Old 05-03-2020, 03:17 PM   #15
gpvecchi
gpvecchi's Avatar
A friend said that on his BRZ the key was to keep stock midpipe, if using a catless header. Any other combo he tried sounded ugly...
The Following User Says Thank You to gpvecchi For This Useful Post:
DarkPira7e (05-03-2020)
Old 05-03-2020, 03:23 PM   #16
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Originally Posted by mav1178 View Post
I did that once, Tomei header w/ stock everything else.
There was some really annoying rattle sounds coming from the stock exhaust under load on the freeway.
Strange, mine was nice. Maybe because I put on a 300 mile stock 2017 exhaust to replace my nasty 2013.
(Inside)
(outside)
Old 05-03-2020, 03:30 PM   #17
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
This is the problem with small sample sizes, there's no right or wrong answer. When piecing together exhaust systems piece by piece, you get too many different outcomes...
Old 05-03-2020, 03:46 PM   #18
mav1178
mav1178's Avatar
or some type of header system where the header/OP/front pipe was the same maker, and the catalytic converter + resonator are large units on the front pipe.
This way, you can run whatever exhaust you want.
Old 05-04-2020, 12:24 AM   #19
jflogerzi
jflogerzi's Avatar
I think you should look at a JDL resonated FP or HKS dual resonated. Should pair well with your current setup and give you a bit more volume without getting to loud
2013 Series 10 FRS #553
Old 05-05-2020, 10:49 AM   #20
kevaughan
kevaughan's Avatar
Drives: BMW E30, 2014 FR-S
Originally Posted by Ernest72 View Post
Just wait the Q300 will get louder over time, mine did. A little raspier too when on it. Not sure I love it with Windows open, windows closed cabin sounds good. Jdl uel catless header, jdl catted and resonated FP, stock overpipe.
My Q300 did the same thing! It's definitely louder and I would dare to say almost it's as loud as the R400 Gemini when I had it.
kevaughan is offline   Reply With Quote
Old 05-05-2020, 12:27 PM   #21
Ernest72
I know. Not that happy about it. Luckily I tuned out the cold start, otherwise waking the neighbors at 6:30am would not be good. I am not a young punk so I don’t want something ridiculous. Hopefully it stays where, it is. If it gets much louder I might have to do something. I would love to have someone repack it for me. Have not found who would do that at a reasonable cost.
Old 05-05-2020, 12:33 PM   #22
CSG Mike
CSG Mike's Avatar
I think the best refined aggression is factory exhaust with a catless header.
Have you ever heard how that sounds from outside? It rattles like an old civic with distasteful mods.
It's actually bad enough that folks in CA get pulled over for it.
NoHaveMSG (05-05-2020)
Old 05-05-2020, 12:44 PM   #23
DarkPira7e
DarkPira7e's Avatar
I swear to goodness mine didn't sound that bad. Maybe it helped that the header was CNT rather than expensive well thought out runner design, and UEL
Old 05-05-2020, 10:22 PM   #24
ItsReiko
ItsReiko's Avatar
Drives: 2017 subaru brz
Why does that happen? Starting to worry me because I just ordered a Tomei catless header.
ItsReiko is offline   Reply With Quote
Old 05-05-2020, 11:06 PM   #25
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
No primary cat and much thinner metal on the header pipes.
I can confirm, even my stock exhaust + JDL header, which uses thicker steel than most aftermarket headers, was raspy from the outside.
Old 05-05-2020, 11:20 PM   #26
CSG Mike
CSG Mike's Avatar
longer exhaust sound waves that the stock muffler wasn't designed to muffle, because the stock cat handles that. These longer waves then introduce vibration, which manifests as a nasty rattle.
Specifically, the sound is that of any old car with a very rattly or tinny exhaust.
The CSG Touring86 will eliminate this problem while maintaining a mature exhaust note.
tomm.brz (05-06-2020)
Old 05-05-2020, 11:30 PM   #27
ItsReiko
ItsReiko's Avatar
Am I right to assume that this rasp/rattle you guys are speaking of with an aftermarket catless header only happens if you are still on the stock catback? Or it will sound like that in general when you get a catless header?
I'm planning to install the Tomei EL header paired to a Perrin 2.5in resonated catback.
Old 05-05-2020, 11:57 PM   #28
CSG Mike
CSG Mike's Avatar
We're referring to the stock catback. The Perrin won't rattle.
CSG Touring86 Competition Catback Exhaust NEW - Track-ready, mature exhaust note ajcarson11 Engine, Exhaust, Bolt-Ons 3 04-29-2018 07:21 PM
Exhaust note changed GsxrMe Forced Induction 3 04-30-2016 11:25 AM
exhaust note, what are the factors? BRZPDX Engine, Exhaust, Transmission 6 01-04-2014 09:04 PM
Name that exhaust note Rampage BRZ Photos, Videos, Wallpapers, Gallery Forum 1 04-14-2012 05:52 AM
