Old 04-09-2020, 12:31 PM   #15
HaXx
Drives: jrsc_brz
To me it sound like your clutch fork is squeaking. My tob is on it's way out, but has different symptoms from what you describe. Yours only squeaks at engagement and during clutch pedal depression, but is silent at full engagement. The tob usually squeaks when the clutch is fully engaged and quiets when the pedal is pressed.
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
Old 04-09-2020, 01:30 PM   #16
Pbrown
Drives: 2013 Scion FRS Raven
Originally Posted by falcon_wizard View Post
Thanks for the feedback. did you swap out out just the clutch, or the tranny also ? In my case, the clutch and pressure plate are only 2 yrs old (35k kms or so)
Interesting, perhaps it is just a worn throw out bearing. Mine started off a little grinding noise when I depressed the clutch peda,l but over time (7 months) it got really bad. My mechanic suggested that the bearing was probaby the culprit but being seven years old I decided just to replace everything since the car was going to be apart anyway. Hope your repair goes smoothly.
Pbrown is offline   Reply With Quote
Old 04-09-2020, 04:47 PM   #17
I did not read all the responses.
That is 98% the symptoms of a TOB.
Replace it. Replace it soon!
Old 04-09-2020, 06:43 PM   #18
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Word.. my original TOB lasted about 25K, second one 50K, now I'm on the 3rd one (updated supposedly upgraded with new grease). the original version used uses grease that disintegrates quickly, allegedly. The new one used better grease, purportedly.
Intent > Content
Old 04-09-2020, 07:00 PM   #19
My first one lasted about 40K. The upgraded one was still performing well after another 100K.
Old 04-09-2020, 08:09 PM   #20
solidONE
solidONE's Avatar
The factory installed TOB
Mines not quire as artistic looking:
Intent > Content
Old 04-09-2020, 08:32 PM   #21
falcon_wizard
Drives: BRZ 2013
Thanks a lot to all of you... I will definitely start with that (TOB + Clutch inspection) before anything else... What makes it tricky to diagnose is that most videos of people with TOB failures were showing different symptoms/sounds, etc. But as PBrown is mentioning, what I am hearing may be the failure mode in its early stage...
I almost feel special having mine fail "only" at 120k+ kms! Once my perf shop reopens, I'll have them check this out...
Cheers and thanks again
falcon_wizard is offline   Reply With Quote
Old 04-10-2020, 01:57 PM   #22
falcon_wizard
Drives: BRZ 2013
I have taken a video of the noise. Hopefully this can confirm the TOB hypothesis. See link below:
https://zenfolio.page.link/JwREu
Old 04-10-2020, 10:35 PM   #23
solidONE
solidONE's Avatar
Does it only happen when you actuate the clutch pedal? If so, then its likely to do with the TOB, clutch fork, or slave master. Either way you'll probably need to get to the clutch fork and TOB to inspect them. No way around it, my friend.
Intent > Content
Old 04-11-2020, 11:38 AM   #24
falcon_wizard
Drives: BRZ 2013
To date, yes it’s really only when the clutch is actuated. I’ll get it checked as soon as my performance shop opens back up.
Old 04-11-2020, 12:57 PM   #25
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
DAYUM. That is some nasty looking chit. Did the the trans snout survive?
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 04-11-2020, 01:01 PM   #26
Capt Spaulding
Persona Non Grata
Were I you, I'd replace the TOB, the actuator arm/fork, and the arm pivot. Verus makes some really sexy looking replacements. Nobody will ever see 'em, but you'll feel good knowing they're there.
Old 04-11-2020, 08:04 PM   #27
solidONE
solidONE's Avatar
Until then, I'd suggest using the clutch gently and sparingly.
Barely, but good thing that's only a $30 part on his car. The TOB that replaced this one looked perfectly fine when it came out, but the ball bearings were loose inside the housing making baby rattle sounds.
Intent > Content
Old 04-15-2020, 01:00 AM   #28
airrick
Drives: TRD R.S. 1.0 FRS
Noise happens on mine when its cold and any pressure on the clutch pedal. TOB. Was gonna replace whole clutch but probably gonna replace the TOB,clutch fork, pivot arm thing
airrick is offline   Reply With Quote
Failing Sway Bar Bushing? jkost Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 04-20-2021 04:14 PM
Suggestion for a failing clutch replacement neoknux_009 Engine, Exhaust, Transmission 6 10-04-2019 09:08 PM
Failing 02 sensor toast Software Tuning 17 05-13-2019 08:56 AM
Do I have bad coil packs or a failing DI pump? xkalelx Forced Induction 16 03-15-2016 01:56 PM
Release Bearing or Pilot Bearing Cal3000 Engine, Exhaust, Transmission 11 01-27-2015 10:39 PM
