| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#113 | |
Drives: 2013 FR-S, 2007 Acura TL 5AT
I currently run 0w40. I've thought about trying 5w30 or 5w40 to see how my pressures react at those higher temps. Maybe, my next oil change I might give a different weight a try. I definitely agree that a quality oil even at 270 would resist breakdown quite well. It's really the pressures that have me a bit concerned.
2013 FR-S Raven, AutoX/Track/Daily Driver
Build: Angel's Dual Duty FR-S Build YouTube: Angel Christov |
#114 |
Drives: FR-S Whiteout
If you go up a steep enough road in 2nd and 3rd gear at a spirited pace for 20-30 minutues straight you'll hit those temps with no oil cooler. Brake pads will fade and tires will get greasy just like on a track.
Intent > Content
cowardice is the mother of cruelty. |
#115 |
Drives: BRZ 2013
I had done some good before and after measurements when installing the Jackson dual radiator water to oil cooler. My finding ls were as follows:
-with regular 0-20 oil, driving at high rpm (say at 4000rpm or above) on the highway for 20mins or more can really crank out temps to 250F and up to 280F. I found its more a factor of rpm rather than speed. -my recommendation would be for anyone NA Or FI that likes to drive at high rpm for extended periods to at Least go to a quality 5-40 oil. i would strongly recommend an oil cooler for Someone driving extensively at 5000rpm or more, such as on track. -for my case, the dual jackson rad/oil cooler was very effective for an all year round solution , and kept temps below 240F (with 5-40 oil) even in high demand situations , while helping warming oil up in the winter time as well. Link to my measurements with and without cooler with high rpm (low speed) driving on the highway: https://www.ft86club.com/forums/show...104943&page=24 Last edited by falcon_wizard; 04-09-2020 at 06:44 AM. Reason: Added link to thread |
| The Following User Says Thank You to falcon_wizard For This Useful Post: | solidONE (04-09-2020) |
#116 | |
If I had to do it again, I wouldn't change a thing. Click on the image for full size
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Teseo (02-21-2023) |
| Head unit depth | bluenoserforever | Electronics | Audio | NAV | Infotainment | 0 | 07-25-2013 09:50 PM |
| Depth Behind Radio Opening? | kmbkk | Electronics | Audio | NAV | Infotainment | 0 | 10-07-2012 11:21 PM |
| Detailed In-Depth Tour of the BRZ | Subaruwrxfan | BRZ Photos, Videos, Wallpapers, Gallery Forum | 49 | 06-22-2012 05:38 PM |
| Depth of speed | DIG1992 | Other Vehicles & General Automotive Discussions | 6 | 05-22-2012 01:13 PM |
| AE86: An In-Depth Look at A Legend | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 01-26-2010 10:44 PM |
