Old 07-20-2012, 08:44 PM   #1
TSLRich
Drives: FJ Cruiser
Bolt Pattern Woes
Ok.. so I don't have a BRZ/FR-S, but I'm in love with the car. I plan on eventually getting one so I'm already plotting and planning and one thing has me anxious... the odd choice in bolt pattern for this car. I don't know why Toyota/Subaru chose 5x100 for this car instead of the much more prevalent 5x114 or 5x120. I've already found several wheels that I'd like that are not offered in 5x100.
So the question is... do we think that the FT-86 platform will be popular enough that wheel manufacturers will begin offering the size in more of their designs?
TSLRich is offline   Reply With Quote
Old 07-20-2012, 08:52 PM   #2
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
5x100 was the size with 2000-2005 VWs and there was tons of selection. So I'd imagine if it becomes popular again the wheel brands would be crazy not to jump on board. But it takes time, and hopefully some other models will use it as well (any of the upcoming small cars)
Khyron686 is offline   Reply With Quote
Old 07-20-2012, 09:33 PM   #3
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Subaru WRX is the answer.... 5x100.
Lots of wheels in the works with the right offsets for this platform.
FT-86 SpeedFactory is offline   Reply With Quote
Old 07-20-2012, 09:41 PM   #4
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I'm having to keep this in mind with lots of other parts too, patience is key when dealing with a new model i don't want to end up buying the same parts multiple times from different manufacturers.
Old 07-20-2012, 10:04 PM   #5
schtebie
Drives: CBS BRZ Limited
The Celicas from the same time period also use the 5x100 PCD.
schtebie is offline   Reply With Quote
Old 07-20-2012, 11:53 PM   #6
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
I was used to the problem of finding good lightweight 5x100 years ago when I drove Neons, but back then the issue was with finding light 14" or 15" wheels. Thankfully there are years of VW and Subaru cars that used 5x100 years in similar sizes, so there are at least some wheel models available, although not nearly as widespread as 5x114 (or 4x100).
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 07-21-2012, 08:21 AM   #7
TSLRich
Drives: FJ Cruiser
I really like the Konig SSM wheels.... hoping they come out with a 5x100 pattern.
Old 07-21-2012, 10:03 AM   #8
Suiris
Suiris's Avatar
When I was searching... I literally found hundreds of choices in 5x100. Tirerack alone had like 235 different wheels to choose from.
2013 Scion FR-S Raven MT: http://www.ft86club.com/forums/dto_g...ehicle_id=1141
--This tagline is umop episdn
Suiris is offline   Reply With Quote
Old 07-21-2012, 10:19 AM   #9
TSLRich
Drives: FJ Cruiser
not really, when you subtract out the wheels that are exactly the same but offered in different colors.
Old 07-21-2012, 10:27 AM   #10
Suiris
Suiris's Avatar
Yes, yes, but still a choice nonetheless. I saw quite a few when I was looking that I'd have liked better in a different color but only came one way.
Hope you find a good set you like...
I, however, managed to find 5 I really liked and then began eliminating one by one til I got the the set I ordered up... and yes, yes, it needs a drop... and cleaned... The wheels were only on for like 5 minutes and it was raining...
Old 07-22-2012, 09:25 PM   #11
TSLRich
Drives: FJ Cruiser
What were the other 4?
Old 07-22-2012, 10:06 PM   #12
sfwg
Drives: 2007 saturn ion(dd)
Rpf1 are coming in 17x9 this winter
2014 FRS
sfwg is offline   Reply With Quote
The Following User Says Thank You to sfwg For This Useful Post:
TSLRich (07-22-2012)
Old 07-22-2012, 10:14 PM   #13
TSLRich
Drives: FJ Cruiser
Now those are nice wheels...
Old 07-23-2012, 08:07 AM   #14
Nepenthe
Drives: 2013 Argento Silver Automatic FR-S
How do you search like that on TireRack? I can search for tires by size but for wheels they seem to restrict how you can search (you have to put in a make/model and then it gives you limited choices).
Anyway, I'm looking to go lighter and smaller, 16s probably (but something that makes the rear at least flush with the fenders). Looks are a secondary concern.
Nepenthe is offline   Reply With Quote
What other vehicles use a 5x100mm bolt pattern? EsoBOFH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 09-13-2014 04:42 AM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 12:19 PM
bolt pattern is 5x100? derka-derka Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-30-2012 02:58 AM
Bolt Pattern, Wheel Hubs and Studs Jeff Lange Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 03-08-2012 02:49 AM
The wheel bolt pattern is... quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 193 02-29-2012 06:04 PM
