Drives: 10 Series
SPARK PLUG GUiDE!
(If you’re skeptical about using something else, or do not plan to use something else, nothing is wrong with staying OEM, however this is meant to be informative, not a flame, troll thread).
Hello everyone, I’ve been researching on spark plugs recently, and bought my NGk 2309 iridium ix plugs, however they didn’t fit and I was SOL. Been chatting with a buddy Ryan of mine, who’s been looking up specs as well, and decided to make up this thread. Some stuff has been covered but I’m trying to compile all in one page so you don’t spend hours researching not knowing what to buy, and so you don’t have to clean off your plugs til you can get to a dealership because it’s sunday and they’re closed, and most autopart stores will not have what you’re looking for. (I’m no expert, mechanic, or anything of the sort) I love cars and researching stuff, if you are one of those however please give me your professional answers, I love to learn new stuff. Turns out our cars use 12mm thread x 26.5mm length the head is a 14mm Gap is 0.8mm/0.031” Electrode position at 8.5mm seems pretty important too, this makes me skeptical about interchangability. Denso ZXE27HBR8 - this helped me a lot thanks to their pn. Precious metal Z: 0.55mm diameter iridium Thread and hex XE: 12x14.0 Heat range: 27 Reach: it’s confusing but you’re looking for 26.5mm total length, 19.0 mm (Electrode position: 8.5 mm) 26.5 mm B: triple ground electrode R: 10k ohm resistor 8: 0.8mm/0.032” gap Denso Iridium tough (look like an economy version) VXEBH27 NGK 97537 racing plug I believe this will have to be gapped, they look extremely close, and their specs online say 0.032mm pregap, these will need a ton. (I will be installing them this weekend) NGK 93026 laser platinum iridium (GTR) plug the heat range is actually hotter than our stock ones, but uses the same gap. HKs has an article about it as well. That being said, it should be safe to go find yourself some economy R35 GTR plugs for those who care about gas milage and are in that vehicle for economical reasons.. C63 AMG use the same specifications as well but are 0.044” gap. HKS (you want the HL type) HL Type φ12×26.5mm 14mm NGK #8 SUPER FIRE RACING M40HL 50003-M40HL (one step hotter) HL Type φ12×26.5mm 14mm NGK #9 SUPER FIRE RACING M45HL 50003-M45HL (OEM heat) HL Type φ12×26.5mm 14mm NGK #10 SUPER FIRE RACING M50HL 50003-m50HL (one step colder) Champion spark plugs, couldn’t find any measurements on them, it may be just the gap that is the same as Fa20 requires, so it pops up under many universal part searches. Champion 7445 double platinum I’ve confirmed will fit. Hex Size (mm): 14mm Thread Size: M12 Thread Reach (In): 1.043 Inch Number Of Ground Electrodes: 1 Preset Gap (In): 0.039 Inch Preset Gap (mm): 1mm Resistor Plug: Yes Center Electrode Tip Material: Platinum Heat Range: 4 Insulator Height (In): 0.118 Inch Heat range is equivalent to NGK’s 9 and Denso’s 27. I hate Bosch plugs had a bad experience with them before, so I won’t be adding anything, feel free to though. Getting lazy now, so calling it quits. If you’ve confirmed anything else works or tried the gtr ones, etc. chime in! My only options I knew of before this were OEM, NGK racing, or HKS plugs. Retrofit plugs at your own risk, I’m not responsible if you mess your car up, or use Bosch plugs.
AKA koji187 on club4ag, Hachiroku.net, mr2oc, clublexus, zilvia, nico
13 FRS 10 series Edelbrock supercharged Last edited by Kojiap1; 02-28-2019 at 12:46 PM. Reason: Updated plug |
#2 |
SCCA SSC Scion FR-S
Drives: 2015 SCION FR-S
plugs
how did the 97537 plugs work out...
notice any differences? |
#3 |
Drives: 10 Series
Not really honestly, my plugs were in pretty good shape before I replaced them, felt like it idled smoother though
13 FRS 10 series Edelbrock supercharged |
#4 |
What year c63 amg?
Have you tried NGK 6043? Would it be better to have one with lower or higher heat range? |
#5 |
Drives: 2014 MY15 86 GTS
What is the factory OEM plugs? VXEBH27?
#6 |
Drives: Crapcan
ZXE27HBR8
I just bought a set and have they next to me in my desk to verify.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Halo_2 (04-10-2020) |
#7 |
Whats different between the two denso plugs.
#8 |
Drives: Nevermorange FRS
Since both are Iridium and the ZXE doesn't show up in Denso's part book, I think maybe the ZXE plug is made specifically for Subaru and the VXE is the Denso direct equivalent.
The only difference I can find are maybe the ground electrode and the resistor. OEM = Triple ground electrode (not sure of metal), 10ohm resistor VXEBH27 = Copper ground electrode, 5ohm resistor. I think it's also very possible the VXE P/N supersedes the ZXE P/N. I also noticed that NGK racing plug has a 5ohm resistor as well and but a smaller gap (Because racecar). I think if I bought the NGK racing plugs I would not alter the gap as they are made specific for these cars with that gap in mind.
PRO86 | WTCC | STL
| The Following User Says Thank You to rice_classic For This Useful Post: | Halo_2 (06-26-2020) |
#9 | |
Drives:
Hks spark plugs
So my question is which HKS spark plug is better the 40,45 our the 50?
#10 |
Drives: 2017 BRZ MT, 2009 Civic sedan AT
the only difference between VXEBH27 and ZXE27HBR8 is the resistor. One is 5k Ohm, another is 10k Ohm.
How does the difference in resistance affect the engine? |
#11 |
Drives: 22 BRZ limited
I don't think it has to do with engine performance, but electrical noise.
| The Following User Says Thank You to dragoontwo For This Useful Post: | Lantanafrs2 (02-19-2022) |
#12 | |
Drives: Dodge Patitas
Sent from my Pixel 3 using Tapatalk |
#13 |
From the NGK website.
#14 |
Drives: 2013 WRB BRZ
FYI, Just bought Denso 3536 from RockAuto. $13/ea. bar code has ZXE27HBR8..
![]() Sent from my iPhone using Tapatalk
| Spark Plug Options? | BRZach | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 27 | 08-18-2017 12:14 AM |
| Spark Plug Replacement | Dacfrs | Rocky Mountains / Great Plains | 4 | 03-21-2017 12:16 AM |
| P0351 bad spark plug... | Jaden | Engine, Exhaust, Transmission | 3 | 01-02-2016 10:19 AM |
| Spark Plug Time !!!! | RFB | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 11-24-2014 07:46 PM |
| Spark plug question | Wilsonk227 | BRZ First-Gen (2012+) — General Topics | 19 | 07-03-2013 12:57 AM |
