Old 04-18-2020, 12:09 PM   #43
I have all the parts he needs minus the engine..
Read his first post. Having the parts is only part of the equation!
Old 04-18-2020, 02:47 PM   #44
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Like someone else said if he can swap a clutch he can swap one of the engines in these cars. Outside of getting the trans off, and back on, the engine, it's pretty easy to do.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-18-2020, 03:23 PM   #45
Still waiting to hear about the brakes.
Tcoat (04-18-2020)
Old 04-18-2020, 03:49 PM   #46
Yep. He wants to do an AT to MT swap. That is not a entry level work. In the long run it would be better for him to just trade the car. I see nothing but headaches in his future if he did the swap.
soundman98 (04-18-2020)
Old 04-18-2020, 04:45 PM   #47
Ashikabi
Ashikabi's Avatar
Better off just dropping in a used motor. I 100% get wanting to upgrade but it definitely sounds like a clusterfuck. Replace the engine then trade for a manual
Sent from my ONEPLUS A5010 using Tapatalk
The Following User Says Thank You to Ashikabi For This Useful Post:
Tcoat (04-18-2020)
Old 04-18-2020, 06:34 PM   #48
This. If it is determined there is actually something serious wrong with the engine. That had not been established yet by any means.
Old 04-18-2020, 06:59 PM   #49
Ashikabi
Ashikabi's Avatar
Agreed. A simple leak down test should certify a valve spring issue. Check oil for sparkles to verify spun bearing. Anything else I'm missing?
Old 04-18-2020, 09:35 PM   #50
Brake booster plumbing. If brakes are fixed then the pump did something and maybe something else is still wrong.
If brakes aren't fixed then I'll bet:
1. The used replacement pump was also shot
2. Improper installation
Old 04-18-2020, 09:39 PM   #51
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
These cars are easy to do the pedal swap in.. the rest is all pretty damn easy.
I get that it's not an entry level job, but compared to the several cars I'd done swaps in (all AT to MT swaps) it's about the easiest car to swap except for some Hondas.
The worse I think I did was probably a Nissan 240SX. Even a Roadmaster estate is easier than that pos!
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-18-2020, 09:52 PM   #52
Easy for you! You are not on a forum posting "hey guys what is this noise?"
Opie (04-23-2020), soundman98 (04-18-2020)
Old 04-18-2020, 09:55 PM   #53
Ashikabi
Ashikabi's Avatar
Good call
Old 04-18-2020, 10:47 PM   #54
Good call
I'm over here
Dave-ROR (04-19-2020)
Old 04-23-2020, 12:13 AM   #55
DJ92
Drives: 13 Crystal Black Silica BRZ
The brakes are fine guys. Iv gotten so frustrated with this and keep going back and forth. Auto engines are expensive I found everything I need for manual swap for around 4k so that sounded like a no-brainer. But now I just want to trade it in after fixing it and take the 4k negative equiy. I'm probably going to have it looked at more I have a couple people/places to try now
DJ92 is offline   Reply With Quote
Old 04-23-2020, 12:16 AM   #56
Ashikabi
Ashikabi's Avatar
Like we mentioned above... There are several tests that can be done to check engine health without tearing it open. Shouldn't cost more than a couple hundred bucks if that. $1500 for diagnostics is insane
Ultramaroon (04-23-2020)
bearing, broke, engine, knocking, motor
Rocker arm broke and broke my valve cover... j0hnnykthx Issues | Warranty | Recalls / TSB 9 08-07-2020 09:12 AM
Need advice, dealership says I need new engine spdsk8race Issues | Warranty | Recalls / TSB 22 04-11-2018 03:23 PM
Need some advice on engine guys! dsteezy86 Northern California 23 01-19-2017 08:33 AM
Engine noise... advice? hyperpunx Issues | Warranty | Recalls / TSB 8 09-28-2012 01:57 PM
