Old 05-18-2020, 09:04 AM   #225
gcranston
Drives: 2015 Subaru BRZ Limited DGM
on track testing?
Has anyone had the chance to do much on track testing with the trac box yet? Sadly our season got shut down before it even got started, and I didn't even get a snowy winter to go drifting around parking lots.
gcranston is offline   Reply With Quote
Old 05-18-2020, 09:36 AM   #226
ML
ML's Avatar
Drives: 13 White MT FR-S
Grip driving, works great! Drifting, still had to pull the ABS fuse.
Old 05-18-2020, 09:42 AM   #227
ka-titties
Drives: 2013 BRZ Limited 6MT
That pedal dance button is great hahaha
ka-titties is offline   Reply With Quote
Old 05-18-2020, 10:37 AM   #228
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It just puts the car in pedal dance mode. There is tons of info on pedal dance on track.
Old 05-18-2020, 10:46 AM   #229
gcranston
Yes, I had been running pedal dance on track. I was curious if anyone had noticed a difference between PD, Trac Box, and Beastronix, or if they were all the same. My testing was limited to "does it turn the TC light on"?
Old 05-18-2020, 10:49 AM   #230
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Originally Posted by churchx View Post
Indeed, wonderful mod. @rice_classic: That "custom switch from CH4X4" - any more details? Part number?
I believe it was this: https://www.ch4x4.com/product/ch4x4-...push-switches/
Small push switch. Depending on what options you chose with the tracbox will determine whether you get a on/off switch or a momentary switch.
PRO86 | WTCC | STL
The Following User Says Thank You to rice_classic For This Useful Post:
churchx (05-18-2020)
Old 05-18-2020, 10:50 AM   #231
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
All the Trac Box and Beastronix box do is initiate PD mode without having to do it manually and heat soak the crap out of your engine bay while trying to get the coolant up to the required temp. You can initiate PD at anytime.
Old 05-18-2020, 12:00 PM   #232
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
I think the question is that.. 'does the TracBox implementation actually work'? All we see at this point (because of lack of testing / track closed) is that the trac lights are on.
iLuveKetchup is offline   Reply With Quote
The Following 2 Users Say Thank You to iLuveKetchup For This Useful Post:
gcranston (05-18-2020), NoHaveMSG (05-18-2020)
Old 05-18-2020, 01:55 PM   #233
rice_classic
See posts #133-138.
PRO86 | WTCC | STL
Old 05-18-2020, 02:38 PM   #234
iLuveKetchup
Drives: EFF JAY
Originally Posted by rice_classic View Post
See posts #133-138.
I don't see any code (nor do I expect to) or any kind of logging that tells me that pedal dance is activated other than lights on the dash board.
I was looking for more real world use and/or data management / logging.
Old 05-18-2020, 03:30 PM   #235
rice_classic
I have raced with both the PD and TCLP (Traction control Long press) and the difference is clear. I will be on track this weekend with testing on Friday so I should get a chance to test both and verify... assuming I remember.
I'm including Gerald's explanation from page 11 for the rest of the participating audience...
This box uses the command over the Canbus and the TCLP isn't a CANBUS command but PD is. (Bold/emphasis below is mine)
Well how this work is that dealer level software or even factory level software that had commands that are send though canbus. They can activate or deactivate various part of different systems. Well not sure what to tell you.. but you can check if your in PD mode is by when your on it, short pressing or long pressing either the TC or the sport button wont work at all until you turn off the car or send the PD off command though canbus. Which i can, but while in PD mode the buttons wont do anything. Also, these commands are not to the ecu but the ABS module. They are dealer level/factory level commands. So outside the typical OBD2 commands, and they are not the vehicle level data (i mean the regular transport data for regular function).
Through canbus there isnt any long press traction control "command" so its not possible to send TCLP though canbus. Only by physically possible by actually pressing the button.
PRO86 | WTCC | STL
Old 05-19-2020, 08:49 AM   #236
RRslip
Drives: Black BRZ - STX
+1
Just to re-iterate, the TCLP is a SWITCH hardwired to ABS. The Trac Box is hardwired to the CAN bus only. Therefore, it's not some elaborate trick he's playing on you...the trac box doesn't even connect to the TC switch...
Also, these CAN commands for pedal dance are very basic. It's actually much easier to do it using the pedal dance commands over CAN than it would be to tie into the TC switch. Nice work Gerald!
RRslip is offline   Reply With Quote
Old 05-19-2020, 10:35 PM   #237
ML
ML's Avatar
just noticed when I turn the fans on using the box it only turns the passenger side fan on. Is that by design or do I have an issue?
Old 05-20-2020, 07:59 AM   #238
peaches
Drives: '14 BRZ Limited
I think that's by design, as far as I know the other fan is for the AC only.
peaches is offline   Reply With Quote
The Following User Says Thank You to peaches For This Useful Post:
ML (05-20-2020)
WTB a Beastronix 86 Nanny unit tonylop33 Want-To-Buy Requests 0 09-25-2018 07:14 PM
FS: Beastronix 86 Nanny - SOLD Agent_D Engine, Exhaust, Bolt-Ons 3 05-09-2018 01:57 PM
Beastronix Install HoonThis Software Tuning 4 06-08-2017 10:02 PM
Flex Fuel Kit and Beastronix 86Nanny Trac/VSC Juanito08 Engine, Exhaust, Bolt-Ons 7 05-10-2017 02:20 PM
Beastronix - 86 Nanny , Speed Academy version brzaapi User/Vendor/Sponsor Reviews, Feedback, Comments 4 07-05-2016 11:17 AM
