Old 03-26-2020, 04:40 PM   #71
erebuswarrior
Drives: 2015 Asphalt BRZ
To clarify, my tune is setup for rev limit at 7600RPM, however, tune has soft rev limit before it that pulls timing and power a bit before 7600. I also have Ecutek racerom so I also have FFS and I primarily use that and shift at about 7200-7400 if I'm on the stretch I can hit over 130MPH. I have the shift light set to about 6500RPM as a peripheral reminder of where in the RPM's I'm at. Generally I have to max at 7200-7400 1-4 to reach 130 on the straight. Shifting at 6800-7k makes me sit in 5th gear harder, or I can do 7400 1-4 and hit 130 a lot easier. I have catless EL headers and carry power through the entire top end. I also don't redline every chance I get. Driving around town and highway shifting by 4k-6k is usually fine for me depending on traffic etc. When I take it to the mountains I usually sit at 5-6k in turns when going fast, but again can cruise at 3-4k it's just not as fun. Gotta carve the curves at max traction for true fun. I also have different wheels tires setup. Stock wheels with Toyo Extensa HP A/S 215/45 that spin for days if I use LC at even 3k rpm. And Enkei RPF1 17x9 +35 wrapped in 245/40 Hankook Ventus V12 Evo2's that LC set to 4k rpm I still get wheel spin for a second or 2, and shifting 1-2 @ 7k rpm I'll get a little traction loss because i use FFS so it carries the power through instead of letting off the accelerator without FFS.
erebuswarrior is offline   Reply With Quote
The Following User Says Thank You to erebuswarrior For This Useful Post:
NoHaveMSG (03-26-2020)
Old 03-26-2020, 04:41 PM   #72
86TOYO2k17
Drives: 2017 toyota 86
I wonder why -
4.3 fd swap, os giken lsd, stage 2 valve body.
Like an idiot i left trans filter o ring in old valve body and shipped back already for core return. Taking a week to get one shipped from subaru.
The Following 2 Users Say Thank You to 86TOYO2k17 For This Useful Post:
humfrz (03-26-2020), NoHaveMSG (03-26-2020)
Old 03-26-2020, 04:44 PM   #73
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That is likely my next mod.
Old 03-26-2020, 05:01 PM   #74
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Because the dive bar is closed and your income stream is diminished?
I don't know how I'm going to pay my bills.
Old 03-26-2020, 05:07 PM   #75
Maybe you can convince the dive bar management to place the machines outside along the side of the bar, so as you can drive thru play -
Old 03-26-2020, 05:45 PM   #76
Tokay444
I'm talking PD off, not long hold off.
I mean no offense when I say this, but if you think that long hold is "off" you have never had to trail brake the car or taken curb at speed on throttle before. It makes a difference. My first year of tracking I was going through front and rear brake pads at close to the same rate when using the long hold due to EBD and E-diff interference.
LOLOLOL
Old 03-26-2020, 06:05 PM   #77
erebuswarrior
Anytime I drive the car I hold the traction button down for the 5 seconds to turn off oem fuel cut traction control. It's so dumb. Ecutek BT kit let's you toggle pedal dance track mode anytime you want on your phone in app which is super cool but I haven't tried it yet with hard braking. With no pedal dance I can hit 100mph and fully apply the brakes without abs kicking in. Only time I've had abs kick in is in the snow and wet enough roads.
Old 03-26-2020, 06:13 PM   #78
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Non of the modes, including pedal dance, effect ABS. You need to pull the fuse to disable ABS.
Even with the long press trac off, there is still some stuff going on in the background. Here is a long thread on it. There are dozens but this is one of the more comprehensive.
http://www.ft86club.com/forums/showthread.php?t=34453
Old 03-27-2020, 08:23 AM   #79
Tokay444
System was revamped for 2017 and up to have less/no interference with long press.
Old 03-27-2020, 09:58 AM   #80
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
The Following User Says Thank You to Spuds For This Useful Post:
SuperTom (03-27-2020)
Old 03-27-2020, 10:37 AM   #81
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
But this car is so easy and cheap to wrench on.
As someone who did just build their engine, this is laughable compared to other cars.
B T is offline   Reply With Quote
Old 03-27-2020, 10:51 AM   #82
86TOYO2k17
Haven’t opened the engine yet. But done just about everything else possible that can be done and everything was pretty easy. Obviously an older car something like a civic, miata, celica, etc.. might be cheaper/easier but as far as newer cars go this is pretty easy and cheap to wrench on.
Old 03-27-2020, 10:54 AM   #83
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yes I know. It was my understanding that there was much less interference on the 17'+, but there is still some aids. There is quite a bit of conflicting info on it. I think EBD is still active with track off on the 17+.
This chart is good but doesn't mention EBD
https://www.ft86club.com/forums/show...75&postcount=1
This still shows VSC with trac off so I don't know how much I trust it
https://practicalmotoring.com.au/car...baru-brz-work/
Old 03-27-2020, 01:53 PM   #84
Tokay444
Pull the fuse and be done with it all.
VEX Calgary built an fa20 for me and here are the results olsonpg CANADA 4 11-19-2019 01:09 PM
Built FA20 by Outfront motorsports? rixter145 Engine, Exhaust, Transmission 15 10-20-2019 04:43 PM
Built FA20 by DSport? StraightOuttaCanadaEh Engine, Exhaust, Transmission 26 08-31-2017 04:41 PM
What do you wish was built/available for the FA20 platform but is not? themajesticone Scion FR-S / Toyota 86 GT86 General Forum 14 07-14-2015 09:36 PM
what oil for BUILT MOTOR BOOSTED FA20 charged86 Engine, Exhaust, Transmission 7 02-19-2014 02:25 AM
