Old 04-30-2016, 10:05 AM   #1
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Exhaust note changed
Car developed a rumble. No knocking, no ticks but it sounds like almost like an UEL header.
All the exhaust clamps at clean.
No boost creeping
No check engine lights
Knock test passed all the way to redline.
I'm expecting to find a bent rod.
Any suggestions?
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 04-30-2016, 10:57 AM   #2
jerbull
Drives: 2013 FRS Asphalt
Compression test might shed some light.
jerbull is offline   Reply With Quote
Old 04-30-2016, 11:04 AM   #3
You may be down a cylinder... AFR?
Old 04-30-2016, 11:25 AM   #4
GsxrMe
GsxrMe's Avatar
I'll hook up my cable and log it tonight.
My failsafe reports a steddy 13.8 at harm idle. I see it at 11 WOT. Haven't had or seen any boost creep other than a spike to 7.8 but I'm thinking my evap is boosting my gas tank. I kinda want to delete my evap.
2014 Subaru BRZ
How to get that raw drift car exhaust note? FR-S89 Engine, Exhaust, Transmission 3 09-25-2014 02:33 PM
Has anyone changed a mid pipe and kept stock exhaust? jflogerzi Engine, Exhaust, Transmission 14 03-08-2014 02:14 AM
exhaust note, what are the factors? BRZPDX Engine, Exhaust, Transmission 6 01-04-2014 09:04 PM
Name that exhaust note Rampage BRZ Photos, Videos, Wallpapers, Gallery Forum 1 04-14-2012 05:52 AM
