Old 04-22-2020, 11:15 AM   #57
gpvecchi
gpvecchi's Avatar
I swapped the cluster to the GR model.
I have 2 issues: open door signals are swapped, if you open left door, display will show the right one.
This can be fixed swapping some wires in the BCM unit, but this will lead to headlight on chime triggered by right door.
The other issue is no TPMS anymore, it's active in diagnosys, but there's no warning light. This can be useful, indeed...
Old 05-23-2020, 04:05 PM   #58
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
For anybody still looking to do this, but not wanting to spend the money on a full unit or deal with programming issues and stuff...
Full cluster overlay. Stock USDM unit. Speedo is in MPH only. LCD screen isn't split white/black like the real one, but otherwise, it's spot on. Cost was $200 from https://www.icefabrication.com
They have one on the site, but it isn't as accurate as this one, so I e-mailed him directly for the inquiry to have him create one as accurate as possible.
Figured some of you in here might find this to be a more attractive solution.
The Following 4 Users Say Thank You to TylerLieberman For This Useful Post:
CkOne (05-25-2020), MJones_RB (07-01-2020), PulsarBeeerz (05-23-2020), weederr33 (05-23-2020)
Old 05-23-2020, 04:17 PM   #59
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Full cluster overlay. Stock USDM unit. Speedo is in MPH only. LCD screen isn't split white/black like the real one, but otherwise, it's spot on. Cost was $200 from icefabrication.com. They have one on the site, but it isn't as accurate as this one, so I e-mailed him directly for the inquiry to have him create one as accurate as possible.
I need this!!!
MS, CSCS, TSAC-F, CPT
Old 05-23-2020, 04:39 PM   #60
TylerLieberman
Drives: '24 GR86
Originally Posted by weederr33 View Post
I need this!!!
^^Plenty of options, including the GR ones here.
Old 05-23-2020, 05:25 PM   #61
weederr33
weederr33's Avatar
Both the GR and the STI are missing two critical pieces that distinguish them: the logos. Though I do like the GR version more.
Old 05-23-2020, 05:41 PM   #62
TylerLieberman
Drives: '24 GR86
Email directly and ask to have the logo added. They can be custom done.
Mine has the logo, as you can see.
The Following User Says Thank You to TylerLieberman For This Useful Post:
Old 06-29-2020, 12:30 PM   #63
yangsik777
Hi. Have you solved this problem? I wonder if there are any methods other than swapping wires on BCM unit.
yangsik777 is offline   Reply With Quote
Old 06-29-2020, 04:41 PM   #64
gpvecchi
gpvecchi's Avatar
Nope, I decided I prefer the headlight chime to be on the correct door. Or you have to send your cluster to Gerald for software tuning.
Or you have to buy a LHD tS cluster and swap the dials for Km/h and sell the remaining Franken in UK.
2017 Limited Gauge Cluster halleffect Electronics | Audio | NAV | Infotainment 26 10-22-2020 07:32 PM
Help! Is there anyway to change the 2017 cluster start up image? slashlee DIY (Do-It-Yourself) Guides 2 11-17-2018 05:36 PM
Any Mid-Year 2017 86 Special Edition? Borchert97 Scion FR-S / Toyota 86 GT86 General Forum 42 03-14-2017 07:43 AM
2017 Limited Gauge Cluster halleffect Cosmetic Modification (Interior/Exterior/Lighting) 0 01-16-2017 03:55 AM
2017 gauge cluster Drakiv Cosmetic Modification (Interior/Exterior/Lighting) 2 11-14-2016 11:32 PM
