Old 05-03-2020, 01:24 AM   #1
toughguy39
toughguy39's Avatar
Drives: WRB Turbo Brz
Header and Overpipe stripped bolt
So I bought UEL headers and was planning on getting them installed today when the worst thing happened... one of the bolts from the headers to the overpipe stripped even after using PB blaster. So I bought an overpipe after doing some research and plan to install that along with the headers. Just wanted to make sure but will there be enough room with both shields off to pull the overpipe along with the headers out? If not what would be the best option to get this bolt out? Thanks in advance.
toughguy39 is offline   Reply With Quote
Old 05-03-2020, 01:28 AM   #2
Gloonge
Drives: 2013 frs raven
I don't think you can get the over pipe out without rotating it like 90 degrees.
So you are going to either have to beat a smaller socket onto that nut and then rip it off with an impact gun (this requires that the socket be sacrificed), Or get in there with a grinder and cut that bad boy off of there.
Gloonge is offline   Reply With Quote
Old 05-03-2020, 01:32 AM   #3
toughguy39
toughguy39's Avatar
Yep, there's nothing to except the threads that are stuck haha, soooo yeah, I don't have a grinder, might need to get one for this.
Old 05-03-2020, 01:46 AM   #4
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Just unbolt your motor mounts and jack it up. Then you should be able to slip it out.
MS, CSCS, TSAC-F, CPT
Old 05-03-2020, 03:53 AM   #5
86TOYO2k17
Drives: 2017 toyota 86
Vice grip pliers.
Old 05-03-2020, 10:04 AM   #6
Gloonge
This guy has the easiest solution. Had not though of that, you can easily get 2 inches of clearance or better and everything should aide out whole.
Old 05-03-2020, 10:45 AM   #7
ls1ac
ls1ac's Avatar
Is the nut turning and not coming off? You can use a nut cracker to split the nut off or very carful use of a grinder. Then remove the pipe and then blast the stud, and remove with stud remover or perhaps Vice grips.
Do you mean that the nut sheered off the stud? Remove the pipe.
Then PB blast the stud that is exposed and then stud remover or try a vice grip. If it breaks at the casting then you will have to drill and re-tap.
Maybe time for a pro.
edit: Should mention that a pro may put a nut on the shaft then weld the nut to the stud to remove. So many ifs.
Old 05-03-2020, 10:45 AM   #8
Ernest72
Be t
Agree do this. Just did it to get to the rear drivers side spark plug. So easy. The others I did with out jacking. Next time I jack the engine, it took 7 min maybe to take lower cover off and jack it up. I prefer ramps rather than jack stands as you can lift the whole car a little in the beginning. Just safer on ramps IMHO.
Old 05-03-2020, 12:04 PM   #9
toughguy39
toughguy39's Avatar
So, there is a stud that is stuck between the overpipe and the headers. I didn't have a great camera but this is what it looks like if you can look closely
[IMG] https://drive.google.com/file/d/1u2t...ew?usp=sharing [/IMG]
Old 05-03-2020, 12:12 PM   #10
toughguy39
toughguy39's Avatar
That's what I'm hoping to do just not sure if ill be able to take that out along with the headers attached.
Old 05-03-2020, 03:53 PM   #11
ls1ac
ls1ac's Avatar
Yes, it looks like the nut froze and twisted the end off of the stud. When you get them apart then see above for removal.
edit: If getting it off becomes impossible with the broken stud stuck in the flange, you could use a hacksaw blade to cut the stud. NOT recommended because you might scar the flanges and have leaks and it will require drilling and using easy-out or retapping.
Old 05-12-2020, 04:40 PM   #12
InstaGib
Drives: 2015 Scion FR-S || Raven Black
I had almost the exact same thing happen. I was able to get a grinder in and just grind the hell out of it until it came apart. I only nicked the flange a little, should be able to press a new stud in and get it back together if I ever decide to go back.
It sucked. It was late, I needed the car to get to work on Monday (this was a Saturday night), and I was frustrated. I swore I would never tear apart my daily driver again. But since then, I've enjoyed the car immensely. Putting the headers on was the best thing I ever did to it. Good luck, whatever you manage to work out.
InstaGib is offline   Reply With Quote
headers, overpipe
How to remove seat rail bolt after you've stripped it protpibe DIY (Do-It-Yourself) Guides 33 02-01-2020 03:06 PM
Rear bolt stabilizer stripped Trueweltall Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 07-15-2018 01:51 AM
Stripped Wheel Bolt Flame9020 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 03-09-2018 11:09 PM
HELP: O2 bung on Rev Works header stripped? btoast Engine, Exhaust, Transmission 9 12-21-2014 07:11 AM
Wheel bolt stripped 2pointSLOW86 Issues | Warranty | Recalls / TSB 23 10-13-2014 03:29 AM
