Drives: White BRZ Limited
SOLVED: Window auto up down upon entry feature stopped
Hey guys no luck with the search function.
Working on my car yesterday for over an hour. Has the driver door open, while i was working i heard the window move a little bit all by itself im assuming it was closing itself. Anywho i closed the door and the window stopped moving up and down, Now im not saying its in operable. Im saying when you approach the car and you grab the door handle the window drops down about 3/8" inch and then you get in and close the door and it seals all the way back up. This function has stopped now. The window rolls down, up, and all the way down and all the way up. The auto 1 down and and 1 up feature still work perfect. its the window entry feature that is not working. Any suggestions? Last edited by Sgtfluffy16; 04-02-2020 at 09:21 AM. |
#2 |
Drives: 2019 Toyota 86 TRD SE
Hey, fellow Toyobaru owner! I'm always trying to learn what issues other twin owners are facing with their rides, just in case I encounter a similar issue. Your problem intrigued me, so I did a search to see if there was a possible solution outside of our forum. There's a guy on YouTube who had a problem with his passenger-side window, and in his video he explains how to reset the window system. I'm including the video link in my reply in the hope that it helps with your issue. Fingers crossed for a successful outcome! https://www.google.com/search?q=toyo...eGgge25I34Aw20
| The Following User Says Thank You to OsageJJ For This Useful Post: | humfrz (04-01-2020) |
#3 | |
#4 |
No luck... I could not find a fuse either. But I have discovered though. The driver side door courtesy light does not work. Neither does the dome light come on whenever the driver side door is open. Everything functions properly on the passenger side. So there's got to be something weird that happened while leaving the door open for about an hour
#5 |
Drives: 22 GR86, 13 FRS, 15 BRZ, 13 FRS
Dumb question but is your battery voltage low from leaving the door open? Try starting the car. The windows automatically stay in that mode if the battery voltage gets low.
#6 |
#7 | |
#8 | |
#9 |
#10 |
Famous Potatoes
Drives: '15 ultramarine
No up and down, no courtesy lights.
Sounds like the switch that says the door is open/closed is not working. |
| The Following User Says Thank You to Sapphireho For This Useful Post: | humfrz (04-01-2020) |
#11 |
#12 |
Famous Potatoes
#13 | |
Somewhere on this forum, there is a wiring diagram - I think ol @Ultramaroon knows where it is, maybe he will clue you in - iffen he ain't in one of his cranky moods - ![]() Next I would check the thingie on the drivers side door that lets the car know when it is open and closed. Maybe it's stuck? It looks like a black rubber button on the door jam. PS - I just saw where ol smarty pants @Sapphireho beat me to it, while I was out in the garage looking for it -
| The Following User Says Thank You to humfrz For This Useful Post: | Sapphireho (04-02-2020) |
#14 |
Thanks for the info guys, I will check both of them out. Yes, might be 6 years old. But the car has less than 13,000 miles on it. And lives in my garage
| Window Sliding Feature - Randomly Stuck | soulreapersteve | Issues | Warranty | Recalls / TSB | 4 | 03-06-2016 06:36 PM |
| Auto Light Feature, Maybe | kmbkk | DIY (Do-It-Yourself) Guides | 47 | 05-20-2014 07:54 PM |
| Auto Windows Safety Feature | Chad86 | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 03-29-2014 08:06 PM |
| Simple Shut Window Feature Not Working on Driver's Side | Gimagination | Issues | Warranty | Recalls / TSB | 21 | 05-08-2013 11:59 AM |
| Issue with Simple Shut Window Feature | Jayp | Issues | Warranty | Recalls / TSB | 5 | 07-26-2012 11:18 PM |
