Old 04-16-2020, 04:30 PM   #43
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Having read Yoshi's problem, I simply looked for the newest model I can possibly find. CA060 on the pump assembly and there is another ID number on the control unit that distinguishes between the newer ones and older, tho I'm not sure how to decode it.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
Yoshoobaroo (04-16-2020)
Old 04-16-2020, 05:02 PM   #44
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
I'll try finding a newer unit and see it that makes a difference.
Old 04-16-2020, 09:35 PM   #45
solidONE
solidONE's Avatar
Hopefully it's that. If you can, try to verify that the electronic module has a number consistent with a newer unit.
My build date is 02/13 IRC, so its just a bit newer than your car.
Original control unit: 0 266 242 427
'19 (or maybe '18) toyota 86 control unit: 0 265 290 176
hope that helps.
Intent > Content
Old 04-22-2020, 03:52 AM   #46
blown
Drives: ft86
so we do need to reflash the ecu for older cars?
blown is offline   Reply With Quote
Old 04-22-2020, 06:56 AM   #47
makinen
makinen's Avatar
Drives: Toyota 86
No.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
Old 04-22-2020, 07:53 AM   #48
churchx
churchx's Avatar
Drives: 2014 GT86
No. unbolt electronic control module from abs block, rebolt new one, repin it, should work even on old instrument gauge cluster, except it will light vsc sport instead of track and will have no hillstart indicator.
Old 04-22-2020, 09:28 AM   #49
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
I'm hoping Yoshoobaroo gets his situation sorted out so we can all do this swap with confidence.
Mike_ZN6 is offline   Reply With Quote
Old 04-22-2020, 09:49 AM   #50
churchx
churchx's Avatar
Drives: 2014 GT86
Well, so far there seems to be more successes vs his case. And seems that module used on ebay doesn't cost that much, or that work isn't that difficult, for just that to keep putting off. Worst case, $100 paid for no change.
Old 04-22-2020, 11:13 AM   #51
solidONE
solidONE's Avatar
Get if off a '19 manual trans. I'm confident.
Intent > Content
Old 04-22-2020, 11:17 AM   #52
Yoshoobaroo
TRACKBREAD
I agree. I'm the only one out so far and I've got the oldest unit by far. even getting a 2018 unit should be safe. I'd avoid the 2017s for now.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
solidONE (04-22-2020)
Old 04-22-2020, 11:51 AM   #53
churchx
churchx's Avatar
Drives: 2014 GT86
BTW, how important bit is to ensure it comes from MT? Has anyone tried & failed with retrofit from AT? Are there different part numbers to ease distinguishing/ensuring it's right one, not just telling yes to all guestions seller that wishes to sell it off?
Old 04-22-2020, 12:19 PM   #54
solidONE
solidONE's Avatar
I just got it from a Mt to be safe there is a part number on the control unit for sure but not sure how to read it. See my last post in the previous page
Intent > Content
Old 05-01-2020, 11:42 PM   #55
blown
Drives: ft86
is it only the brz which has the track mode? or does the gt86/frs have them?
Old 05-02-2020, 01:00 AM   #56
makinen
makinen's Avatar
Drives: Toyota 86
It only depends on MY.
CSCS Mid Summer DRIFT 2017 - Round 3 - SUN July 23 2017 @ TMP CAYUGA SB LAYOUT DTrouble CANADA 0 07-19-2017 08:42 PM
2017 CHRYSLER PACIFICA MINIVAN VS 2017 TOYOTA 86 WHO WINS IN A DRAG RACE??? Extreme Dimensions Off-Topic Lounge [WARNING: NO POLITICS] 6 06-08-2017 08:59 AM
Boost Festival 2017: Feb 25, 2017 Willow Springs GTA, JustDrift, Drift ModinJapan Southern California 1 01-25-2017 12:46 AM
WTB BRZ Always On Module Jordan Silveira Want-To-Buy Requests 3 08-08-2016 01:30 AM
WTT - 2014 Scion Bespoke Nav Module for Toyota AHA Nav Module Danklvr Audio/Visual, Electronics, Infotainment, NAV 1 09-04-2014 05:57 PM
