Old 05-22-2020, 03:48 AM   #1
Yitzb
Yitzb's Avatar
Drives: Brz with wudebody. Hopefully boost
Doors won’t lock
The touch of the door lock doesn't work, neither does locking it using the buttons on the key fob but it does make and sound when pressing button with the key and the headlights and twilights blink
Yitzb is offline   Reply With Quote
Old 05-22-2020, 09:32 AM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
The Following User Says Thank You to JD001 For This Useful Post:
soundman98 (05-22-2020)
Old 05-23-2020, 01:47 PM   #3
p1l0t
p1l0t's Avatar
I was thinking about disabling the locks on my car and just having this angry little gopher that won't attack me but would knaw down to the bone anyone else who tries to rummage through my change in the center console.
The Following 2 Users Say Thank You to p1l0t For This Useful Post:
Silviacrazed (05-24-2020), soundman98 (05-23-2020)
Old 05-23-2020, 02:19 PM   #4
Unhook the battery for a few minutes and see if t resets things.
Old 05-23-2020, 11:09 PM   #5
Yitzb
Yitzb's Avatar
I tried that and it didn’t work
The Following User Says Thank You to Yitzb For This Useful Post:
Tcoat (05-23-2020)
Old 05-24-2020, 12:07 AM   #6
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Do the locks open and close normally when you use the key or the buttons in the car? If not then you may have a problem with the harness or a grounded wire, but I don't know. If it is just with the fob then try replacing the battery in the key fob.
Old 05-24-2020, 12:09 AM   #7
Yitzb
Yitzb's Avatar
Doesn’t work with anything. What ground should I check?
Old 05-24-2020, 12:24 AM   #8
Irace86.2.0
Neither side works electronically using the door card buttons? You can manually lock the doors, but nothing electronically is working on either side, right? Check the fuse. If it is only one side then maybe the harness wiggled loose. Do you have the ability to roll up and down the windows and does the speakers in the doors work (feel and listen carefully)?
Old 05-24-2020, 07:02 AM   #9
JD001
JD001's Avatar
Drives: Subaru BRZ
What were you doing to the car just prior to the problem occurring? Work your way backwards..
Opie (05-26-2020)
Old 05-24-2020, 12:43 PM   #10
Yitzb
Yitzb's Avatar
Everything else works on both doors aside from the locks
Old 05-24-2020, 12:43 PM   #11
Yitzb
Yitzb's Avatar
I bought the car from copart like this
Opie (05-26-2020)
Old 05-24-2020, 12:52 PM   #12
Irace86.2.0
Remove the door card. Make sure the wire/ball is secured into the lock. Check the electrical harness that it is plugged in.
https://www.ft86club.com/forums/show...89&postcount=3
Old 05-24-2020, 01:38 PM   #13
ls1ac
ls1ac's Avatar
You say that there is a noise when you push the Button. From inside the doors? Both doors? If it is both doors then probably not in the door. If the sound is in the doors then it is trying to work but probably low voltage.
Old 05-24-2020, 01:53 PM   #14
Yitzb
Yitzb's Avatar
No noises
Adding doors auto-lock and oil t° display to your FRS / BRZ / 86 T0rt0r0 DIY (Do-It-Yourself) Guides 82 05-14-2019 12:46 AM
Doors won't lock. mynameis940 Issues | Warranty | Recalls / TSB 9 03-15-2018 02:05 PM
Trunk won't open and doors won't lock/unlock Mazikowski Electronics | Audio | NAV | Infotainment 13 03-05-2018 10:50 AM
Auto Lock (Doors) pinoyplaya BRZ First-Gen (2012+) — General Topics 67 11-13-2017 10:47 AM
Doors won't automatically lock adan Issues | Warranty | Recalls / TSB 18 03-01-2014 10:02 AM
