| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#43 | ||
Drives: 2018 BRZ
#44 |
Drives: 2017 BRZ Limited PP
I'm basically in the same boat as you. I'd like to replace my stock wheels with some nice lightweight wheels. But, I don't want to mess with the stock feel too much. Also, the car in bone stock form is already fast enough to get me into trouble, so making it faster is not particularly important.
And, I have PP brakes, so that complicates things. Every time I look, I keep coming back to RPF1 17x8 et45. Several sources say they fit the PP brakes. And the 3mm difference in offset should not be too significant. Tirerack specs seems to suggest you can stretch a 215 tire over them. But, do the 17x7.5 et48 fit the PP brakes? I don't recall seeing any info suggesting they do. If they do though, they'd be the obvious choice for me. |
#45 | |
Drives: 2018 BRZ
On the other hand, if you don't want/need the 8 inch wide wheel, you could try the 17.7.5 and if they don't fit try some spacers. For most wheels that don't fit mild spacers seem to be enough. Edit: actually, it might be that the narrower wheels will actually have better backspacing, so they might fit without spacers. This is especially appropriate for the RPF1 that are more convex in narrower widths (so the more concave 17x9 not fitting might actually be a good sign )
| The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | scottbrz (04-21-2020) |
#46 |
Dysentery Enthusiast
Drives: 2017 toyota 86
The wheels are pressure cast sport edition P4, enkei makes an identical rim size and offset wheel. My wheels are 16/7 +35 I had factory wheels with the Michelin then some R3's, before I switched to these. I wanted a good all season tire with decent performance so I went with General Gmax AS-05. If you drive your car in the snow or bad weather this tire is flat out awesome. Performance on dry pavement for how I use the car is good enough and it's got good overall life.
| The Following User Says Thank You to RuyGuy2 For This Useful Post: | Ohio Enthusiast (04-21-2020) |
#47 | |
Drives: 2018 BRZ
#48 | |
I'm also considering the Continental ExtremeContact DWS 06 since they are 20lbs (same weight as the stock tires). I just have to wear out the Primacies first. |
#49 |
Drives: 2018 BRZ
I ended up getting the Enkei RPF1s in 17x7.5. I'm very happy with them - the stock Primacys look a tad stretched already on the 7.5, I doubt I would have liked them on 8 inch wide wheels. According to the Butt Dyno™ the car feels sprightlier in low gear acceleration (the Enkeis are about 5 lbs lighter per wheel).
| Will changing wheel width and offset affect alignment? | azynneo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 09-15-2017 01:46 PM |
| Handling characteristics with a low offset and narrow wheel width | surfwaxsmitty | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 05-24-2017 08:04 AM |
| Effects of wheel weight and width on suspension | wootwoot | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 34 | 04-01-2015 11:44 PM |
| Desired Wheel Size, Width, Offset - OPINIONS | CSG David | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 63 | 05-21-2014 12:02 AM |
| Stock width, stock "feel" bigger rim? | Trashed675 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 03-12-2013 12:39 PM |
