Old 03-20-2020, 10:54 AM   #169
Drivers meetings aren't very socially distant. Neither is the group drinking after the day is done.
I also suspect the EMS guys could better spend their time transporting the elderly than sitting around at a track - especially in Sebring which at one time had the oldest population of any city in the US. (might still - haven't checked in 5 or 6 years)
I personally think it's a bit silly also but whatever helps flatten the curve I suppose.
Drivers meeting can be held with proper spacing or even electronicky (i.e. Skype). The group drinking is not directly related to nor a part of the sport even if it could be the most fun part to some.
If things reach a point where ever single EMT is spending every working minute transporting elderly people to medical attention then the shit has truly hit the fan and Florida will be an empty wasteland in a week so you can just track on the streets.
I didn't say it was a great idea just that as far as social distancing goes then tracking would be one of the best sports.
Opie (11-05-2020)
Old 03-20-2020, 02:16 PM   #170
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Track should setup a key card and transponder system. Key card would keep you off track until your proper run group, transponder would tell them if & where you had an issue. Less manpower....
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 04-13-2020, 10:10 AM   #171
Opie
Opie's Avatar
Lightened the car by a little more than 30lbs on Saturday. Removed the following unnecessary parts:
Driver & Passenger Side Curtain Airbags, Passenger Dash Airbag, Airbag Controller (Computer), Both Front Seat belts, Headliner, Antenna Wiring harness, Dome light wiring harness, A-Pillar trim, B-pillar trim, C-pillar trim, Dome light, Bluetooth mic, Headunit, GPS antenna & bracket, 8 Speakers, Amplifier and several miscellaneous brackets.
Car should be down under 2,700lbs now.
The Following User Says Thank You to Opie For This Useful Post:
SuperTom (04-17-2020)
Old 04-19-2020, 10:45 AM   #172
Opie
Opie's Avatar
Stole Dave-Ror's taillights...
And filled the big empty radio hole with a delete plate.
new2subaru (04-26-2020)
Old 04-26-2020, 09:23 AM   #173
new2subaru
Weight Weenie
Drives: 15 FR-S
Where did you get the delete plate? Looks good!
Old 04-26-2020, 07:10 PM   #174
Opie
Opie's Avatar
From Toyota, P/N:55522-52020
Old 04-26-2020, 10:57 PM   #175
new2subaru
Weight Weenie
Drives: 15 FR-S
Thanks for the part number!
The Following User Says Thank You to new2subaru For This Useful Post:
Opie (04-30-2020)
Old 05-29-2020, 02:00 PM   #176
Opie
Opie's Avatar
So am finally headed to Sebring tonight for the weekend and get to try out all these changes! It's gonna be humid, hot and rainy...just like every other summer day in Florida but it's gonna be fun!!
Will be out there with my friend Aaron, owner of Opie & Dave-ROR's rebuild #6
@Dave-ROR says it's too hot....or he is just too slow...
Code Monkey (05-29-2020)
Old 06-01-2020, 11:01 AM   #177
Opie
Opie's Avatar
Ran consistent 2:38's at Sebring this past weekend, put down a new PB of 2:38:33 on an old set of RE-71R's I used on Saturday with thinking it would rain but was Humid & Super Hot instead.
Sunday was dry so I ran a set of brand new R-Comp Hoosiers for the 1st time and set another PB of 2:37:88. I know there is a bunch more time with those tires as they grip like nothing I've tried before!
Parked the car after a few issues, thanks to the Sebring bumps LOL:
Have a slight tire rub in turn 1 I need to address since I'm taking it much faster than before, going to raise the coil-overs 1 turn at all 4 corners to maintain the corner balance.
Right end plate on the Big Wang lost a screw and the plate was dangling for a few laps.
Steering wheel became way off center during the day, I assume something is loose...or bent. Need to inspect to determine.
Was a super fun weekend, would've been a perfect weekend if it wasn't so hot & humid.
Have videos I'll get uploaded later this week!
Code Monkey (06-01-2020)
Old 06-01-2020, 01:35 PM   #178
ka-titties
Drives: 2013 BRZ Limited 6MT
Lmao you mention the heat and humidity like you dont already live in Florida. Its summer, mate!
Which Hoosiers are you using? What made you want to buy some brand new sticky bois if you're not doing NASA or SCCA?
ka-titties is offline   Reply With Quote
Old 06-01-2020, 02:19 PM   #179
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
This has been a constant issue for me as well the last couple years. Alignment feels fine but wheel will slowly become off center. I was thinking it could be the steering rack bushings degrading. Forgot to look last time I was under the car.
Old 06-01-2020, 02:53 PM   #180
Opie
Opie's Avatar
I'm surprised every year by how hot and humid it is here...you think I'd learn after 45 years...LOL
Hoosier R7's - They were a gift...and now I'm addicted to the purple crack....
Old 06-01-2020, 02:56 PM   #181
Opie
Opie's Avatar
Interesting....that seems to be my case, car still tracks straight and alignment seems fine (no pull, etc) just the wheel is way off center....I could go around turn 6 (right turn) and the steering wheel was straight...down the straightaways the wheel was at the 10:00 position...
Old 06-01-2020, 03:01 PM   #182
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Mine settles in about that position as well.
NORGP GT86 just for Track Rebuild Panamaniac Member's Car Journals 25 12-06-2019 08:41 AM
History of my GS-R.. and rebuild.. my now-current track car. Dave-ROR Other Vehicles & General Automotive Discussions 35 12-12-2013 08:02 PM
MVP Track Time 2013 Road Atlanta Track Dates Feffman Southeast 7 11-05-2013 11:36 AM
MVP Track Time 2013 Great Lakes/Midwest Track Dates Feffman Great Lakes 5 09-07-2013 01:39 PM
FS: 2013 Totalled BRZ FS (~5,000 miles) eklipz98 Northern California 45 02-03-2013 01:16 AM
