Old 04-22-2020, 11:56 PM   #57
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
If you want to see what's going on with the engine (without pulling the motor out/apart), just do a damn used oil analysis.
Drain the oil. collect a good sample. refill with used or new oil, doesn't matter.
Wait a few weeks for the UOA to come back and determine next steps.
Old 04-23-2020, 12:06 AM   #58
soundman98
ProCrastinationConsultant
soundman98's Avatar
You found a motor, trans, ecu, pedals, and wiring loom to be cheaper than just a motor?
I think i might need to make some popcorn
Old 04-23-2020, 10:32 AM   #59
DJ92
Drives: 13 Crystal Black Silica BRZ
Cheaper? No never said that. It was engine, trans, harness, and ecu all on one nice little pallet for 4k. If I got it for a little less than asking, just add pedals and any miscellaneous things = about 4k for manual swap. And if I kept the car that's what I would want to do so why not spend 700ish extra and just do it.
But really that's alot of work and I honestly intend on getting rid of it now and that would be alot of time and more money just to sell it id much rather just find a direct swap and trade. Or better yet I found this niche shop that just fixed an acquaintance's heavily modded sti so maybe they will give me a lower price to fix it. The only problem is I don't want to waste any more money on towing because it's 50 miles away and I'm not sure what there gonna tell me but just like the pump I'm about to try it
DJ92 is offline   Reply With Quote
Old 04-23-2020, 12:01 PM   #60
Originally Posted by DJ92 View Post
The brakes are fine guys. Iv gotten so frustrated with this and keep going back and forth. Auto engines are expensive I found everything I need for manual swap for around 4k so that sounded like a no-brainer. But now I just want to trade it in after fixing it and take the 4k negative equiy. I'm probably going to have it looked at more I have a couple people/places to try now
But swapping to MT still would require you swapping an engine so there is no advantage as far as costs go.
You still don't even know what is wrong with it. The assumptions are it is major but it could be a cheap easy fix. Find the actual issue before deciding what you are going to do.
Old 04-23-2020, 04:31 PM   #61
DJ92
Well it's at the shop now. I'm getting a 100% for sure diagnosis now that I found a well qualified place. I should know by the end of tomorrow what it is.
Old 04-25-2020, 02:48 PM   #62
DJ92
Engine is internally screwed for sure. I'm now wanting to verify compatibility. I know the 13 and 14 brz enfines are exactly the same, as far as frs motors go is the same true? Just any 13/14 frs will work?
bearing, broke, engine, knocking, motor
Rocker arm broke and broke my valve cover... j0hnnykthx Issues | Warranty | Recalls / TSB 9 08-07-2020 08:12 AM
Need advice, dealership says I need new engine spdsk8race Issues | Warranty | Recalls / TSB 22 04-11-2018 02:23 PM
Need some advice on engine guys! dsteezy86 Northern California 23 01-19-2017 07:33 AM
Engine noise... advice? hyperpunx Issues | Warranty | Recalls / TSB 8 09-28-2012 12:57 PM
