Old 04-11-2020, 12:00 AM   #1
airrick
Drives: TRD R.S. 1.0 FRS
Dyno day. OFT Stg 2+ E85 Gruppe-s Uel
a
airrick is offline   Reply With Quote
Old 04-11-2020, 01:45 AM   #2
DarkSunrise
DarkSunrise's Avatar
Mustang dynos typically read lower compared with dynojets, usually around 12-13%, so you'd probably have made around 168-170 whp stock and 186-189 whp on e85 with a dynojet.
That torque curve looks pretty good too. No more torque dip and you're making 90% of peak from roughly 2700-7400 RPM, which is a wide spread.
2022 BRZ Build
2013 FR-S Build
DarkSunrise is online now   Reply With Quote
The Following User Says Thank You to DarkSunrise For This Useful Post:
Lantanafrs2 (04-11-2020)
Old 04-11-2020, 02:35 AM   #3
airrick
a
The Following User Says Thank You to airrick For This Useful Post:
Old 04-11-2020, 08:42 AM   #4
Lantanafrs2
Drives: 2013 frs red
Those numbers will improve with all e85 and a little time for the tune to settle in.
Lantanafrs2 is offline   Reply With Quote
The Following 2 Users Say Thank You to Lantanafrs2 For This Useful Post:
airrick (04-11-2020), PulsarBeeerz (04-13-2020)
Old 04-12-2020, 10:12 PM   #5
86TOYO2k17
Drives: 2017 toyota 86
12% gain, pretty low for E85, header, tune. Especially catless header.
OFT E85 is not flex fuel you are supposed to run tank down as low as possible.
It’s possible your E85 percentage was rather low, especially if it hadn’t mixed fully yet, and even after mixing 8gallon E85 (assuming its not low E85 % like a lot actually are) and 4 gallons of 91 is E60. Which is just out of the flexibility of OTS E85 tune, either case would cause you to run very rich on OTS E85 tune reducing potential power. Did you happen to record your AFR and or fuel trims on the run?
Old 04-14-2020, 09:31 PM   #6
airrick
a
Tuning AVCS without a dyno (AVCS for Gruppe-S header post 12 and 24) Tor Software Tuning 87 10-15-2021 12:04 PM
Shiv dyno day 2 in lewisville, OFT users custom dyno tunes malubawla Southwest 14 11-21-2015 02:53 PM
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 04:16 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 08:00 PM
Base line dyno figure (dynapak Hub dyno) gtauto AUSTRALIA 16 10-08-2012 09:06 AM
