go_a_way1, MisterSheep
Old 04-28-2020, 02:56 PM   #21771
Originally Posted by Vital View Post
Oh yep thats very true didnt even think about that. See we are spoiled we normally dont really have to deal with that...
You would be shocked!
RToyo86 (04-28-2020), Vital (04-28-2020)
Old 04-28-2020, 03:01 PM   #21772
JD001
JD001's Avatar
Drives: Subaru BRZ
The engine bay and content just back from a tour of Afghanistan?
The Following User Says Thank You to JD001 For This Useful Post:
Old 04-28-2020, 04:55 PM   #21773
That is just a winters worth of dust from road salt and sand.
JD001 (04-29-2020)
Old 04-28-2020, 05:36 PM   #21774
Ashikabi
Ashikabi's Avatar
Pictures showed up side by side on my screen. I knew it was two different pics but still thought "why would he make that front splitter with a right angle like that" when I first looked.
Thanks tapatalk
Sent from my ONEPLUS A5010 using Tapatalk
Old 04-28-2020, 06:51 PM   #21775
saltywetman
Drives: 2020 Toyota 86 GT 6M
Just got a call from dealership today, eagle finally landed. The journey begins!
Hopefully will be ready for pickup tomorrow. Was told due to reduced staffing they still need to perform PDI and check to see if they have parts available for my optional accessory installs
saltywetman is offline   Reply With Quote
The Following 10 Users Say Thank You to saltywetman For This Useful Post:
beltax90 (04-28-2020), Dadhawk (04-28-2020), DarkPira7e (04-30-2020), humfrz (05-02-2020), jflogerzi (05-02-2020), MJones_RB (04-29-2020), mrg666 (05-02-2020), RToyo86 (04-28-2020), Stephen W. (04-29-2020), The Red One (04-29-2020)
Old 04-28-2020, 09:38 PM   #21776
Contender
Drives: 2017 Toyota 86
Changed oil to Mobile 1 5-20 and removed my rear sway bar also adjusted front camber to -3 and removed about 13lbs off the front with a lawn and garden battery best 50 bucks spent.
Contender is offline   Reply With Quote
Old 04-28-2020, 10:46 PM   #21777
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Bit of a preview on the wheel color, I decided to paint the barrels on my wheels first.
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
Old 04-29-2020, 02:58 PM   #21778
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
After installing some Whiteline sway bars and endlinks, a neat new clunking sound is coming from my suspension. It seems to be happening in the rear, mostly at low speeds on uneven pavement. I lifted it up and checked all the torques and bolts, made sure the sway bar wasn't contacting anything, greased up whatever I could, no luck. Comes and goes, most people just live with it I've read. Will have to check to see if the coilover is seated correctly. Sigh...
MJones_RB is offline   Reply With Quote
Old 04-29-2020, 04:26 PM   #21779
Ashikabi
Ashikabi's Avatar
Disconnect end links and loosen swaybar bushings. Set the car on the ground, full weight. Then tighten everything. Clunk will be gone. Your swaybar is binding
The Following 2 Users Say Thank You to Ashikabi For This Useful Post:
MJones_RB (04-30-2020), tarzan_nojane (04-29-2020)
Old 04-29-2020, 08:13 PM   #21780
arxm
Drives: 2013 FR-S, 2023 BRZ
Originally Posted by DarkPira7e View Post
For what it's worth, the only thing holding my bumper on are the sidemarker clips ( no bolts) and the bolts in the engine bay that cover the radiator support. It has held on that way for 2 years and while it did get detached during a snowstorm (see a few pages back) it clipped back on with no damage that I could see. Embrace the ability to quickly yank the bumper on/off!
haha thats good to know, idk i just feel sketched out plus i hate the gap, i found this writeup (https://www.ft86club.com/forums/showthread.php?t=95624) it seems fairly easy and buying the releases on its own is cheaper than the move over racing ones by a huge margin so if i get bored enough i might just pick it up for the time being ill probably leave it alone or try and secure it to the splitter (which i might also remove to be honest)
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 04-30-2020, 01:31 PM   #21781
RToyo86
RToyo86's Avatar
Ordered gorilla 45128bc forged steel lugs.
Edit: did some calculations, also ordered APR extended studs and 10mm spacer.
Old 04-30-2020, 02:31 PM   #21782
MJones_RB
MJones_RB's Avatar
Thanks! Will do that this weekend!
Old 05-02-2020, 09:54 AM   #21783
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Washed it. My water softener setup works great. It takes my hard well water from 285 ppm to 2 ppm.
humfrz (05-02-2020), Kaotic Lazagna (05-02-2020)
Old 05-02-2020, 11:12 AM   #21784
squall leonhart
kuro kitsune
Drives: 2002 Toyota Celica GT-S
I'd really like to get a softener setup like that. I have a filter on the garden hose, that's about it. It helped a little, but still have crazy water spots anywhere that I don't get dry within 2 seconds of washing.
Starting to think I'd be better off going to Crew Car Wash or something. :/
As for what I did to my FR-S today, it's not quite finished, but I'm installing my OEM fog light kit...only been sitting in the box in the garage for a year and a half or so.
'02 Celica GT-S, '88 Celica All-Trac
'13 Scion FR-S (sold)
squall leonhart is offline   Reply With Quote
The Following User Says Thank You to squall leonhart For This Useful Post:
humfrz (05-02-2020)
