Drives: 13' Toyota GT86
Cusco Rear LCA
Hoping someone here can help, I have tried searching but failed to find anything.
I have some Cusco rear LCA's installed and after a few years the pillow ball's have worn enough that there's some play. Does anyone know the correct size of pillow ball's for the Cusco arms? |
#2 |
![]() Sent from my SM-G975U using Tapatalk |
#3 |
Drives: '13 FRS - STX
I'd contact the UK Cusco dealer, coordsport first, then Cusco USA second, or maybe CSG can get you specs/replacements.
https://www.cusco.co.jp/en/distributor/ |
#4 |
I would contact Cusco UK.
But you can also measure what you have. Detailed dimensions are all available on the rod end sites so you can compare fairly easily. Or see if a place like www.mcgillmotorsport.com can help you (no personal experience, there are plenty of other options in the UK). I have a set off the car, but they're in storage and not at my house. When the time comes I'll measure and replace them on my own. EDIT: sorry, one note is that the rubber boots will be absolute misery to get off without a special tool. that would make things a little more complicated. - Andrew |
#5 |
Thanks @Strat61 and racecomp. I have emailed Cusco, but not heard backs thought I'd ask here incase anyone has had to change them already.
As racecomp mentioned the rubber boot will make it a pain to measure without stripping off the car. Will see if coordsport can help. |
#6 |
Got a reply from Cusco JP, they use HRT18E NMB end's for anyone else that might need some.
http://bearingsize.info/catalogue-on...obj143330.html |
| FS: Cusco Subframe Collars, Cusco Rear Differential Collars (Front and Rear). | FRSH86 | Transmission and Driveline | 0 | 04-19-2020 01:36 AM |
| <FS> Perrin 25mm rear sway, Radium front strut, Cusco rear strut bar | mav1178 | Brakes, Suspension, Chassis | 2 | 07-21-2016 06:49 PM |
| FS: Cusco Power Brace Front, Rear, Rear-side Member and Engine Room | fungus | Canada Classifieds | 2 | 05-20-2016 12:36 PM |
| Cusco Engine Mounts and Cusco Rear Diff Brace - Stiffen up your BRZ/FR-S!!! | RallySport Direct | Transmission and Driveline | 10 | 03-12-2013 03:11 PM |
| Cusco Rear Diff Covers!!! Cusco LSD Units! | vividracing | Transmission and Driveline | 0 | 06-18-2012 04:24 PM |
