Old 03-26-2020, 01:26 PM   #1
gt7877
Drives: turbo frs
Question back to stock
Dear all
I have removed my turbo kit form my FRS + Ecu +imo ecu
And I install it to my friend FRS
I remove both ecu because it has ecuTek tune ..
My call ID was
ZA1JB01C
And I run the turbo car with no issue..
Now my issue
I have install the second car ecu + imo ecu to my car .
Call ID at this ecu :
ZA1JB01G
I have only install Cold air intake
And OFT STAGE 1 TUNE
but the issue now
When RPM hits 4k I hear something like knoking at driver side
It's start around 3900k - 4100k
Then gone
Only happens while driving ..
At stop and revs all r good
Any idea
Or could be the tune issue
Can I use other CID ??
Thnx
gt7877 is offline   Reply With Quote
Old 03-26-2020, 01:49 PM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
I'd check two things - if some exhaust bit starts rubbing somewhere due thermal expansion (thus harder to diagnose when stationary/cooled off except for already made contact marks). And also state of direct injector seals.
gt7877 (03-26-2020)
Old 03-27-2020, 06:04 AM   #3
tomm.brz
Drives: brz 2017 hksv2
B01G doesn t exist, check better
anyway the Sound is normal with stage1 cam timing, it s just a resonance induced by the cam system
Taking car back to stock - can I use the upgraded MAP sensor with stock ECU tune? Foobar Software Tuning 17 07-01-2019 10:26 AM
Cat-back vs axle-back on stock headers drz400dude Engine, Exhaust, Transmission 6 02-24-2017 06:03 PM
DFW going back to stock Mexorcist Interior Parts (Incl. Lighting) 0 12-24-2016 11:39 AM
PA:Back to stock shultz2 Brakes, Suspension, Chassis 35 06-20-2015 09:03 PM
