| BRZ First-Gen (2012+) General Topics All discussions about the first-gen Subaru BRZ coupe |
#43 |
ProCrastinationConsultant
| The Following User Says Thank You to soundman98 For This Useful Post: | p1l0t (04-09-2020) |
#44 | |
Drives: '17 BRZ / CBS + PP
These cars LOVE 2500rpm... that's the start of the first torque mountain, so you know the car is at it's most efficient. To those saying not to floor it under 3k, you're missing the second best part of the power band. To the OP, use your ears and but dyno, and you'll hear/feel the best shift points based on your intended acceleration. For me, puttering around town I'll usually grab second by 10mph, third by 20, 4th by 30, 5th by 40, and 6th at 55 or so. This is with the 2017 FD. If I want to rip it, it's near redline. If you want something in the middle, I usually skip the extra revs and just give it more gas thru that first torque plateau. Still shifting no later than 3500, because if you do you'll miss that 2500rpm sweet spot. You'll be faster if you stay on the low end cam versus riding the valley. And the car just sounds right when it's on cam like that. I'm of the mind that this motor is a little gem. People complain about the dip really they've given us two torque mountains. One for puttering around (2500rpm-3500rpm), and one for ripping it (~4.5k to 6.5k+). There's a huge tuning and aftermarket modding industry drive to flatten that dip, when it's supposed to be there in the first place. This is how the motor was designed. And who is pulling through 4k anyway? If accelerating hard my tach never sees below 4k. Maybe for a split second while the wheels catch traction at launch, but that's it. I personally would rather have the low end available to me. I've driven Hondas that only have one portion of the rev band on cam... VTECYO!, and they feel sure lifeless before that surge. OK, /end torqudip rant
#45 |
Drives: 2020 BRZ tS
Thanks for your tip, guys. Now, I'm done with a break-in stage (strictly by the manual) and did the first oil change at the dealership. I asked them to change transmission and rear differential oils, but they said those should be done at 10000 miles or so and were not done at that time. They put Mobile1 5w30, not 0W20 as the manual goes. Is the engine alright with 5W30?
Now, returning to my original question on engine speed, my concern is if I'm lugging the engine at a low 2000 rpm, or I should shift down by one gear to run at a high 2000 rpm at the same speed of the car. Say, at 50 mph, 5th gear gives 2700 rpm, and 6th gear gives 2100 rpm. which gear would you use? I've been driving nothing but pickup trucks and SUVs equipped with a V8 motor for the past 3 decades, and I'm so used to 1000 to 2000 rpm range. nothing matters with a V8 motor so long as I put fresh 5W30 oil at every 5000 miles. Meanwhile, I'll stay close to 3000 rpm with my BRZ. |
#46 | |
Pavement Grey
Unlike a V8 a 4banger does not have alot of torque available at all times. Especially a N/A 4 banger of relatively small displacement, the FA20 was designed for high revs so all its power is really located high up in the rev range (5000-7400 RPM). Even high revving V8's have gobs of torque available at the low end if if most of their power is located high. Theres no replacement for displacement, although turbos help alleviate this dificiency 5W30 or 0W30 doesnt really matter all that much. I think 0W30 was formulated to help in winter conditions where the oil can get really thick due to the cold (im not 100% sure, i just know that 5W30 was the norm for a really long time before 0W30 came along...i kind of forgot what 5W30 means) |
#47 | |
I agree to an extent. And there's definitely no replacement for displacement, but I think the FA was not designed specifically for high revs, but rather a compromise between high and low end torque. High revs only, ala Honda S2000 ![]() And our curve, for those who don't have it on the gauge cluster: ![]() 2.5 to 3.3 krpms... This small 4cyl NA motor definitely has some low end grunt! Ok, so grunt might be the wrong word for it
#48 |
Do these new cars still have the shift light? If you do not put your foot to the floor the light gives a good indication of shift points.
#49 |
Drives: 2016 Subaru BRZ Limited Ice Silver
The shift light is programmable, if you're talking about the red blinking one on the tach.. I've moved mine up as i've gotten better at driving stick, as the BRZ is my first MT car
![]() I usually do : 1 -> 2 at 20 mph 2 -> 3 at 30 mph 3 -> 4 at 45 mph 4 -> 5 at 55 mph and only use 6th above 65 mph. |
#50 |
Drives: 2013 FR-S Series 10
Seems pretty excessive for puttering around town. You can get out of first gear at 10mph with zero danger of lugging.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
#51 | |
Sent from my SM-G975U using Tapatalk |
#52 | |
Drives: Q5 + BRZ + M796
@p1l0t I'm not really sure what you mean when you say long power curves. EJ's have always been oversquare like the S2000, but they don't rev high for many reasons. That design was probably to reduce the width of the motor to aid in servicing and to give more room for suspension geometry. Did you mean they have a broad torque curve? In like 2006 the WRX moved from the EJ20 to the EJ25, so the extra displacement provided some low end torque and got the turbo moving faster, but the top end really falls off, even on the STI.
#53 |
My STi pretty constant from like 3k to 6k...
![]() Sent from my SM-G975U using Tapatalk |
#54 |
The original shift light was RPM, speed and throttle position related. I think it was an up pointing arrow. And could be turned on and off. The red line light was adjustable.
Been years since I thought I saw it. I turned if off right away, it kept pointing up and I still had several grand to red line. |
#55 | |
The Dictater
Drives: '13 Red Scion FRS
#56 |
Drives: 2020 BRZ Limited PP
Yeah. My 2020 has a little shift arrow that can be turned on. Its for slow pokin, maximizing mpg, and probably other things that are unholy for this car. Im surprised Subaru bothered with them.
| 2014 frs 6 speed manual 22k | Ruzbrz | Canada Classifieds | 2 | 11-07-2016 12:17 PM |
| WTB Longblock or whole motor (manual 6-speed) | Synack | Want-To-Buy Requests | 0 | 07-07-2015 02:46 PM |
| Thoughts on a 7 speed manual? | dem00n | Other Vehicles & General Automotive Discussions | 22 | 01-20-2014 01:12 PM |
