Old 04-04-2020, 02:10 PM   #15
Pat
Pat's Avatar
Drives: 2023 BRZ
The drawback to the Bilsteins is the progressive rear spring isn't ideal for everyone.
- Andrew
That was my main concern before buying the B16s from you guys. But after driving them that concern was almost entirely eliminated. What about the progressive rear springs of the B16s on an 86 (specifically) makes them not ideal for someone? I have some thoughts of my own, but would especially like to hear your detailed opinion.
TIA, Andrew.
Old 04-04-2020, 05:53 PM   #16
gravitylover
Ohlins R&T and Bilstein B16 use monotube rears.
Both are quite good and we have experience with both. The drawback to the ohlins is the softer rates don't work super well with the limited travel. The drawback to the Bilsteins is the progressive rear spring isn't ideal for everyone.
Again both are really good shocks for a fun street car. They have limitations like most other things but do a good job overall.
- Andrew
What is it about the progressive rear spring that makes the Bilsteins less than ideal? I figure it won't be long before my car needs some new suspension bits, it's at ~135k miles (but obviously not seeing much use at the moment).
Old 04-05-2020, 06:35 PM   #17
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Non-linear spring means you get a different stiffness at different suspension loadings, that can make the car hard to predict in various scenarios, it may act wildly differently when you hit a bump at 1.5g lateral vs. 0.7g lateral while a linear spring will largely act the same when it comes to suspension response, which is good for racecars (driver understands how car will respond and can anticipate needed correction), but probably not great for street cars (fuck I spilled my boba even though I was going slow af).
That being said, anything that uses a long bump stop in the rear will have some level of progressive spring, especially stock. Bilstein has you re-use stock bump stop so in addition to the coil spring progression you have the bump stop progression as well. If you look at the RCE T2's they have a very small bump stop that exists (mostly I believe) as a safety measure to prevent harmful bottoming. If you look at KW V3 kits they spec a softer spring and more bumpstop, even though the spring is linear their bump stop introduces progressive behavior not so different from the B14/B16.
The stock setup is pretty progressive due to some long bumpstops, if you don't hate the stock progressive spring odds are the Bilsteins or KW's wouldn't bother you. Tuned well everything works in harmony, as an average amateur odds are if you're slow on course a linear rate spring isn't going to magically make you faster, however with experience you can pinpoint areas where the suspension may not act as desired and tweaking spring rates and damping profiles can yield benefits to you as a driver.
I am interested in giving my B14's another shot, I wonder if I can get them converted to the B16 adjuster without breaking the bank...
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
EB86 (04-06-2020), gravitylover (04-06-2020)
Old 04-05-2020, 06:51 PM   #18
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I've not read one good thing about the Bilstein single adjustable shaft. They are not very consistent. If anything, you should be able to adapt a better 14mm adjustable shaft and bleed mechanism for less money. (taiwan) Or if its the same diameter OD shaft and stud mount for the pistons (8 or 12mm) on your megans, you can transplant. The guy that built your shocks can probably do this one hand tied behind his back.
They are 'shit' is what I've heard.
Intent > Content
Old 04-05-2020, 07:47 PM   #19
Pat
Pat's Avatar
Drives: 2023 BRZ
Interesting. I've read just the opposite. When they came out with the new adjustment mechanism a few years ago they got all kinds of praise for it, and how linear it was relative to the competition. I wish I remembered where I read that, but it's out there somewhere. You may know more about this than I do, solidONE, but I have no complaints with them.
The Following 2 Users Say Thank You to Pat For This Useful Post:
solidONE (04-05-2020), strat61caster (04-05-2020)
Old 04-05-2020, 07:58 PM   #20
strat61caster
Check the dates on your sources for those reviews. DG/Far North for example hasn't been involved in motorsports for about fifteen years which is the only one I can recall trashing the old Bilstein adjuster, as Pat mentions they came out with a new design about 8 years ago iirc.
