#141 | |
Drives: 2019 BRZ Sport-Tech RS
I'll be looking to order the JDM tips as well. Last edited by N_Raged; 01-31-2020 at 12:46 PM. |
#142 |
I happen to have a set I was going to use but changed directions. Shoot me a PM if your interested. Will probably post these this weekend in the FS section
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | Busybee (02-08-2020) |
#143 |
Drives: GR86 Trueno Edition
Please can you guys post picture and a link if you happen to order the JDMs from somewhere. I want the original diffuser but not with the stock tips
#144 |
So I think the 2017+ muffler has shorter tail pipes. So even with the JDM tips on, they do not poke out from the bumper like all the pics in this thread. Once installed they are longer than the stock tips by maybe under 1 inch, but the ends are still recessed in the diffuser. The problem is the bump stops of the JDM tip are similar to the USDM tips with respect to the end of the tips.
I don't have the JDM tips on me anymore and was stupid to not take a photo when I did a test fitting. In the end, this is not worth pursuing on 2017+ cars. Here's a photo of stock tip vs JDM tip: |
| The Following User Says Thank You to N_Raged For This Useful Post: | Busybee (02-17-2020) |
#145 |
Would anyone with the JDM tips be able to measure the distance between the bump stop inside the tip to the outer edge of the tip?
Like this:
#146 |
Does anyone have pictures with the JDM (44370CA000) on a 2017+ BRZ?
Meanwhile, is the Toyota tip SU003-01126 the same as the JDM in terms of the shape and dimensions? |
#147 | |
In short, not worth it. |
| The Following User Says Thank You to N_Raged For This Useful Post: | Busybee (05-14-2020) |
#148 | |
Despite the difference in the length? Wooow! Did not expect that. I decided to keep the exhaust and only change the tips for the look. That’s really bad. Thanks for the information. Sent from my iPhone using Tapatalk |
#149 | |
How much is the difference between these tips. I assume that the difference is what I will gain in length. Sent from my iPhone using Tapatalk |
#151 |
The JDM tips may be physically longer than the 2017+ USDM tips, but once installed some of that length goes to the front of the car as well. So the additional 3" doesn't all go towards the back.
Easiest way to explain this is with a quick photochop of the stock photo i posted earlier in this thread. This is roughly how it looks. |
| The Following 2 Users Say Thank You to N_Raged For This Useful Post: | ActionMaxon (05-14-2020), Busybee (05-14-2020) |
#152 | |
Definitely not worth the ~$150 I wish there would be a non-welding extension option of the muffler pipe and use the original tips Thanks for the picture Sent from my iPhone using Tapatalk |
#153 |
JDM BRZ/GT-86 Exhaust Tips
If the JDMs are 8” it will be a different story! Earlier here it was mentioned that the JDMs are 7”. I was not able to find it anywhere. To reconsider the tips I got some measurements from my MY19. ![]() While the Lower length is around 4.5” the upper length is a quarter or max 1/2 quarter less than 6” ![]() If the JDM is 7, it’s not a dramatic difference (still some and better IMO). But if the JDMs are 8” that will make a real difference. As shown in the picture below; ![]() The bolt holes are at the same position as shown in the picture previously. That means 8-5.75=2.25” more than the stock is coming out. It will get almost flush with the bumper at the angle of the plastic. Which I think will dramatically change the look. Would really appreciate if anyone else can confirm Yoshoobarooo in terms of the 8”length or check his/her JDMs. Meanwhile I assume that the OD (4.25” ) and the shape (longer on the upper and shorter on the lower) as the stock. ![]() Appreciate any reply! Thanks Sent from my iPhone using Tapatalk |
#154 |
TRACKBREAD
My measurement was at the top, so the long end.
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | Busybee (05-14-2020) |
| Exhaust Tips *UPDATED* with pics | Ericfrs | Cosmetic Modification (Interior/Exterior/Lighting) | 35 | 01-13-2017 02:58 PM |
| Exhaust System/Exhaust Manifold Removal and Replacement | GrimmSpeed | DIY (Do-It-Yourself) Guides | 52 | 11-11-2015 09:30 PM |
| Exhaust tips | rawbz | Cosmetic Modification (Interior/Exterior/Lighting) | 37 | 01-19-2013 08:12 PM |
| Let's keep it simple, I want to change out my exhaust tips. | Liquidsnake | Engine, Exhaust, Transmission | 11 | 06-30-2012 03:08 AM |
| Overseas OEM Exhaust Tips (Japanese/European models) | frsaraiki | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 05-25-2012 12:03 AM |
