Northern California NorCal
Old 04-14-2020, 12:36 AM   #1
fiveoneoh
Drives: none
Recall service question - what other maintenance/repair work to do at same time?
I know, I'm terrible. This question has been answered before, and here I am posting it again. I know there was a post mentioning the following items, but is there anything else I should have done while my car is having the valve spring recall done?
1. Spark plugs (the dealer should charge for parts only, not labor)
2. Timing belt - should I get this changed? I have 35K on the car
fiveoneoh is offline   Reply With Quote
Old 04-14-2020, 03:30 AM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Timing belts last way longer than 35k. But besides the car has a timing chain. It isnt a service item
strat61caster (04-14-2020)
Old 04-14-2020, 10:10 AM   #3
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Clutch just to be safe. They can last a long time or they can last a short time. If yours is a 50k one then you’ll be pulling things apart again. I was at 40 and had it done.
TommyW is offline   Reply With Quote
Old 04-14-2020, 03:35 PM   #4
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
+1
It's inspect and replace the serpentine/accessory belt when it begins to deteriorate or when it starts making noise. Mine was starting to show it's age (light squealing based on weather like a cold morning, some cracks upon removal) at ~85k miles/7 years. And it's relatively trivial to pull it out with the car fully assembled, remove intake, a couple plastic shields, release tension remove belt, install new, check torques and reassemble. Real unnecessary to throw it into the valve spring recall service.
OP, assuming this is the valve spring recall on early cars you should at a minimum replace the throwout bearing with the updated part since it starts dying in the 60k-80k range as a known issue. Should be a max of $40 for the part and an hours worth of labor.
Personally it's too early to do spark plugs or clutch given your low mileage I'd wait for 60k to roll around but doing it now and selling it before the next 60k comes around (when car has ~95k on the clock) will save you a few hundred bucks.
ineedyourdiddly
Old 04-14-2020, 10:29 PM   #5
fiveoneoh
Drives: none
Thanks, I meant serpentine belt and some how wrote timing belt. It was late last night. I also thought the owner's manual said to change spark plugs at 30K (I could be wrong, just going from memory here). I feel like there were other parts that could be inspected and/or replaced while the engine is gutted. I'll definitely check out the throwout bearing Is there any way to inspect the clutch first and only replace it if it looks worn?
+1
Old 04-14-2020, 10:42 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
the brake fluid is supposed to be flushed every 30k miles.
https://www.openbay.com/maintenance/2014-scion-fr-s
Conventional oil change(Every)7,500 miles
Tire Rotation(Every)7,500 miles
Cabin air filter (Replace)(Every)15,000 miles
Brake fluid (Change)(Every)30,000 miles
Air filter (Replace)(Every)30,000 miles
Spark plugs (Replace)(Every)60,000 miles
Automatic transmission fluid (Change)(Every)60,000 miles
Coolant (Flush/replace)(Every)75,000 miles
Fuel filter (Replace)(Every)75,000 miles
Old 06-04-2020, 04:59 PM   #7
fiveoneoh
Drives: none
OK, one more question about this. the dealer is saying to get the oil changed while they're doing it, but I just changed the oil literally not two weeks ago.
Couldn't they just top it off to replace the residual oil that was in the engine?
Are they going to be taking the pan out too? Could the oil get contaminated while the engine is out?
Old 06-04-2020, 09:35 PM   #8
finch1750
finch1750's Avatar
Coolant is 137.5k miles the first time. Then every 75k miles after that actually
norcalpb (06-05-2020)
Old 06-05-2020, 01:57 PM   #9
strat61caster
Yes they can reuse the oil;
https://www.ft86club.com/forums/show...5&postcount=19
I do believe the pan gets removed.
The biggest risk is contamination from a sloppy sealant job, any contaminates in the oil from lazy procedures should be caught by the oil filter before damage is done.
ineedyourdiddly
Old 07-14-2020, 05:37 AM   #10
dagle
Drives: assphalt FRS, couple s2000's
+1, the cost of the clutch is small compared to the labor of in/out. if you don't want to pay the cost now (if you haven't already), the minimum you should do is replace the pilot bearing and throw-out bearing (less than 50$ in parts)
dagle is offline   Reply With Quote
J02 Recall repair in Georgia? nerdpad Issues | Warranty | Recalls / TSB 1 03-08-2019 09:12 PM
Recall service at 65k miles CSkap21 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 02-04-2019 04:27 PM
First warranty service maintenance vinh359 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 16 07-09-2014 01:54 PM
Maintenance or Service Warranty? or Both? JohnAyySays Issues | Warranty | Recalls / TSB 24 03-27-2013 02:04 PM