Edit: and their double adjustable is legit, there was a conversion using their shafts a few years back here.
https://www.ft86club.com/forums/showthread.php?t=100216
ineedyourdiddly
Old 04-05-2020, 08:00 PM   #21
solidONE
solidONE's Avatar
Is that right? Fatcatmotorsports is pretty on top of all things Bilstein. I recall him mentioning about the bleed mechanism. Was not aware they updated that long ago.
Can you link me to your source?
Take me to your leader?
Intent > Content
Old 04-05-2020, 08:03 PM   #22
solidONE
solidONE's Avatar
Can you link he post? Cause I see pics of Bilstein's MDS shaft which is pretty badassed and also $500 a piece. Where is the talk about the single adjust?
Intent > Content
Old 04-05-2020, 08:24 PM   #23
strat61caster
Here's >600 page catalog from 2010 when they came out with pss10 from what I gather.
https://www.google.com/url?sa=t&sour...1vRsIo4q9fw3U9
When I talked to fcm about 5 years ago he didn't have any experience with the pss10 preferring to stick with revalving the non-adjustables.
Dynos are certainly scarce, here's one;
https://forums.m3cutters.co.uk/threa...r-sale.197264/
The criticism I've heard second hand about the current Bilstein single adjust is that it doesn't offer a wide range of adjustment and is more a fine tuning advice, at the amateur level us hack jobs sometimes need a bigger change in feel to assuage our egos that we've done something different.
ineedyourdiddly
Old 04-05-2020, 08:24 PM   #24
Pat
Pat's Avatar
Drives: 2023 BRZ
I read it years ago while researching my purchase decision. You're probably just as capable of doing a search as I am. Sorry I couldn't be of more help.
The Following User Says Thank You to Pat For This Useful Post:
Old 04-05-2020, 08:26 PM   #25
Pat
Pat's Avatar
Drives: 2023 BRZ
Huh. I don't have much experience with adjustable dampers, but I'm not a novice driver, either. I can tell you the range available with the B16 are as much as I'd ever want with the supplied springs.
Old 04-05-2020, 08:28 PM   #26
strat61caster
Cheers to that, last we talked I don't think you had spent time playing with them yet, glad to hear you like them!
ineedyourdiddly
Pat (04-05-2020)
Old 04-05-2020, 09:03 PM   #27
strat61caster
@solidONE
https://f87.bimmerpost.com/forums/sh...51&postcount=3
Found another forum post with PSS10 dynos, BMW chassis, whole thread is neat with a couple different dampers dynoed so you see some different philosophies and capabilities. Anyway, I stumbled across some S2ki posts bashing the Bilstein for an 'inconsistent adjuster' which their criticism was one click out of 10 doesn't necessarily create a 10% change in damper stiffness across the range, you get some big changes going between clicks 9 and 10 and it looks like going from say 2-3 isn't going to feel like a change at all.
As long as it's repeatable and predictable that's a decent adjuster imho, it's a damper on a budget for certain and there are sacrifices made but it's a contender.
ineedyourdiddly
Old 04-05-2020, 10:35 PM   #28
solidONE
solidONE's Avatar
@solidONE
Rear adjustment looks a little funky toward the harder end, but the front one looks like a good spread. Maybe the amount of bleed in the shims is effecting the adjustments response, cause I cannot think of a reason why the front and rear adjustment bleed orfice and mechanism would be different. Not nearly as bad as I imagined.
Intent > Content
Koni Yellow vs. Bilstein B6 vs. Bilstein B8 shattered_memory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 01-04-2017 11:22 AM
STX Bilstein Double Adjustable Package - Bilstein PSS with Dual Bleed Shafts FRSport.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 02-25-2016 12:50 PM
Bilstein B6s and B8s speargunsandracecars Suspension | Chassis | Brakes -- Sponsored by 949 Racing 61 05-09-2014 08:04 PM
Bilstein I-RC C3 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-16-2013 11:45 AM
bilstein PSS mokinbird87 Southern California 1 10-29-2013 10:12 PM
