Koji_Online
Old 04-18-2020, 05:52 PM   #729
LancePower
Drives: 2020 BRZ tS
Originally Posted by airrick View Post
I did the mod, and i like it. But only one thing that annoys me and i think i did wrong. Whenever i shift and my foot leaves my clutch pedal, the gear indicator takes like almost a full second to show what gear im on. Ive been trying for like an hour to adjust my sensor thing. Is it broken? Im just not sure what to do and its annoying me
Are you sure it is a longer delay than previously?
The cluster's Gear Indicator is based on a calculation of the gear you're in and the speedometer reading, so it has a delay built-in.
It is not a sensor in the Trans or somewhere that knows what gear you've selected.
LancePower is online now   Reply With Quote
The Following User Says Thank You to LancePower For This Useful Post:
jcw99 (04-24-2020)
Old 04-18-2020, 06:25 PM   #730
airrick
Drives: TRD R.S. 1.0 FRS
Okay maybe my memory is a little off. I did this mod like a year ago. But i remember this was like the only thing i didnt like. I just thought i did it wrong. Because the Reverse gear indicates immediately. Before i depress the clutch even.
airrick is offline   Reply With Quote
Old 04-18-2020, 07:30 PM   #731
LancePower
Drives: 2020 BRZ tS
I'm guessing Reverse is instant due to the Back-Up Camera.
Old 04-18-2020, 07:35 PM   #732
airrick
If only i had one of those.
Old 04-18-2020, 07:52 PM   #733
Infinity
Drives: 2016 Scion FR-S
Can someone clarify for me, does this adjust the physical position of the pedal or does it adjust the point in the travel of the pedal that the clutch grabs?
Infinity is offline   Reply With Quote
Old 04-18-2020, 09:06 PM   #734
Infinity
I just did the adjustment. I see that it adjusts the position of the pedal. Going for a test drive now.
Old 04-21-2020, 05:41 PM   #735
Bodalenko
Steve Bodalenko
Drives: Toyota 86 GTS
So it has no relevance to clutch adjustment just pedal height?
Bodalenko is offline   Reply With Quote
Old 04-21-2020, 09:52 PM   #736
The clutch operating mechanism adjusts to wear automatically.
This adjustment changes the amount the clutch is disengaged by changing the throw of the pedal. The stroke of the master piston is proportional to this.
jcw99 (04-23-2020), Mike_ZN6 (04-23-2020)
Old 04-23-2020, 05:50 PM   #737
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
I think they are related. As in, adjusting the position of the pedal effects the catch point.
Mike_ZN6 is offline   Reply With Quote
Old 04-23-2020, 05:52 PM   #738
Mike_ZN6
Mike_ZN6's Avatar
I have been playing around with this adjustment for a few days now. Personally, I think having the clutch pedal just slightly higher than the brake pedal, rather than just slightly lower, feels the best.
Old 04-23-2020, 06:42 PM   #739
This is very true.There needs to be enough disengagement to keep the clutch from dragging with the occasional sloppy shift. Need some clearance to keep the disk from windmilling. Otherwise the syncros have to fight that drag - stubborn shifts and premature syncro wear
jcw99 (04-24-2020), Mike_ZN6 (04-23-2020)
Old 05-14-2020, 05:56 AM   #740
sneaky_pete
Drives: MY14 86 GTS Manual Velocity Orange
for those with RHD versions:
sneaky_pete is offline   Reply With Quote
Old 07-15-2020, 02:00 AM   #741
alangoooo
Drives: 2016 Scion FRS
Hello! Just had my clutch replaced to a Spec stage 2 and re-adjusted the pedal. Can someone please let me know if the clutch cylinder is fully depressed/ compressed? Also is that adequate play for the cruise control sensor? My clutch pedal is maybe a tiny bit higher than my brake pedal right now. I also made sure the cruise control screw is not pressing into to the clutch on its own. Want to make sure I did this correctly and the clutch isn't engaged...
https://imgur.com/9TtheVx
Thanks!
alangoooo is offline   Reply With Quote
Old 07-16-2020, 07:13 AM   #742
sneaky_pete
Originally Posted by alangoooo View Post
is that adequate play for the cruise control sensor? !
if the cruise control disengages when you put the clutch in then it is OK.
clutch adjustment, clutch helper spring
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 04:41 PM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 11:17 PM
Any (easy) way to stiffen up the feel of the clutch? Partial Stall Engine, Exhaust, Transmission 41 07-19-2012 03:17 PM
My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* wanger Scion FR-S / Toyota 86 GT86 General Forum 5 06-02-2012 02:41 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 04:48 PM
