Old 04-05-2018, 08:38 PM   #1
spdsk8race
Drives: scion frs
Need advice, dealership says I need new engine
I don't know if anyone can help, but I figured this would be worth a shot.
I was driving home last week and while on the highway my engine shut off. Pulled it off to the side and started it back up, but it wasnt idling right, I pulled off and parked it, got it towed to a dealership and they looked it over and are telling me that I need a complete new crate engine, which will cost $15,000. My car is 4 years old and 65k miles and I haven't had a single issue in the lifetime of the vehicle up to this point.
What I'm trying to figure out is if that is what is really needed, if there is a cheaper option, or if I'm being bent over a table. They won't do a full teardown because the warranty is expired and Toyota is not offering any help. The only thing they have given me is a picture of the oil and the error code read out.
Thanks for any helpful information or advice!
spdsk8race is offline   Reply With Quote
Old 04-05-2018, 08:42 PM   #2
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Just Google the code number combined with "frs" and see the general prognosis. It's a known issue and it sucks. Your oil having metal flakes in it doesn't bode well either.
Lots of threads, with varying fixes!
Old 04-05-2018, 09:08 PM   #3
humfrz
Hello spdsk8race and welcome to ...... The Forum ......
That code doesn't look good for your car. As mentioned, there has been a lot written about that problem, for your review.
You might consider draining the crankcase oil to see if there are metal particles in the bottom of the pan.
Is your car boosted..??
Have you tracked it ..??
Will it start and run at all ... ??
$15,000 sounds like a lot for a new engine ....
Come back.
humfrz
Old 04-05-2018, 09:45 PM   #4
spdsk8race
Drives: scion frs
100% stock Everything. No boost, no mods, never been on the track. It started but I had to review it to keep it going before it idled out and went into limp mode.
Old 04-05-2018, 09:49 PM   #5
spdsk8race
Drives: scion frs
My big question is should I get it towed to another shop, since the dealership won't do a teardown to find the actual issue without a warranty, trust the dealership, or find my own engine which I have no idea where to start on that. Toyota told me because my oil records are from jiffy lube they are valid to a out of warranty fix. Only dealership records will be accepted.
Old 04-05-2018, 10:18 PM   #6
steve99
If it out of warantee just take it to a subaru shop they will fit new engine for a fraction of that price
Old 04-05-2018, 10:18 PM   #7
Summerwolf
Panda Trueno
Summerwolf's Avatar
Do some research through those threads. I would at least give the sensor swap a try and maybe send an oil sample to Blackstone for analysis before shelling out more than the vehicles value in a "new" engine after one dealer's diagnosis.
Perhaps find a local tuner familiar with the platform. You're out of warranty either way, might as well use someone who has expertise with the car.
Old 04-05-2018, 10:32 PM   #8
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Ask Toyota to see if they would goodwill the repair to help lower the repair bill. If you had your car Normally serviced at the dealership, ask for a discounted Labor rate if you're a loyal customer. Doesn't hurt to ask.
N1rve
Old 04-05-2018, 10:42 PM   #9
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
A used engine with 30-60k miles on it can be had for 2200-3000 dollars. Add ~18h of labor at a good Indy (1800 bucks ish) and you should be set for just under 5K.
Good luck
Old 04-06-2018, 12:11 AM   #10
humfrz
Well, spdsk8race, the first thing I would do is to get that car away from that dealership.
If you live in a bigger city, I would call around to local shops that have experience with that type of engine to try to find one that would give you a second opinion as to the cost of repairs.
The oil analysis suggested above would be a good idea.
If the shop is not too far away, I'd just drive it there.
Keep us posted.
humfrz
Old 04-06-2018, 10:39 AM   #11
Icecreamtruk
Drives: Track preped NA FRS
Get the car away from the dealer if the only thing they want to do is a brand new engine swap. It will cost more than buying a whole car, not even joking here.
Also, stop doing oil changes at Jiffy lub, I dont think there is a garage in the world I would trust less than them. Almost 100% convinced your problem is because of an "oil change" where they didnt change it all, or put in the wrong oil.
Old 04-06-2018, 11:01 AM   #12
davidsn_670
Drives: 2015 Scion FRS
Replace that cam sensor and leave the negative terminal off for 4 hours. Let it relearn and go from there. Worked for me.
davidsn_670 is offline   Reply With Quote
Old 04-06-2018, 11:04 AM   #13
highway7
Drives: FRS 2013
Agree with this... jiffy lube and other quick lube places literally hire people off the street with 0 experience. I don't understand the rationale behind taking a $30k purchase to get the engine, the most expensive part of the car, worked on by people that are getting paid minimum wage. Minimum wage = minimum effort; just to save at most $20 compared to getting it changed at the dealership.
highway7 is offline   Reply With Quote
Old 04-06-2018, 11:39 AM   #14
strat61caster
strat61caster's Avatar
That's a lie, read your warranty information.
ineedyourdiddly
Advice about dealership mishap! ModalSoul37 BRZ First-Gen (2012+) — General Topics 16 10-21-2014 07:30 PM
Dealership overfilled my engine oil mike the snake Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 50 12-07-2013 10:50 PM
Need some advice (dealership error) Dreamshot Scion FR-S / Toyota 86 GT86 General Forum 19 06-09-2013 09:32 AM
Dealership advice MattZ28 Southeast 6 01-06-2013 01:36 PM
dealership 4 hours away, bad for engine break in? Mykflo BRZ First-Gen (2012+) — General Topics 27 05-23-2012 07:57 PM
