Old 04-01-2020, 02:47 PM   #10809
86TOYO2k17
Drives: 2017 toyota 86
Originally Posted by BlOody_BoOger View Post
Any one got a clue why I'm making such lil power???
I'm in e85 openflash phantom original tune.
Ft86 UEL headers
Grams throttle body
AEM e85 fuel pump
Aftermarket over pipe
Catless front pipe
And full catback exhaust.
I thought atleast I would be making
225whp/210tq
The phantom is pushing a good 4.5 psi at Max sometimes even 4.7 so I'm confused.
Lots of reasons.
1. Every dyno reads different, one car can go dyno 145whp on one dyno then 170whp on another with zero changes otherwise. So don’t compare your dyno to someone else unless its the exact same physical dyno not even just dyno type. Should only look ar and compare your baseline before and after % increase compared to someone else baseline before and after % increase.
2. Whats more important making 400whp on a dyno but taking 11sec 60-130 or 350whp on a dyno but take 10sec 60-130. Ultimately what matters is actual performance.
3. It looks like you did a pull in 2nd then 3rd? You should be doing it in 1-1 gear 5th mt 4 at. And then using the correct correction factors.
4. ESC doesn’t make high peak WHP it does however make decent low end torque. Which by your graph you are making really good torque downlow. But you probably make 1psi at 7k rpm which would only add about maybe 8whp. So peak whp isn’t the greatest compared to full bolt ons.
5. Openflash’s dyno has the highest baseline reading dyno i have ever seen. Makes the after dyno look really good if not compared to baseline. I believe they baseline at 176+whp. So don’t compare to them unless looking at % increase, and even then i believe its a custom dyno tune, and posted by the company that makes the esc kit so marketing gimmicks involved most likely. Edit: looks like that cars baseline was 171whp to 217whp. About 27% increase.
6. I think for an OFS tune you’re probably doing just fine.
Old 04-01-2020, 05:28 PM   #10810
Kodename47
Kodename47's Avatar
Drives: UK GT86
Those gears are probably too fast for most on the road though..... the data points look like it's Virtual Dyno.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-01-2020, 05:47 PM   #10811
86TOYO2k17
It looks like a real dynojet dyno?
Old 04-02-2020, 05:03 PM   #10812
Kodename47
Kodename47's Avatar
Drives: UK GT86
Look in the top left ("Generated by Virtual Dyno")
Plus the layout of the screen and the data points are representative of what I'd expect of a 3rd gear pull
VD is very sensitive to all the data being correct and, as per a normal dyno, only good for comparisons if you make all things equal; the road, weight, settings, gear, temps etc.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-02-2020, 06:32 PM   #10813
86TOYO2k17
Interesting, maybe it is. But he hasn’t chimed back in. Not sure why anyone would take a virtual dyno seriously, at least not as an accurate representation of real numbers. Maybe as an easy way of self testing your own gains from mod to mod assuming you have all settings, conditions, road, etc.. the exact same. But definitely not comparing to someone else’s real dyno. That’s why I automatically assumed it was real. But maybe your right.
Old 04-06-2020, 03:59 PM   #10814
BlOody_BoOger
BlOody_BoOger's Avatar
Drives: Hot lava FRS Monogram Charizard
I was gone for a lil while oops, it is a virtual Dyno only reason why I assume it to be accurate is because a buddy of mine who did the virtual Dyno, actually had his car on a Dyno and the numbers where roughly +3-3 from his virtual Dyno runs. So taking that into consideration I assume if I was to get on a Dyno I would still se similar numbers. But I guess untill I do it there's no real telling. I wonder if having larger heavier wheels can be the culprit. I put in about 5lbs per wheel when I got rid of my stock wheels.
BlOody_BoOger is offline   Reply With Quote
Old 04-06-2020, 04:08 PM   #10815
86TOYO2k17
Unless your car is slower than it should be. I wouldn’t worry.
His virtual dyno may have had more accurate parameters entered in then you did and also just so happen to use a dyno that produced a similar number. As he could use a different dyno and still read + or - 10% in comparison.
Old 04-06-2020, 04:56 PM   #10816
BlOody_BoOger
Ummm disregard my last message initial message lol. So I brought up the wheels to my buddy and he thought I was on stock wheels and tires. So after changing the parameters to 245/40/18 and adding 5lbs of rotational inertia per wheel. These are the new numbers.
Old 04-07-2020, 02:02 AM   #10817
mrjj
Drives: GT86 2013
Would you mind telling us exactly what patsmeters you are using in Virtual Dyno?
mrjj is offline   Reply With Quote
Old 04-07-2020, 09:56 AM   #10818
86TOYO2k17
your 1st one looked more accurate Phantom ESCs don't make more then about 210whp unless on a hero dyno.
Full bolt ons E85 is hitting 200whp, ESC makes about 1.5psi at peak WHP. that would be roughly 210whp. ESCs do make a lot of torque though as down low at peak torque they are making about 4psi. 210whp/190ftlbs is what i would expect with full bolt ons e85 and ESC.
But either way at end of the day its all just an arbitrary number especially without a baseline to compare and what matters is real world performance numbers.
To attempt to make a virtual dyno as accurate as possible it is vital you put in 100% accurate information. you would need to weigh your vehicle, get the exact drag coefficient, gear ratio, tire diameter etc...
Then find as long and flat of a road as possible and in the highest gear you can do on that road, do a run in both directions trying to start and stop at the same points, to account for any wind as well as any slight slope, even a 2% grade will be hard to tell from inside the car but make acceleration a good bit faster. Doing it in both directions you can average the two runs so the real world road conditions aren't a factor.
Old 04-07-2020, 10:08 AM   #10819
BlOody_BoOger
When it comes to what he inputs it asks for it all on the vdyno but its
Weight of driver
Weight of car
Tire diameter
Air tempature
Third gear pull
The data log was done using OFT and on there I have
Engine speed
Engine load
Throttle position
Maf
Oil temps
Stft
Ltft
Adv multi
Afr
Boost
Timing
And I can't remember what else right now.
Old 04-07-2020, 10:21 AM   #10820
BlOody_BoOger
Here's a quick video with my with a couple of friends in Mexico. This is just for comparison
The wrx mods
-Custom Dyno tune
-23psi
-Catless Downpipe
-Boomba racing Bov
-285whp/315tq
Focus ST mods
-Depo racing Intercooler
-Woosh Intake
-Woosh hybrid Turbo
-25psi
-Thermal catback
-Dizzy e30 Tune
-261whp/282wtq
Old 04-07-2020, 10:41 AM   #10821
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
The wrx mods
-Custom Dyno tune
-23psi
-Catless Downpipe
-Boomba racing Bov
-285whp/315tq
Focus ST mods
-Woosh Intake
-Woosh hybrid Turbo
-25psi
-Thermal catback
-Dizzy e30 Tune
-261whp/282wtq
Nice vid. need more empty space to full Throttle
i still love my ESC
Old 04-07-2020, 06:26 PM   #10822
SHWNBRZ
Drives: '08 MX5 6MT & '15 BRZ Premium 6MT
That looks like a fiesta st. ��
SHWNBRZ is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
