Old 03-28-2020, 03:43 PM   #21659
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
Originally Posted by DarkPira7e View Post
It fits well, seems lighter than stock and looks awesome. I won't get to hear it for a few months as I put my build together. I like that the hardware you're given is zinc coated
Damn must suck not being able to hear it for a while. Sounds good from videos I’ve seen and looks great. Considered it for a while since it’s different, but on the fence about it.
Will BRZ is offline   Reply With Quote
Old 03-28-2020, 04:04 PM   #21660
dnieves
Drives: FR-S 10 Series
Changed the cabin and air filter just in time for me engine tear down this Monday to determine if my CEL #P0018 is caused by a stretched timing chain or worn down gear on the crankshaft (as everything else turned out ok).
Question: when you polish your steel lines and throttle body do you use a Dremel and a polishing compound/paste? If so, what tip do you put on the Dremel and do you go through them like water? Also, how do you keep it from getting dull afterwards? Clearcoat over it?
dnieves is offline   Reply With Quote
Old 03-30-2020, 06:28 AM   #21661
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
My P0018 was caused by a stretched chain. It came apart a few weeks after I started getting this code intermittently.
Old 03-30-2020, 06:40 AM   #21662
scottman
scottman's Avatar
Drives: 13 mt fr-s
How many kms?
scottman is offline   Reply With Quote
Old 03-30-2020, 06:51 AM   #21663
DarkPira7e
DarkPira7e's Avatar
Originally Posted by scottman View Post
How many kms?
No idea, Toyota put the used motor in because they blew my engine twice doing the recall, they wouldn't tell me. I'm assuming in excess of 200k KMs
scottman (03-30-2020)
Old 03-30-2020, 08:42 AM   #21664
theneptune86
Drives: Neptune Blue 2019 Toyota 86
Finally broke out the DAR paint pen and touched up my drivers side pillar--massive stone chip has been sorted, for now!
Next I start attacking the front bumper...shoulda got it clear bra'd like I said I wanted to...
2019 Neptune Blue Toyota 86 • Gruppe-S UEL Catless Headers • OFT Stage 2 Plus (91)
theneptune86 is offline   Reply With Quote
The Following User Says Thank You to theneptune86 For This Useful Post:
MJones_RB (03-30-2020)
Old 03-31-2020, 08:00 AM   #21665
dnieves
Just found out it was caused by a timing gear that wore out (?!?!), changed both. Everything else is ok, I wonder if I should do spark plugs since the engine is out?
When did your chain stretch and break (miles/years)? Did you suffer catastrophic engine damage (aside from the damage to your wallet)? Are these interference engines? Until now I didn't know a timing chain could stretch and break without oil starvation. What did you do and did they determine root cause?
Old 04-01-2020, 02:54 PM   #21666
etherdude
Drives: 2020 Hakone Edition, 2015 FR-S
In the last week, I have done lots of things to my 2015 FR-S and 2020 Hakone Edition 86.
  1. Shipped the FR-S on Tuesday 3/24 to my nephew in California on an enclosed transporter. It should arrive on Thursday, 4/2.
  2. Had the 16x7 Focal X wheels restored. Color change from satin black to a medium grey with bronze-ish overtones. These will look great on the Hakone next winter. Plenty of tread left on the 205/50x16 Blizzak WS80s
  3. Ordered new lugnuts and 8-spline socket from Tirerack. The old lugnuts were getting rusted and I didn't trust the threads any longer.
While it is extremely unlikely I will get many miles on it this year, at least I will be ready for winter! And for the first time in over 20 years, we have only 2 cars (2018 RAV4 Hybrid, 2020 Hakone 86), so both will get to live in the garage!
etherdude is offline   Reply With Quote
Old 04-01-2020, 02:58 PM   #21667
Ashikabi
Ashikabi's Avatar
They are interference engines. You lose a timing chain and you're fucked. Yes, you should do the plugs.
Sent from my ONEPLUS A5010 using Tapatalk
The Following User Says Thank You to Ashikabi For This Useful Post:
humfrz (04-02-2020)
Old 04-02-2020, 06:05 PM   #21668
Ashikabi
Ashikabi's Avatar
Raised my shift knob 20mm
Old 04-02-2020, 07:49 PM   #21669
DreamSpeedBRZ
Drives: 2017 86
Took this picture today in preparation for making an add. But then changed my mind.... For now...
What type of paint did you use to paint the fluid caps and clamps? Is it durable? Primer or clear coat? I want to do this soon.
DreamSpeedBRZ is offline   Reply With Quote
Old 04-02-2020, 08:46 PM   #21670
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Clean with solvent. Spray adhesion promoter. Spray two coats of color. Spray three costs of clear. My job looks great. The paint is fairly durable with the layers I sprayed.
Primer is great for parts that are not plastic. Adhesion promoter is great for plastic parts. I used automotive clear coat.
You can get EVERYTHING you need here. I also bought a few cans of D6S paint. I have touched up several things with it. It matches perfectly.
https://www.automotivetouchup.com/
I LIKE TIRES!
DreamSpeedBRZ (04-14-2020)
Old 04-02-2020, 09:13 PM   #21671
Painting engine parts gold brings to mind a waaay back in the day story.
When I was 15, I painted several engine parts (valve cover, air cleaner, stuff like that) of my 1948 Chevrolet, gold. I even painted the circular access door to the front of the radiator (silver in the picture). I then wrote my GF initials (KH, for Kathy Hart) in white paint on the access door.
The next year, when I was 16, my new GF (Kathy Harvey - KH) wanted to see the mill in my car (that's a lie - she didn't want to see it, I just wanted to show it off). As I raised the hood, I had this sinking feeling about the initials that I had inscribed on my engine part.
Then, it dawned on me that the initials were the same (KH). What a relief!
OK, OK, leave me be - it's an exceptionally slow day here in Puyallup -
jcw99 (04-03-2020)
Old 04-03-2020, 05:27 PM   #21672
Bobharp
Bobharp's Avatar
Drives: 86 Hakone
TAGS
I ventured out during our current pandemic ‘Stay At Home’ to pick up my vehicle license plates. Essential right!
While any trip in my venturing forth in my baby is deemed essential by me others (the law) might object.
I'm Bonafide now!
Bobharp is offline   Reply With Quote
The Following User Says Thank You to Bobharp For This Useful Post:
humfrz (04-03-2020)
