Old 04-13-2020, 02:36 AM   #1
Jaaared
Jaaared's Avatar
Drives: 2013 Scion FRS
Eibach Sportlines / Wheel set-up to close gap?
Hi guys, new to forums and tried searching for a setup with the eibach sportlines with a wheel set-up to close the gap (if there are any). Thanks!
Jaaared is offline   Reply With Quote
Old 04-13-2020, 07:35 AM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
I have them on my car, they come in a standard drop, however I do recommend a wheel alignment and camber bolts up front.. make a big difference...
Old 04-13-2020, 07:46 AM   #3
JD001
JD001's Avatar
Drives: Subaru BRZ
My car sitting on Eibach Sport lines.
The Following User Says Thank You to JD001 For This Useful Post:
Busybee (04-17-2020)
Old 04-13-2020, 05:54 PM   #4
Jaaared
Jaaared's Avatar
Car looks great!! will definitely try that out, much appreciated!
Old 04-17-2020, 10:29 AM   #5
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
I read several topics here on the Eibach sport line and pro kits.
I DD my car and that’s all. I just want to lower the car a little. I have 24K on my 1 year old Brz (90% highway).
Is the sport line or the pro kit more suitable with the stock struts ? (Meanwhile is it worth to get the plus for both of the kits?) Another option might be the Tein Flex A or Z coil overs. What I don’t want is to play with the settings. I just want a straight forward install without dealing with camber or LCA ( which I do not understand what they are for).
Is there any one that I can discuss these ? Will also appreciate if I can discuss some details.
Thanks
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
Old 04-17-2020, 11:33 AM   #6
JD001
JD001's Avatar
Drives: Subaru BRZ
Thanks
I have the stock dampers, so far no issues.. there are others on the Forum who have the same setup but done greater mileage..
Old 04-17-2020, 11:49 AM   #7
Vital
Drives: 2015 BRZ
Thanks
If you want to lower just a little than lowering about 1" is perfect for daily driving. I would suggest RCE Yellows or Eibach Pro-Kit. The Sportlines lower more than 1" and not exactly suitable for the stock struts. The RCE Yellows are built around the OEM struts and are great, i have them and countless people on the forum will recommend them as well. Racecomp Engineering is very active and helpful on this forum. Also you mentioned you dont want to play around with settings than lowering springs would be the best option for you. There is no point in you spending money on coilovers if you're just gonna "set it and forget it". Going too low on springs or coilovers will add natural camber more noticeably in the rear. If you stick with a 1" drop or less you wont necessarily need LCAs. LCAs are nice to have to adjust camber if you end up having camber that is uneven on both sides, for the front get some camber bolts and max out the camber.
The Following User Says Thank You to Vital For This Useful Post:
Old 04-17-2020, 12:03 PM   #8
HaXx
Drives: jrsc_brz
Thanks
I just walked a friend through his lowering springs install last weekend. Im on coilovers. if you are deciding between the two eibachs, id get the 1.4in drop, so you get a little more bang for your buck. youre talking about protecting your oem struts here, not exactly a precious commodity that need to be taken seriously. if it was u turbo housing, yes, id say protect that and make sure its getting oils pressure and wasnt overheating.
i dont forsee any problems using the sportlines, im sure theyre are MANY forum members that run them.
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
The Following User Says Thank You to HaXx For This Useful Post:
Old 07-11-2021, 05:07 AM   #9
JD001
JD001's Avatar
Drives: Subaru BRZ
Just an update/warning, yesterday my car went for its annual safety check. The Workshop discovered both front springs had failed, NSF spring was in 3 pieces!! I only done about 12k over 6years.. I surprised and shocked, had noted the ride getting very "crashy" over a period of time, I think the springs snapped yesterday on my drive to the workshop..
Moved on to KW V3, new dampers and springs.. Freshen up the ride as I'm sure the OEM dampers must have suffered..
Old 07-14-2021, 07:05 PM   #10
jflogerzi
jflogerzi's Avatar
talk bout a huge jump. Why not something like blisten dampers.... KW v3 are more track focused that still ride nice on the street
2013 Series 10 FRS #553
Old 07-15-2021, 11:44 AM   #11
JD001
JD001's Avatar
Drives: Subaru BRZ
Yep, a big jump. Always been curious about the KW coilovers, seen them spec'd on various cars from our Twin to Porches etc.. Opportunity arose so I took it... Keep you all posted with developments.
jflogerzi (07-15-2021)
Old 07-17-2021, 05:02 PM   #12
JD001
JD001's Avatar
Drives: Subaru BRZ
FedEx still have my suspension. It was meant to be delivered last Tuesday, didn't happen.. The UK supplier rather optimistic!! FedEx booked for yesterday by COP!! No show, looks like the car is staying with the garage another week..
Old 07-17-2021, 10:08 PM   #13
PulsarBeeerz
Drives: JRSC BRZ SOLD
FedEx has been a joke here too. 60/40 I get packages sometimes days late from them.
PulsarBeeerz is offline   Reply With Quote
Old 07-23-2021, 03:44 PM   #14
JD001
JD001's Avatar
Drives: Subaru BRZ
Picked her up today, drove about 20miles home, first impressions, very good! The spring/damper relationship seems much better. The bumps and thumps have gone, no longer sharp drops into and out of bumps in the road.
The car is riding on KW's factory settings, will explore further once I've gotten used to the current setup..
eibach, frs, lit, setup, wheels
FS: Eibach Sportlines yam86 Canada Classifieds 3 04-17-2017 01:53 PM
FS: Eibach Sportlines yip Brakes, Suspension, Chassis 13 03-03-2016 04:46 PM
FS: Eibach sportlines. CA 420zc6 Brakes, Suspension, Chassis 5 11-07-2014 03:03 PM
Anyone with Eibach Sportlines gatorbushmen Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 12-12-2013 02:55 AM
NY: F/S Eibach Sportlines delusional Brakes, Suspension, Chassis 7 04-26-2013 01:35 PM
