#29 |
Drives: frs
MT>AT
#30 |
Rice King
Glorious Honda.
Know my 5x120 GREATNESS PEASANTS. |
#31 |
Rice King
I am rejected....
Glorious Honda.
#32 |
Drives: frs
#33 |
#34 | |
Maybe, just maybe, NOBODY knows ...... ![]() humfrz |
#35 | |
Only happy when it rains.
Drives: series.blue
After the obvious answer it is all about going as far off topic as possible. That is how we roll. |
#36 | |
#37 |
Drives: 2016 Toyota 86 GT (Auto)
#38 |
#39 |
Drives: 2013 frs red
Drift office did a comparison of at vs mt whp awhile back
#40 |
Drives: ‘13 FRS
I won't be in the market for a while, but they've given me more solid numbers to ponder than anyone else to date. They've tried it all. I'm sure many others have as well but these guys are local to me. I'll use them moving forward.
#41 |
Drives: 2017 toyota 86
AT has about 2% more drivetrain loss or roughly 18% vs 16%. Drift office baselines where 164whp vs 168whp, It does appear they make peak power at the same rpm but for some reason the AT does drop off quicker after. Not sure why this would be, maybe something in the tune and can be tuned out. Mine doesn’t feel like it has such a noticeable drop off if any. My tuner also changed a lot of things with the AT. But i have never dynoed to know for sure if I know longer have this drop off.
The biggest difference is MT can launch, and 3-4-5 gears are essentially our 3-4 gears so mt has much closer gearing. Without launching they are almost identical 0-60 though, then the gearing the MT ever so slowly crawls away. A FD swap can mitigate some of the gearing disadvantage. Also the auto has been known to hold up to a lot more power then the MT. Either way modifying either MT or AT car will yield roughly the same benefits. |
#42 | |
Our AT is called A960e, it is used in the IS250 and several other cars, and the max torque it can handle is 300nm/221ft⋅lb Only!* The other issue is that the options to beef it up is almost none existing. Reference * https://www.gt86.org.uk/forums/forum...rbox-strength/ (go to the post by a member named Leeky) Sent from my ONEPLUS A6000 using Tapatalk |
| What is the difference between.............. | vmastros | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 05-29-2016 07:58 PM |
| TIS and GTS, any difference? | babybreath | Software Tuning | 1 | 03-28-2016 10:06 PM |
| bra difference from frs | shift2launch | BRZ First-Gen (2012+) — General Topics | 5 | 01-22-2015 01:00 AM |
| Every difference between the MT and AT | BlueDubbinTDI | Engine, Exhaust, Transmission | 38 | 09-04-2013 09:32 AM |
| LED vs HID: what's the difference? | GhostofAkina | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 04-06-2013 07:23 AM |
