Old 05-09-2020, 12:18 PM   #1
melvin_213
Drives: Subaru BRZ ‘14
Help with reverse camera
Hey all, I recently installed a Sony XAV-AX5000 and I need help with my reverse camera, it makes the quality of the video really bad with flicking after the car is turned on. But when I’m in accessory mode, the camera’s video quality is clear. What can I do about this image?
melvin_213 is offline   Reply With Quote
Old 05-09-2020, 12:32 PM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
Ole @humfrz can help.. calling Mr Humfrz, calling Mr Humfrz, we have a query here that fits with your speciality..
The Following User Says Thank You to JD001 For This Useful Post:
humfrz (05-09-2020)
Old 05-09-2020, 02:02 PM   #3
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
What rear view camera are you using? The stock one is 6v. Maybe the aftermarket head unit utilizes a 12v. Maybe you need a converter if so.
My Kenwood HU utilizes a 12v camera, and that is what I bought. I feel like people who bought the same unit with the stock camera just found a black screen--not a flickering screen--so I don't know if your problem is a voltage issue.
Old 05-09-2020, 02:07 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
how are you connecting the existing camera? is it a RCA connection?
Old 05-09-2020, 02:43 PM   #5
OK, I'm here. hmmmm......for the OP things behind the car look to be flickering.
Well, I'm sorry to say, that is just the early stages of the disorder. Soon things will move around. In the latter stages, things will zoom up on you quickly. The final stage, before they take your license away, big things will jump up behind you, with no warning.
There is no cure, but you can minimize the damage by limiting parking where you have to back up.
JD001 (05-09-2020)
Old 05-09-2020, 02:53 PM   #6
JD001
JD001's Avatar
Drives: Subaru BRZ
Thank you Mr Humfrz, your input most helpful. We may call upon your expertise if/when rear bumper requires some TLC.
humfrz (05-09-2020)
Old 05-09-2020, 03:04 PM   #7
I may not be the best person to call. Someone here on the forum said my latest ding would "rub out". I've tried, but with no luck. Maybe I need a stronger rubbing compound?
JD001 (05-09-2020)
Old 05-09-2020, 03:14 PM   #8
JD001
JD001's Avatar
Drives: Subaru BRZ
I suggest that the next time you go rubbing just keep a copy of your Playboy stash by your side.
humfrz (05-09-2020)
Old 05-09-2020, 03:39 PM   #9
That's what I use my very good long term memory for -
JD001 (05-09-2020)
Old 05-09-2020, 03:59 PM   #10
ls1ac
ls1ac's Avatar
Looks like you are looking through a screen door.
Ok, does the vertical lines change or move right and left with RPM if yes then a line filter, or ferrite ring core that snappes on the video line might help. Sometimes looping it through twice works better.
Old 05-09-2020, 04:16 PM   #11
melvin_213
I’m using an aftermarket one from amazon, it’s camerasource. How can I check if it’s a voltage issue? Whet can get a converter?
Old 05-09-2020, 04:17 PM   #12
melvin_213
Yes it’s an RCA connection from the camera, straight to the headunit
Old 05-09-2020, 04:22 PM   #13
melvin_213
While the engine is on it flickers bad, to where it goes to “no video signal” then back to the video screen
Old 05-09-2020, 04:49 PM   #14
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
I suspect there's a bad or highly questionable ground somewhere. I would think first to the camera itself, but the headunit's ground interference (if the problem is up there) could filter to the camera if the camera is powered off the HU. I'd check and re-do both and see if it improves.
sharpsicle is offline   Reply With Quote
Need help with installing Camera Source's reverse camera for 2013 FRS Ann13 DIY (Do-It-Yourself) Guides 9 09-30-2019 07:39 PM
Reverse Camera Emissary_of_Pain Electronics | Audio | NAV | Infotainment 5 10-27-2017 10:13 AM
FYI - it's possible to add a reverse camera for $20. SloS13 Electronics | Audio | NAV | Infotainment 25 09-09-2013 10:03 PM
Reverse Camera FT86_Zero Scion FR-S / Toyota 86 GT86 General Forum 26 08-05-2012 08:05 PM
Reverse camera? dorkymork BRZ First-Gen (2012+) — General Topics 28 05-21-2012 10:21 AM
