Old 01-02-2020, 08:41 PM   #1
gg1978
Drives: 2016 Subaru BRZ Limited Ice Silver
Did the dealership replace my 6MT gear oil with the correct type??
I was going through and filing my brz's maintenance paperwork today and while reviewing it, I noticed that the gear oil used for both the manual gearbox and rear differential was listed as the same item, quantity 3 for trans and 1 for the diff. The description is listed as Valvoline 75W90 synthetic.
From what I understand the torsen rear diff likes 75w90 LS type fluid while the trans is gl3 or gl4 but without the LS as that type of gear oil has sulphur which can corrode the synchros in thr long term.
I did a google search for valvoline 75w90 synthetic, which at first view seems to be a LS type oil that is compatible with GL4, but upon further review of the product info for it indicates that valvoline doesn't recommend it for any transmission with synchros, so nothing made in the past 60 years or so.
Is there another 75w90 that they may have used that might not be LS type, but then I would have to get the diff changed to LS type, or is the more likely conclusion is that the trans has LS type in it?
I have put in an initial call to the dealership about this but was just wondering what gear oils the dealership has put into other ft86 type cars.
Thanks!!
gg1978 is offline   Reply With Quote
Old 01-02-2020, 10:50 PM   #2
skylinekin
skylinekin's Avatar
Drives: 22 GR86, 13 FRS, 15 BRZ, 13 FRS
LS type fluid is not required for our LSD differential since it’s a helical type there is no clutch plates which is typically what the friction modifier or “LS” description is designated for (it won’t harm it to us LS type though).
Lots of people use mogul gear 300 for both the transmission and differential which is a 75w90 (non LS type) safe for our transmission and Hypoid differential gears.
I personally use redline mt90 in the transmission and redline 75w90 in the diff.
What the dealer filled with is probably fine for a daily driver (I assume they used bulk vendor supplied Valvoline non LS type non synthetic fluid), how does it shift? I personally would run a higher end fluid like Motul, Redline, Amsoil etc.. if you are doing any spirited driving but it will cost more.
skylinekin is offline   Reply With Quote
The Following 3 Users Say Thank You to skylinekin For This Useful Post:
CSG Mike (04-21-2020), Plumbus (07-20-2020), Summerwolf (01-03-2020)
Old 01-03-2020, 12:20 AM   #3
gg1978
I am pretty sure that what is in both the transmission and diff is LS type gear oil, as that's that google returns for "valvoline 75w90 synthetic".
Old 01-03-2020, 04:00 AM   #4
radroach
Drives: car
No, this is incorrect. It just uses regular 75w90 gear oil.
I use Motul 300 in both my transmission and diff.
The Following User Says Thank You to radroach For This Useful Post:
Old 01-03-2020, 12:17 PM   #5
Vital
Drives: 2015 BRZ
My Subaru dealership used 80w-90 for the diff and its been great no issues.
https://parts.subaru.com/p/Subaru__/...A427V1800.html
Old 01-03-2020, 12:33 PM   #6
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
Pentosin MTF2 75w-80 in the trans, Motul 300 in the diff
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 04-12-2020, 10:36 AM   #7
chipmunk
Drives: _
+1 on the Subaru oil
About a year ago, my Subaru dealership put in OEM 80w instead of 75w. They told me that that's what's used in STi. All gear changes are great now, even in Michigan winters. So that's what I'll stick to next time.
For me, the key is to change the gears quickly before the rpms drop too much for proper engagement. Also, I don't wait till redline to shift into 2nd. My 2nd gear comes in at about 15mph. I also have a fraction-of-a-second overlap between clutch press & throttle lift-off, just to maintain the rpms for 2nd gear engagement.
Sent from a potato
chipmunk is offline   Reply With Quote
The Following 3 Users Say Thank You to chipmunk For This Useful Post:
callisto (04-10-2023), CSG Mike (04-21-2020), why? (04-13-2020)
Old 04-15-2020, 04:52 AM   #8
gg1978
Just as an update for this, i have had my local mechanic change the MT oil to Amsoil MTG 75W-90 synthetic GL-4 that i ordered direct from Amsoil's website.. So far i've noted the transmission makes less gear noise in the low gears (1 and 2), and a bit less resistance going from 1 to 2 when the oil is cold. It seems the syncro's are doing a better job as well, with the limited mileage i have put on it so far.
The Following User Says Thank You to gg1978 For This Useful Post:
humfrz (04-19-2020)
Bad ball joint;possible to just replace balljoint or do I have to replace control arm kev0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 01-03-2019 04:07 PM
Have to replace entire assembly to replace fuel filter? tobkin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 08-04-2017 03:26 PM
To replace rims or not replace? unlimited86 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 23 09-21-2015 01:12 PM
How much would a dealership charge to replace all four injectors? Astroboy Scion FR-S / Toyota 86 GT86 General Forum 30 06-24-2014 02:04 PM
Dealership is charging me $1725 to replace my OEM clutch for BR-Z venom8776 BRZ First-Gen (2012+) — General Topics 147 02-02-2014 09:34 AM
