View Poll Results: How many 86 owners are planning on getting the Supra?
I'm definitely getting one 32 12.12%
I might get one if they offer a MT 100 37.88%
No, not me. 132 50.00%
Voters: 264. You may not vote on this poll
Old 04-28-2020, 12:00 PM   #2311
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
So, in the end, until he gets in something that is probably fighting above a base C8 class stock car, the review would be the same? Pretty meaningless then if he can't review it in context, in my opinion.
I was making an assumption that he was implying it couldn't be made better than what it was, particularly since he was talking about it against a tuned car. Guess I was giving him the benefit of the doubt, which apparently wasn't deserved.
Yeah... but again, a lot of older JDM Tuners are like that. Just can't review it in context. Maybe he haven't seen Papadakis' 1000whp Formula D Supra yet.
But when R35 was released, he stated, R35 was crap too. Who knows, he might change his mind lol
Dadhawk (04-28-2020)
Old 04-28-2020, 01:56 PM   #2312
gymratter
Drives: BMW
Updated 2021 Toyota GR Supra Reaches Japan With Two Special Limited Editions
https://www.supramkv.com/threads/upd...editions.5172/
gymratter is offline   Reply With Quote
Old 04-28-2020, 01:57 PM   #2313
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
with 8 piston calipers w ceramic brake & full custom e-suspension Nismo GTR. Of course, stock Supra is slow and doesn't stop or doesn't turn. It's like comparing 86 w 1st gen Geo Metro.
Brakes don't stop cars, the tires do. Sounds like his complaint is 75% about the tires.
The biggest problems I've seen from the Zupra is the suspension, seems like they didn't quite get the springs/dampers right on the longitudinal control and the car is both boat-like in responsiveness and twitchy. Looks like a frustrating package to hustle.
ineedyourdiddly
Old 04-28-2020, 04:16 PM   #2314
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Both are part of the system and one will not work well without the other being up to par.
shiumai is offline   Reply With Quote
The Following User Says Thank You to shiumai For This Useful Post:
Tcoat (04-28-2020)
Old 04-28-2020, 07:18 PM   #2315
strat61caster
Right and the factory brakes on the Zupra are easily far and away more capable than the tires.
If the abs can be engaged consistently over the entire use period it means it's not the clampers failing you, it's the tire.
ineedyourdiddly
Tcoat (04-28-2020)
Old 04-29-2020, 02:07 PM   #2316
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
I think the Supra looks much better in person. In photos it looks narrow to me, not sure why. In person, looks wider. Makes the whole design much better.
The Following 3 Users Say Thank You to WolfpackS2k For This Useful Post:
BA9092 (04-29-2020), mn_ca (04-29-2020), StraightOuttaCanadaEh (04-29-2020)
Old 04-29-2020, 02:21 PM   #2317
WolfpackS2k
Thumbs up
*raises hand*
I don't understand this.
I thought electronic "diffs" used the rear brakes. Cars already have rear brakes. How can a mechanical lsd, which has more parts than a conventional diff, be lighter than an electronic diff?
Originally Posted by DM7 View Post
Electronic limited slip differentials are computer controlled variable slip differentials. It can theoretically go from completely open to completely locked as needed. It varies the speed difference between the wheels based on sensor data from the car. Compared to conventional limited slip differentials; electronic limited slip differentials have computers, solenoids, hydraulic components and cooling systems.
Brake vectoring systems use the brakes to limit the speed difference between wheels.
Torque vectoring systems can feature one or both systems mentioned above.
Bingo! Well Said.
Captain Snooze, much like anything else, you need to read the fine print. If any vehicle is described as having a brake based electronic LSD, you can interpret that as being crap, and the cheapest possible way to control wheelspin via a differential. It's better than nothing, but not by much. Other advantage is it doesn't add any weight (since it just requires a computer and uses the existing brake hardware).
