Old 04-26-2020, 10:56 PM   #1
dholloway543
Software Hobbiest
Drives: 2015 FRS
2 Quick Questions
1. Is the Evap and the Charcoal purge canister the same connector or are they 2 different connectors.
2. Is ECUTEK racerom free, Can I just buy the cable and the license because it seems like it is but ft86speedfactory.com has an option for racerom here https://www.ft86speedfactory.com/ecu...l#.XqZJocBlBPY
So could I spend $600 on the kit instead of the $1000
dholloway543 is offline   Reply With Quote
Old 04-27-2020, 04:17 AM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
1. Don't know about the EVAP system.
2. Sort of. You only need the RaceROM Upgrade if you plan on building your own tunes. The standard ProECU license allows you to load RaceROM enabled tunes onto the car
  • If you buy the Ecutek Tuning Package, you get a license to access the ProECU Software, plus the ProECU BRZ features, which has a few basic RaceROM options enabled (more of a flavor than the full suite). See this link: https://www.ecutek.com/Products/Reta...res/ProECU-BRZ
EndlessAzure is online now   Reply With Quote
Old 04-27-2020, 04:44 AM   #3
tomm.brz
Drives: brz 2017 hksv2
you only need extra racerom license if you do tune by yourself
if you need help, and want to save money on the racerom license,i do have it
the carbon canister system, when deleted, offers you 1 auxiliary input and 1 output
You use inputs for sensors but you will use that free output to command a wastegate for your turbo
You'll need racerom license to tune that by yourself
Old 04-27-2020, 08:42 AM   #4
dholloway543
Software Hobbiest
Drives: 2015 FRS
The reason i ask about that sensor cable is because I have the flex fuel sensor wired to the evap on the connector block under the passenger side dash. I also have my electronic boost control is wired to the cpc behind the intake. I just realized that might actually be the same circuit.
Thank you for the replies on ECUTEK RaceRom
Old 04-27-2020, 02:21 PM   #5
dholloway543
Software Hobbiest
Drives: 2015 FRS
NVM it just dawned on me that they are different systems because the Flex fuel sensor outputs a steady voltage 1-5V for the E content and the CPC valve is set to a steady 5V pwm output with a duty cycle. Therefore they have to be different systems
The Cpc it technically considered an output as well
where as the EVAP is concidered an input
Old 04-28-2020, 06:53 AM   #6
steve99
Drives: FT86
ecutek has built in boost control , flex and more but to access that stuff you will need the racerom extension software . The base ecutek kit only allows nasic access to rom ie all the standard tables, but none of the fancy ecutek stuff you need for boost flex speed density closed loop fuel control.
the CPC os set up to purge charcol canister, it will take a lot of code rewriting to make it into boost control system , especially with feedback to map sensor and to disavle the current function and dtc codes
A few quick TPMS questions Keenercarguy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 03-01-2017 09:18 AM
Quick questions about OFT FR-Slide Software Tuning 13 11-28-2015 09:09 AM
About to buy, quick questions DigitalVeil92 Scion FR-S / Toyota 86 GT86 General Forum 22 08-10-2015 12:10 AM
Few quick BeSpoke questions NOMNOM Electronics | Audio | NAV | Infotainment 0 04-17-2013 01:39 AM
Few quick set up questions Im_SPEED Tracking / Autocross / HPDE / Drifting 14 08-23-2012 03:28 PM
