Old 04-06-2020, 08:53 PM   #1
Joveen
Joveen's Avatar
Drives: Bone stock
Steering creek
I started getting a steering creek/squeak when ever turned my steering wheel. I thought it was the Perrin lockdown bushings that had installed (3 weeks ago) that caused it. So I jacked up the car yesterday and seems the bolts weren't tightened down fully. The sound has left the driver side but still can hear it when I turn to the right every now and again.
I'm wondering if this might be a tie rod issue? Also the car pulls to right a little. So an alignment came to mind but not sure that would fix what I'm assuming. Also car feels bouncy. Not sure if it's because I'm still using winter tires.
Let me know what you guys think. Thanks.
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
Old 04-06-2020, 11:16 PM   #2
I'm thinking it's time to take your car in for an alignment -
Old 04-06-2020, 11:18 PM   #3
Joveen
Joveen's Avatar
Drives: Bone stock
I'm thinking the same thing too lol.
Old 04-07-2020, 03:02 AM   #4
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Old 04-07-2020, 06:13 AM   #5
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
May be the rubber seal on the steering shaft that's squeeking.
My '17 does it occasionally, I've seen a lot of customer cars do it, sometimes a bit of silicon based lube does the thing, sometimes not, I'm not even bothering with mine, it's not even worth bending down under the dash.
Old 04-07-2020, 06:26 AM   #6
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Sometimes the pathways water follows are the results of thousands of years of erosion. It's near impossible to change its path by force, you just need to work around it.
Depending on how rural you are, we're definitely in mud season; it may not be a bad idea to clean the undercarriage. Several bushings could just be contaminated with mud and grime that are causing this. Turn the music up!
Old 04-10-2020, 01:36 PM   #7
Joveen
Joveen's Avatar
Drives: Bone stock
Trust me bro the volume is party all day everyday lol. The remark exhaust makes up for it. That bad boy sounds like a 5.0.
Old 04-10-2020, 01:51 PM   #8
DarkPira7e
DarkPira7e's Avatar
I'll be posting sound clips once my car lives again! If you go to WBM2020 (if it's even on at that time) we'll have to be quad tip mafia
Old 04-10-2020, 01:57 PM   #9
Joveen
Joveen's Avatar
Drives: Bone stock
Yessir!!
Old 04-10-2020, 04:05 PM   #10
Lantanafrs2
Drives: 2013 frs red
Alignment time.
Lantanafrs2 is offline   Reply With Quote
Hello from oak creek, Wisconsin scion FR-S Scionshaun Great Lakes 9 02-11-2018 11:51 AM
warning about walnut creek toyota driftartist Northern California 15 07-07-2016 03:45 AM
warning about Walnut Creek Toyota driftartist Issues | Warranty | Recalls / TSB 5 06-11-2016 03:46 AM
BBQ: Seneca Creek - 10/20/13 BoostinIX Mid-Atlantic 19 10-21-2013 06:33 AM
NorCal: Stevens Creek Scion random Southern California 13 06-20-2012 12:44 AM
