go_a_way1, MisterSheep
Old 04-22-2020, 07:26 PM   #21743
Don’t they make caliper designed paint? Or it’s same damn thing?
"Caliper" paint is good to 900 degrees. The high heat paints are good to 1200. There is nothing special about caliper paint other than saying caliper on the label.
ichitaka05 (04-22-2020), RToyo86 (04-22-2020)
Old 04-22-2020, 07:31 PM   #21744
I suspect high heat paint isn't quite good enough. But if he's not racing then maybe
Sent from my ONEPLUS A5010 using Tapatalk
Ya. I sold the FRS with life still left on the original brake pads after 150,000 miles. My brakes don't take much pressure so I could probably use finger paint and it would last.
Old 04-22-2020, 07:34 PM   #21745
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
I’m no expert, but don’t think you need 1,200F lol stock pads can’t even handle that temp. Even those semi racing pads goes up to 800~900F.
Old 04-22-2020, 07:52 PM   #21746
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Calipers usually don’t get over 500. Most of the heat is in the pad and rotor surface.
Old 04-22-2020, 08:02 PM   #21747
I know. That is why the high heat paint is fine. It greatly exceeds the max it will ever need to. "Caliper" paint is just marketing for the guys that think everything needs to be special.
Old 04-22-2020, 08:08 PM   #21748
i'm special
Ashikabi (04-22-2020), ichitaka05 (04-22-2020)
Old 04-22-2020, 08:24 PM   #21749
i'm special
Old 04-22-2020, 09:40 PM   #21750
i'm special
So then, change your avatar, oh special one -
Old 04-22-2020, 09:41 PM   #21751
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
You don't like Jesus restored?
Ultramaroon (04-22-2020)
Old 04-22-2020, 09:50 PM   #21752
Plenty special, if you ask me.
Sapphireho (04-22-2020)
Old 04-22-2020, 09:52 PM   #21753
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I suspect many brands like rustoleum, VHT, and Dupli-Color are more similar than they are different.
POR-15 has a good reputation at being resilient against corrosion. Their kit has a prep primer for neutralizing rust, and it was relatively inexpensive.
With new good condition calipers I'd probably go with G2's caliper kit. Two part epoxy finish, paint with an activator.
The Following User Says Thank You to RToyo86 For This Useful Post:
Old 04-22-2020, 10:07 PM   #21754
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I coated a 1970 frame in a restore with POR-15, and restored an old steering wheel with their wheel kit. Good stuff.
RToyo86 (04-25-2020)
Old 04-22-2020, 10:16 PM   #21755
MasterBandit
Drives: Scion 2015 FR-S
Today I installed my Tomei uel and it sounds great paired with my trd exhaust. Tune tomorrow.
MasterBandit is offline   Reply With Quote
Old 04-24-2020, 10:49 PM   #21756
EvolutionRevolution
Drives: SCION FRS 2016
Bolted up an invidia Q300 cat back exhaust system that i picked up today locally for 300 bucks (not sure what they go for but that seems decent?). It's paired with HKS EL header added a few weeks ago. Seems to be a decent combo. More drives will tell. It's tame.
EvolutionRevolution is offline   Reply With Quote
