Old 03-31-2020, 04:16 PM   #1
DaPistonHead
Drives: 2020 BRZ tS
6 speed manual and speed levels
Hello,
I got a new 2020 BRZ just recently and want to get the right speed for each gear. The car has 600 miles on the odometer now. For easy city driving (still breaking in), I'm doing the following:
gear speed (mph)
1 0 to 5
2 5 to 15
3 15 to 25
4 25 to 35
5 35 to 45
6 above 45
Does it sound right? Any input appreciated. Thanks.
DaPistonHead is offline   Reply With Quote
Old 03-31-2020, 04:19 PM   #2
Milhouse86
Noob
Milhouse86's Avatar
Drives: 13' FRS, 13' F150, 17' A4, 69' 442
Short shifting way too much imo
Sent from my Pixel 4 XL using Tapatalk
-2013 FRS/Black (Motor Blown/Under Construction)
http://www.ft86club.com/forums/showthread.php?t=135599
-1979 Trans AM/Black (Sold) -1969 Olds 442/Orange with white racing stripes - 2017 Audi A4/Black
Milhouse86 is offline   Reply With Quote
The Following 4 Users Say Thank You to Milhouse86 For This Useful Post:
DarkPira7e (03-31-2020), NoHaveMSG (03-31-2020), Pat (03-31-2020), strat61caster (04-09-2020)
Old 03-31-2020, 04:29 PM   #3
There is no "right speed for each gear" really. Just keep her under the 4K rev mark until done the break in. In fact the break in says to vary the speed and revs during that period so you want to stay away from fixed patterns not enforce them. Don't worry about what speed you are doing since it could vary considerably depending on the circumstances.
JCC (04-09-2020), jcw99 (04-08-2020), Spuds (03-31-2020)
Old 03-31-2020, 04:32 PM   #4
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
My opinion:
Don't drive in a gear at less than 1700rpm. That's not great for the engine. I personally try to keep it over 2krpm. At low rpm the flywheel isn't providing enough inertia to keep the engine running smoothly, which means you are gonna get strange forces and vibrations. At the same time you have low oil pressure so that's not good for your bearings.
Until you finish the break-in, don't go over 4krpm or whatever it is the manual says. After break-in, go as high as you want, it will probably be fine unless you money shift.
So basically increase your speeds in each gear by about 5-10mph lower gears, and 10-15mph in higher gears
The Following User Says Thank You to Spuds For This Useful Post:
Tcoat (03-31-2020)
Old 03-31-2020, 04:43 PM   #5
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
My opinion:
This is nice and safe advice. You'll also notice that if you do find yourself in low rpms, pressing the gas hard will make the engine vibrate badly. This is called lugging the motor and bad for the bottom end. When in doubt, downshift a gear.
Generally I never apply heavy throttle under 3k. Gently accelerating between ~1700 and 3000 is fine.
Feel and listen to the engine, it will let you know when it isn't happy.
The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post:
JohnJuan (04-08-2020), NoHaveMSG (03-31-2020), Spuds (03-31-2020)
Old 03-31-2020, 04:46 PM   #6
My opinion:
Although many will say "just drive the crap out of it from the start it is good for it" I have always been a follow the break in procedure guy.
I am having a hard time with it this time around though since the car is so much the same as the FRS I sometimes forget it is new! Have to actually pay attention to the revs and not just throw it on cruise for my 45 minutes commute.
Spuds (03-31-2020)
Old 03-31-2020, 04:58 PM   #7
soundman98
ProCrastinationConsultant
soundman98's Avatar
i've had 2 brz's. the first i had for 4 months, then someone totaled it by ignoring their stop sign. it was at 3k miles..
on the first, i followed break-in procedure. it was an agonizing thousand miles.
the second, i pretended i did it already. i left the dealer sideways through first, and chirped second just in case.
outside of first gear, i try to not let the revs go below 2000. i generally hover around 3000 the majority of the time though. and it see's redline at least once every time it leaves the garage. it's a mechanical device. and mechanical devices are built to serve a purpose. my cars purpose is to be fun!
ENJOY YOUR NEW CAR!!
Spuds (03-31-2020)
Old 03-31-2020, 05:02 PM   #8
Yoshoobaroo
TRACKBREAD
Also DON'T REDLINE WHEN THE OIL IS UNDER 170F
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Spuds (03-31-2020)
Old 03-31-2020, 05:06 PM   #9
Spuds
The Dictater
Spuds's Avatar
Oh easy solution to get through it quickly, just go on a road... trip... Nevermind.
When I got mine I went back to NY for a weekend varying my speed in 6th, probably drove a bunch of people crazy. But it spun off the last few hundred miles pretty quick lol.
soundman98 (03-31-2020)
Old 03-31-2020, 05:07 PM   #10
Milhouse86
Noob
Milhouse86's Avatar
I am pretty sure the manual says you should redline daily to preserve the integrity of the motor. I know I do
The Following 2 Users Say Thank You to Milhouse86 For This Useful Post:
soundman98 (03-31-2020), ToySub1946 (04-01-2020)
Old 03-31-2020, 05:08 PM   #11
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
yep...below 4k the first 1000 US miles. check your oil level properly and frequently as consumption is more during this period.
thomasmryan is offline   Reply With Quote
Old 03-31-2020, 05:17 PM   #12
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Isn't the entire break-in procedure outlined in the owners manual?
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
JohnJuan (04-08-2020), Mr.ac (04-01-2020), soundman98 (03-31-2020)
Old 03-31-2020, 05:26 PM   #13
Originally Posted by Milhouse86 View Post
I am pretty sure the manual says you should redline daily to preserve the integrity of the motor. I know I DID
FIFY
https://www.ft86club.com/forums/show...74#post3314974
Milhouse86 (03-31-2020), Spuds (03-31-2020), Ultramaroon (04-01-2020)
Old 03-31-2020, 05:27 PM   #14
Yes
2014 frs 6 speed manual 22k Ruzbrz Canada Classifieds 2 11-07-2016 11:17 AM
WTB Longblock or whole motor (manual 6-speed) Synack Want-To-Buy Requests 0 07-07-2015 01:46 PM
Thoughts on a 7 speed manual? dem00n Other Vehicles & General Automotive Discussions 22 01-20-2014 12:12 PM
