Old 05-13-2020, 04:37 PM   #1
Dububster
Dububster's Avatar
Quietest Catless Header
I'm aware that a catless header is loud so you don't need to tell me that, but are there any catless headers that are a bit quieter than the rest? The only other exhaust component I have is an MXP Comp RS catback and I don't want my ears to bleed whenever I'm just casually driving but want the power that comes with a catless header and a tune. Thanks!!
Dububster is offline   Reply With Quote
Old 05-13-2020, 04:43 PM   #2
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
When I had my HKS for a short time, it wasn't very loud. You might want to get a catted header as the gains won't be much different and it will keep the noise down. Also you're in Cali so... yeah you guys have Nazi noise regulations.
MS, CSCS, TSAC-F, CPT
Old 05-13-2020, 05:16 PM   #3
Dububster
Dububster's Avatar
LMAO, we do indeed. The only reason I haven't looked into a catted header very much is because they are like double the price and I don't wanna spend that much more on something that is still illegal.
Old 05-13-2020, 05:57 PM   #4
weederr33
weederr33's Avatar
lol fair point.
Old 05-13-2020, 08:53 PM   #5
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
The stock one de-catted.
The Following 2 Users Say Thank You to x808drifter For This Useful Post:
86MLR (05-13-2020), why? (05-15-2020)
Old 05-13-2020, 11:45 PM   #6
HaXx
Drives: jrsc_brz
Is the stock decatted really not that loud? Can you give a little insight as to how tolerable it is because I'm thinking of punching mine.
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
Old 05-14-2020, 01:06 AM   #7
gpvecchi
gpvecchi's Avatar
EL will be quieter than UEL.
Old 05-14-2020, 12:07 PM   #8
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
This.
Why? The stock cat acts as a resonator, so the extra volume helps to reduce sound.
Another part is that the stock header uses steel that is much thicker than aftermarket stainless piping. It's done for warranty/durability reasons but it looks like crap, so no aftermarket company would do that.
The only real drawback to using the stock header is that over time, you'll have more rattle from the heat shields. Keep in mind that sound energy can also cause unwanted secondary noises from other parts of the exhaust system.
It's why the stock exhaust is designed the way it is, it's why there are random pieces of sound deadening material all over the car.
why? (05-15-2020)
Old 05-14-2020, 01:37 PM   #9
churchx
churchx's Avatar
Drives: 2014 GT86
But resonators work with frequencies depending on their size. If "resonator" is short-ish ex-cat "bulb", it's questionable, if frequencies changed/removed by such matter at all. Somehow no aftermarket catback for twins seen had resonators of similar size (with exception being maybe nameless's downpipe optional orb-like helmholtz resonator, but only size looks a bit similar, how such, connected with separate side pipe, function, it may differ).
Old 05-14-2020, 01:42 PM   #10
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Most of the power gain comes from the tune. Try getting the tune first and see if you're happy with it
mrg666 (05-14-2020)
Old 05-14-2020, 03:36 PM   #11
mrg666
pessimistic skeptic
mrg666's Avatar
Do you know any dyno plots showing how much can be gained just by tune?
Old 05-14-2020, 04:54 PM   #12
churchx
churchx's Avatar
Drives: 2014 GT86
For very rough numbers out of thin air imho expected gains mentioned in Steve99's basic bolt-on guide thread's OP should do.
phm14 (05-16-2020)
Old 05-14-2020, 05:31 PM   #13
DarkPira7e
DarkPira7e's Avatar
I have my own best proof; my own dyno tuned car. My car made almost the same power with the tune without the catless headers vs when retuned with catless headers. The difference in runs between each was within 5whp peak. I went with u equal length headers and even in the mid range, there wasn't a significant difference. I'm not saying that there are no gains
Op should get a tune, post average dyno plots. Then get catless headers, get re-tuned, and post average dyno plots. I think they'll be wishing they'd spent the money on tires instead
mrg666 (05-14-2020)
Old 05-15-2020, 01:18 AM   #14
BRZ_88
Imperator
Drives: Supercharged 2013 BRZ Limited
I installed Borla UE length headers and the results were pretty damn loud even with the stock exhaust.
I'd ordered a Remark muffler delete axleback which arrived soon after, and with that installed too I'm reading 85db inside the car cruising at 70mph. It's almost uncomfortably loud now but I'll enjoy it until I get pulled over.
BRZ_88 is offline   Reply With Quote
catless header vs catless frontpipe steveholt Engine, Exhaust, Transmission 30 10-10-2017 07:13 PM
Quietest catless front pipe Flat_4_Life Engine, Exhaust, Transmission 9 04-06-2016 07:14 PM
Best UEL catless header bozack Engine, Exhaust, Transmission 13 04-24-2015 02:00 PM
Quietest EL Header? Silver Ignition Engine, Exhaust, Transmission 17 01-09-2015 09:50 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
