| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
Persona Non Grata
Drives: '15 BRZ (WRB)
To echo some of what Churchx said: If you want the feel of the car to stay the same, leave the OEM tires and wheels alone. If aesthetics are what you're after and you don't mind the "stretched" tire look you could go to 8" wheels with the OEM tires. I suspect it will change the dynamics a bit. Will you notice it? I can't say. Probably not.
As soon as you change the tire, however, it will change how the car feels. That may be for the better (it was in my case) or it may not. It's highly subjective. I went to 17x8 Konig Ultraforms with 225 Conti EC Sports. It made a significant change in the feel of the car. Before I did that, though I installed some camber bolts and had the front camber set to -1.5. That made a substantial change in the feel of the car. It was more surefooted on turn in and a little more tail happy. The wheel/tire change increased the sureness of the turn-in and calmed down the tail happiness. OE - I re-read your original post. If you with either of the tires you mentioned it WILL change the feel of the car. A few tenths of an inch in width won't matter much. Going to a high(ish) performance tire will. Which takes me back to the first sentence.
Slow is smooth, and smooth is fast
#16 | |
Drives: 2018 BRZ
Yeah, I'm starting to lean toward the school of thought that tire compound is much more significant than tire/wheel size. I'll probably go with the RPF1 in 17x7.5 (being the lightest option, and almost the only lightweight wheel at that width) and consider the tire choices when the Primacys wear out (and I have more experience under my belt with the BRZ). |
#17 |
Drives: 2016 Ablaze FRS
I love the stock Primacy tires on my 720Form 17x8. There is a bit of stretch, and not all tire places will mount them, but they are fun for daily driving. The 17x8 +35 offset fills the fenders pretty close to flush too. I'm not bothering with lowering as then I have to rebuild the whole suspension, and it won't be any better than stock.
| The Following User Says Thank You to scotto79 For This Useful Post: | Busybee (04-20-2020) |
#18 | |
Drives: GR86 Trueno Edition
Any pics? Thanks Sent from my iPhone using Tapatalk |
#19 | |
Drives: Crapcan
#20 |
Drives: 2014 GT86
Narrower tires may also have another less obvious pros .. eg. what happens if during trackday it rains? They should also have less rolling resistance/better economy for ones that daily on them aswell. And often they are cheaper, and they fit well even on OE wheels. So even if on some tracks in some circumstances they do slightly better, if one is not hunting for every second competitively but is out there for fun and if one pays himself all track wearables, imho narrow tires look a bit more desirable overall choice.
#21 |
Drives: '13 Whiteout
Stickier tires cause more body roll so it’s advisable to lower the car
#22 |
Drives: 2018 BRZ
Yeah, no necessarily lower, but stiffer springs for sure. That's in the long term plan as well (the stickier tires will be mounted once the stock Premecys wear out, so I still have time for that).
#23 | |
Drives: 2017 toyota 86
Possibly the tracks used for testing where all more advantageous to wider wheels, Possibly the professional driver can bring out the true limits of each size tire and a casual can’t or at least needs more time with each size or whatever size he has most seat time with is fastest for him. Possibly this car is vastly different than the other cars tested. Possibly the other cars stock tire was way undersized to begin with and our 86 is perfect size from factory or closer to perfect size with stock setup. But it was repeated so many times on so many cars with 100% identical results across the board. |
#24 | |
Drives: Crapcan
#25 | |
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Generally a slight stretch will give you better initial turn-in and steering response at the small expense of a marginally harsher ride.
In reality, the tire you select will have magnitudes larger effect on vehicle dynamics (turn-in, steering response, general NVH) than splitting hairs on 10mm of section width. Just choose a quality tire (the Michelin P4S and mentioned Conti's are the best street centered tire that money can buy) and be done with it. Quote:
On the note of T4, let's talk about it. Looking at the 2019 TTN Results, guess what the class winner was running? 255 on a 9.5. Guess what the 2nd place was running, guess what the third place was running? All 245's/255's. We need to put this myth that a 225 on an 8 inch is even in the realm of competitive compared to 245/255 on a 9+ wheel to bed.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
| The Following User Says Thank You to Goingnowherefast For This Useful Post: | Ohio Enthusiast (04-20-2020) |
#26 | |
Drives: Crapcan
A twin in T4 is limited to 17X7 wheel size. I believe the reason the T4 guys went narrow is the wider tire wasn't working on that narrow of a wheel for them.
#27 | |
There is no wheel size limitations in SCCA TT T4. Here's a link to the rules: https://timetrials.growsites.net/pages/tuner-category "1. Any width or diameter wheel and wheel spacers may be used provided it complies with the following: A. Non-metallic wheels must be certified/approved from an appropriate, recognized standards organization. (e.g., FIA, SFI, SAE, TUV, etc.) B. Wheel spacers are permitted. C. Wheel studs, lug nuts, valve stems (including pressure-relief types) and/or bolt length may be changed. Wheel bolts may be replaced with studs and nuts, but the number of fasteners may not be changed. D. Tire pressure monitoring sensors may be removed. E. Centerlock/spline drive/knock-off type hubs may be converted to lug-type hubs." For the tire size, 2WD cars are limited to a 265 tire.
#28 |
Wheel offset has a huge impact on scrub radius, which has a huge impact on steering feel.
| The Following User Says Thank You to Tokay444 For This Useful Post: | Ohio Enthusiast (04-20-2020) |
| Will changing wheel width and offset affect alignment? | azynneo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 09-15-2017 01:46 PM |
| Handling characteristics with a low offset and narrow wheel width | surfwaxsmitty | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 05-24-2017 08:04 AM |
| Effects of wheel weight and width on suspension | wootwoot | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 34 | 04-01-2015 11:44 PM |
| Desired Wheel Size, Width, Offset - OPINIONS | CSG David | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 63 | 05-21-2014 12:02 AM |
| Stock width, stock "feel" bigger rim? | Trashed675 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 03-12-2013 12:39 PM |
