Old 05-24-2020, 06:57 PM   #1
Bowtie2bimmer
Drives: 2016 Scion FR-S
SCCA Solo class question
2 weeks ago I did my first event in my car, classed as C Street. I have trd sways and springs but apparently as long as it was the TRD stuff, I was OK to be in Street.
I just added 17x8 wheels, which is 1" wider than stock. Tires are 225/45. Can I still run as C street or have forced myself into a new class? If so which one? I have tried reading the rule book but i couldn't figure it out
Sent from my SM-G973U using Tapatalk
Bowtie2bimmer is offline   Reply With Quote
Old 05-24-2020, 08:26 PM   #2
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
you played yourself you are now in stx technically. if you arent competitive tho, no one will probably say anything. i swear at least 20% of the cars are classed wrong
The Following User Says Thank You to Breadman For This Useful Post:
strat61caster (05-25-2020)
Old 05-24-2020, 08:37 PM   #3
Bowtie2bimmer
Ha, definitely not competitive!
Old 05-24-2020, 08:45 PM   #4
Breadman
Breadman's Avatar
you could always run under novice
Bowtie2bimmer (05-25-2020)
Old 05-25-2020, 01:50 AM   #5
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
You could have the beginnings of an SSC build going for you. You'll have to buy wheels again if you want to be competitive in STX as 9" wide wheels are faster.
SSC will have you buying new Eibach parts that may be identical to your TRD stuff, but you can probably get some of the money back selling the TRD parts.
https://racer.com/2018/04/18/diving-...tocross-class/
ineedyourdiddly
Old 05-25-2020, 09:36 AM   #6
Bowtie2bimmer
Looking at the SCC build list, my wheels are +35 and it looks like +40 or greater is required. So sounds like I am kinda screwed there too
The Following User Says Thank You to Bowtie2bimmer For This Useful Post:
Old 05-25-2020, 09:38 AM   #7
Bowtie2bimmer
Pardon my ignorance but is novice considered its own class? When I registered for the event it asked for my class but I didn't see novice as a class
Old 05-25-2020, 10:19 AM   #8
M0nk3y
You can simply just run a 5mm spacer and be compliant.
Kyle H. - #89 STX
Old 05-25-2020, 10:29 AM   #9
Bowtie2bimmer
Isn't running a spacer going to be add more negative offset? If I ran a 5mm spacer I would be effectively at +30, not +40.
Old 05-25-2020, 10:31 AM   #10
Breadman
Breadman's Avatar
your region might not have it. but it is anyone that wants to and there are no points or requirements to enter. they also will have good drivers out there to ride along and help you if you want to.
Old 05-25-2020, 11:16 AM   #11
troyguitar
Drives: 2020 Toyota 86
That's correct.
troyguitar is offline   Reply With Quote
Old 05-25-2020, 08:57 PM   #12
M0nk3y
Math is hard sometimes. I’m stupid. You’re right
Kyle H. - #89 STX
SCCA pro solo what class TRD_Demon527 Tracking / Autocross / HPDE / Drifting 34 05-11-2015 10:45 PM
new solo class G-Man Tracking / Autocross / HPDE / Drifting 3 04-01-2015 06:13 PM
2014 SCCA Solo Nationals/Pro Solo Finale thread edj Tracking / Autocross / HPDE / Drifting 206 09-19-2014 11:34 AM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