This is the LSD type most base level VWs have, including the GTI (heck even my 2015 Golf wagon had it). However, the GTI I have now has an active torque vectoring LSD that can overdrive the outside wheel to rotate the vehicle into a turn. These cost a lot more, and unfortunately add weight.
The Following User Says Thank You to WolfpackS2k For This Useful Post:
Captain Snooze (04-29-2020)
Old 04-29-2020, 02:35 PM   #2318
BA9092
Captain Slow
BA9092's Avatar
Drives: '18 BRZ Limited PP 6MT ISM
Originally Posted by PulsarBeeerz View Post
I completely agree. I would still love a 220hp D4S 2.4L but I really doubt that will happen.
That's so sad...
BA9092 is offline   Reply With Quote
Old 04-29-2020, 07:20 PM   #2319
mn_ca
Drives: 2013 frs, 2005 is300
Didnt like it in photos but in person it was beautiful. Saw the C8 and still still have no regrets!
mn_ca is offline   Reply With Quote
Old 04-29-2020, 08:07 PM   #2320
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Mmmm... I'm not sure McLaren would agree with you.
"The new McLaren 720S Spider isn’t exactly wanting for power. Just like the coupe, its 4.0-litre twin-turbo V8 is good for 710bhp (or 720PS, hence the car’s name). But here’s something you may not know: all of that power is sent to the rear wheels via an open differential.
It’s the same case with McLaren Automotive’s entire line-up, plus all of its previous vehicles. Yep, even the mighty P1 used an open diff."
https://www.carthrottle.com/post/why...t-wont-change/
Old 04-29-2020, 08:47 PM   #2321
soundman98
ProCrastinationConsultant
soundman98's Avatar
#trade-off's.
for a race track, i can understand how it makes sense. but for the street, the speeds are too low to really benefit from the system the same.
and i also think that a mechanical LSD is more easily used by a lesser skilled driver (like me), where a brake-based system requires a better driver technique to get a net benefit out of them.
Old 04-29-2020, 09:12 PM   #2322
Lantanafrs2
Drives: 2013 frs red
I wouldn't want more than 250 whp out of a turbo 2litre. Reliability will suffer.
Lantanafrs2 is online now   Reply With Quote
Old 04-29-2020, 09:58 PM   #2323
BA9092
Captain Slow
BA9092's Avatar
That depends on the manufacturer.
The 2.0 TSI EA888 Gen3 engines found in the Audi TTS, S3 and Golf R are rated at 292hp and 280tq with 91 octane and were pretty reliable.
I met a handful of guys when I had my GTI who were running stage 2 (intake, downpipe and intercooler upgrades) and were putting out an average of 400hp/400tq...on the stock turbo with no problems for tens of thousand of miles.
Old 04-29-2020, 10:01 PM   #2324
nashcarr
Drives: 2020 BRZ tS 247/300, 1995 Miata
I had a 2010 Sti purchased brand new and then at 25K miles added Cobb Accessport, a 1 cat Downpipe and full 3" Borla exhaust. Sold it at 90K miles and I NEVER had anything go wrong. NEVER.
nashcarr is offline   Reply With Quote
2020 Toyota 86??? Twin-Dragons Scion FR-S / Toyota 86 GT86 General Forum 225 01-02-2019 12:33 PM
Official: Nissan Concept 2020 Vision Gran Turismo revealed, hints future R36 GT-R vh_supra26 Other Vehicles & General Automotive Discussions 42 01-17-2016 02:28 AM
Nissan 2020 vs Toyota FT-1 vs Acura NSX vh_supra26 Other Vehicles & General Automotive Discussions 35 07-08-2014 05:15 PM
Modellista Toyota 86 Revealed quik1987 Scion FR-S / Toyota 86 GT86 General Forum 385 12-04-2011 04:51 PM
Breaking! Toyota FT-86 II revealed? A-Spike Scion FR-S / Toyota 86 GT86 General Forum 40 02-13-2011 06:16 PM
