Old 05-13-2020, 09:07 PM   #1
RWD fun
Removing shock tower brace
Hi, I couldn't find the exact correct name for the part, but will removing and reinstalling this part (highlighted) affect the alignment? I've just had the alignment done and ould hate to throw it off.
RWD fun is offline   Reply With Quote
Old 05-13-2020, 09:26 PM   #2
ZDan
ZDan's Avatar
Drives: '23 BRZ
shouldn't affect you, I wouldn't worry about it.
ZDan is online now   Reply With Quote
RWD fun (05-13-2020)
Old 05-13-2020, 09:28 PM   #3
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
It won’t do anything to the alignment.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Old 05-13-2020, 09:41 PM   #4
RWD fun
Thanks! Out of curiosity, what effect to shock tower braces have this car? Seems like it would make the car stiffer around turns?
Old 05-13-2020, 09:54 PM   #5
Yoshoobaroo
TRACKBREAD
Exactly, they reduce chassis flex under high cornering load. They are not loaded sitting still on a level surface.
Old 05-13-2020, 09:57 PM   #6
Yoshoobaroo
TRACKBREAD
When you put it back on, do not over tighten, the studs strip easily. Spec is 12ft*lbs, no more.
WTB: Strut Tower Brace BooneBRZ Want-To-Buy Requests 3 02-25-2020 10:05 AM
NEW - AEM STRUT TOWER BRACE w/ Master Cylinder Brace prj3ctm4yh3m Brakes, Suspension, Chassis 4 01-24-2017 01:24 AM
WTB: AEM Front Strut tower brace with master cylinder brace prj3ctm4yh3m Want-To-Buy Requests 0 08-05-2016 01:49 PM
STI strut tower brace theanswer3 Brakes, Suspension, Chassis 0 04-19-2016 02:54 AM
FS: Cusco Front Strut Tower Brace with Master Cylinder Brace / Adj Chassis Brace VoiD Brakes, Suspension, Chassis 2 03-16-2016 04:19 PM
