Old 05-12-2020, 11:35 AM   #1
alex87f
Meow
alex87f's Avatar
Drives: Focus ST mk4
Aftermarket axleback fitment
Hello guys,
I've finally received my axleback, and got round to fitting it last weekend. Only things didn't go as well as I'd hope, as fitment isn't fantastic.
As you can see in the pictures, I can't raise the driver's side tip as much as I'd like to, and there's also a symmetry issue when looking from the top.
Have I done anything wrong in fitting the exhaust? I'm under the impression that this is an issue with the axleback's design, what do you think?
Would it be a terrible idea to just slightly "persuade" the tubes to get closer to each other (with a hammer)? I just need to gain about 1/3rd of an inch where they meet.
alex87f is offline   Reply With Quote
Old 05-12-2020, 11:54 AM   #2
Gloonge
Drives: 2013 frs raven
You can likely adjust how far that right side stick out by bending the hanger.
Gloonge is offline   Reply With Quote
Old 05-12-2020, 01:33 PM   #3
alex87f
Meow
alex87f's Avatar
Yeah that doesn't worry me too much.
The height issue, however, does!
Old 05-12-2020, 01:51 PM   #4
Gloonge
You could likely find shorter rubber pieces if you were so inclined. Also in the center of the exhaust system there is a metal hanger that offers some adjustment that you might be able to get a little vertical movement out of.
Old 05-12-2020, 03:48 PM   #5
alex87f
Meow
alex87f's Avatar
Come to think of it, I could probably solve the height issue by bending the rear silencer hangers down a little bit.
Now they're almost half an inch diameter, so that could prove an interesting challenge
Old 05-12-2020, 03:51 PM   #6
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
You’re likely going to need tighter poly exhaust hangers anyway. The hangers on your aftermarket exhaust aren’t flared like the stock ones are. It will slide off the hangers during vigorous cornering if you don’t replace them with tighter ones. Cusco makes a nice 12mm set, and they’re a little bit shorter as well.
Old 05-12-2020, 04:05 PM   #7
alex87f
Meow
alex87f's Avatar
They're not flared on the outer edge, but have a higher diameter "ring" on the inner side that sits on the rubber hangers which you can sort of see on the picture above. Having that on all four corners would very much negate the risk of it sliding off, as it prevents the metal from sliding too far into the hanger.
I was thinking of using a screw collar to bring that risk down to 0:
Old 05-12-2020, 04:16 PM   #8
Yoshoobaroo
TRACKBREAD
I missed that.
The small hole clamps work great as a temp fix, that's how I held my Greddy on until the new hangers showed.
Old 05-17-2020, 06:11 AM   #9
alex87f
Meow
alex87f's Avatar
Well I did a fair bit of hanger-bending, and it's much better now. Gained about 1/2 an inch in tip-to-bumper distance:
Old 05-17-2020, 07:25 AM   #10
Yoshoobaroo
TRACKBREAD
Nice! Looks much better!
How's the fitment of 1320's dual res fp fitment on AT aznchris Engine, Exhaust, Transmission 0 04-16-2019 06:02 AM
Aftermarket Side Markers Fitment Issues Darth Khan Cosmetic Modification (Interior/Exterior/Lighting) 1 09-13-2017 11:54 AM
Aftermarket Bumper covers-how's the fitment? guybo Cosmetic Modification (Interior/Exterior/Lighting) 4 04-17-2017 04:44 PM
WTB: Greddy SP Elite Axleback or Nameless Axleback brzfl Want-To-Buy Requests 0 01-04-2017 10:37 PM
Quietest 2.5" axleback or midpipe+axleback for my JDL UEL? stockysnail Engine, Exhaust, Transmission 22 03-28-2015 01:52 PM
