Drives: 2016 Subaru BRZ
Lowering Springs or Coilovers?
Looking to keep myself busy during the quarantine and wanted some nicer fitment. Don’t wanna break the bank too much, but I do want good quality stuff. Should I go lowering springs or coilovers? Keep in mind it’s a daily driver for me and I have to brave Canada winters as well, wanting a 1” drop max. Any suggestions would be highly appreciated
#2 |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
I first went with lowering springs (swift) and didn't really like the way the car felt with them on curves with bumps and dips. It felt like the rear was wallowing. Switched to Tein Flex Z coilovers and have been happy with them. The Flex Z's also allowed for corner balancing as well as adjusting the ride height and shock firmness. Well worth the slightly extra cost vs the lowering springs.
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 Last edited by shiumai; 04-18-2020 at 01:15 PM. |
#3 |
Wes
lowering springs. Cheap coilovers ownership will go like this:
1. Wow this is just like OEM! 2. Okay a tiny bit firmer than OEM 3. *starting to research suspension technology and finding this thing called "damping"* 4. Realizing the damping in your cheap coilovers ain't that great 5. Painfully browsing online car part shops for $4000 KW V3 with Raceseng camper plates and Shock Tops in the rear, wishing you knew this before hand and saved up a while longer instead.
Instagram: @gt86ws
#4 |
Drives: 2015 BRZ
If its a daily just get lowering springs and call it a day. Theres great springs that offer a 1" drop. I would personally recommend RCE Yellows other options are TRD, Hotchkis, and Eibach Pro-Kit.
#5 |
Drives: '23 BRZ
Lowering springs are fine if you don't go with camber plates. I'm on Swift BRZ Sport springs, lowered the car ~1.25". If you also want front camber, do it with camber bolts and pick wheel/tire fitments that allow you to get the desired camber.
With camber plates, the additional loss of front bump travel makes the ride kinda intolerable as the fronts will bottom out over the smallest bumps... |
#6 |
Drives: '13 Whiteout
I just have springs and and happy with em. I don’t like adjusting things. The car feels good on the track and a bit stiff on the street but I don’t really care. Stiffer sway bars also. I drove an 86 with one of the less expensive coils and didn’t like it at all.
Camber bolts up front to get -2 degrees. any more and you run the risk of killing your tires if you drive on the street much. Last edited by TommyW; 04-17-2020 at 02:39 PM. |
#7 | |
Drives: jrsc_brz
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
#8 | |
Drives: Crapcan
As soon as someone with cheap coilovers says #1 I just ignore the rest of the thread or start trolling.
#9 |
Drives: '13 FRS - STX
Springs
Eibach, RCE, Swift, etc. If you're feeling fancy get dampers too, Bilstein B6 or Koni Yellow |
#10 | |
Drives: FR-S Whiteout
The list is just a possible, albeit likely, scenario.
Intent > Content
cowardice is the mother of cruelty. |
#11 |
Wes
Just my personal experience. I paid about $1100
Instagram: @gt86ws
#12 |
Flex-Z? Or something else? I was referring specifically to the Flex-Z.
Best way to go about it is to get a test ride. Then you can determine how you want to spend your money with no ragrats. Im sure someone will do it for a couple of rolls of TP or hand sanitizer
Intent > Content
#13 |
Drives: 2017 toyota 86
Depends on budget. You got three best bang for buck options you really can’t go wrong with.
300$ RCE yellow springs 950$ tein flex A 1550$ tein flex a csg spec Beyond that isn’t worth it unless dedicated track car. You’ll probably want rear LCA and front camber bolts to go with any of these to get camber dialed in. |
#14 |
If you go lowering springs get dampers to suit.
Lowering springs are a poor mans option, they are marketed well though. These cars ride the bump stops at stock height, so.... Save your money and get some quality coil overs. Don't go silly with spring weights. I wouldn't drop more than 20mm. Adjustable top hats for the front, and some camber solution for the rear. Also, if your coilovers don't come with new front sway bar links, get some adjustable ones. 80% of the mods people do typically makes their car handle worse than stock, typically people just want the lowered look, don't be a typical person. The best advice I can give is don't believe any marketing, go the track and have a look at what the quick guys run. Me, I went MCA street performance coilovers, car was just my daily, way better than the rubbish performace pack Sachs and spring combo that was on my 2017, and at only $2k AUD, the swap was a no brainer. My rear camber solution was Superpro adjustable LCA. The car handled like a dream, till I hit oil mid corner and backed it into a wall. Opinions may vary
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
| Lowering a PP BRZ: Springs vs Coilovers | TofuTogue | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 08-17-2018 01:07 PM |
| Can't get lowering springs, so what coilovers? | jnmxcvi | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 03-17-2017 01:31 AM |
| WTB: Lowering springs or used coilovers | Rsmith954 | Want-To-Buy Requests | 4 | 03-12-2017 06:55 PM |
| Lowering Springs v Coilovers and Exhausts | thehapaone | Northwest | 6 | 07-14-2013 02:23 PM |
| Coilovers or lowering springs | Hawk77FT | AUSTRALIA | 9 | 07-30-2012 09:41 PM |
