstick to the oil level! If you don't see it on your dipstick, you don't have enough oil and need to add more. @blackfireball5
| FRS Die-cast model | encity5 | Scion FR-S / Toyota 86 GT86 General Forum | 75 | 02-24-2019 12:15 PM |
| Expensive, but cool Die Cast GT-86 | Kimsey47 | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 11-26-2013 05:12 AM |
| FS: Die-cast EBBRO 1/43 frs 86 | blanco | Miscellaneous | 4 | 09-25-2013 10:42 PM |
| Durability of cast wheels | AsianStyle | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 12-06-2012 05:10 PM |
| Any Disney Cast Members here? | MF_DEUCE | Off-Topic Lounge [WARNING: NO POLITICS] | 9 | 11-18-2011 01:48 AM |
