#15 |
Drives: 2013 BRZ Limited manual
I am in the finishing steps of my BRZ build. My car is a IAG stage 3 closed deck block. It made 400+whp on 93 and 500whp on e85. my transmission went shortly after the engine was built. It actually went out on the dyno. You will absolutely need a different transmission to be able to hold that power level longterm.
IAG built stage 3 block, HKS camshafts, built and tuned by national speed. 1050 ID injector, garret GTX3071 93 octane 415whp, E85 524whp monster! Quaife QBE69G sequential transmission!
| The Following User Says Thank You to bulldog11267mad For This Useful Post: | Irace86.2.0 (03-16-2020) |
#16 | |
Drives: Q5 + BRZ + M796
#17 | |
#18 | |
Drives: 13' Brz
| The Following User Says Thank You to Try Again For This Useful Post: | Irace86.2.0 (03-17-2020) |
#19 | |
https://www.ft86club.com/forums/show...2&postcount=25
#20 | |
Drives: 13' Brz
#21 |
pessimistic skeptic
Corvette is a great car, just saying ...
| The Following 4 Users Say Thank You to mrg666 For This Useful Post: |
#22 | |
Drives: 2014 BRZ Limited, Satin White Pearl
Running about 17-18psi before storing over winter. Working on getting the cd009 swap in currently. Any higher on boost(19-20psi) and my tires just spun recklessly. So i turned it back down to about 17-18psi. Still a work in progress , so no dyno time yet. Have some m&h drag radials for when i want to turn it up and run at the strip or street drag nights. With the drag radials and the cd009, I'm planning on around 28psi. Didn't notice a difference really between stock engine with same turbo set up, vs built 9:1 cr engine. Same lag, same off boost power.
'14 SWP BRZ 6MT | FBM built 9:1cr engine w/ GTX3076R Turbo | Mazworx CD009 trans swap | EcuTek | Jackson Racing Dual Oil Cooler/Radiator | SPAL fans | JDL 3" Dual Resonated OP/FP | Perrin 3" | Radium Dual Cans | 18" Rota Titans | M85 3.73 diff | DSS 1k axles | And more....too much more....ugh.
| The Following User Says Thank You to Tonrogs For This Useful Post: | Irace86.2.0 (03-17-2020) |
#23 |
I am running 10.5:1 compression closed deck. I also have built heads so the psi would be different on non built heads. im at 22psi at the moment. I did not reach the limit of what it could do on e85 but im close to the limit of what my turbo is able to flow. on 93 octane im sure their is room left but we wanted to keep it relatively safe for the engine.
| The Following User Says Thank You to bulldog11267mad For This Useful Post: | Irace86.2.0 (03-17-2020) |
#24 | |
#25 |
Will be doing boost by gear, just not there quite yet. Winter hit least year and the car got put away. More tuning to come once I get the trans swapped...starting that this weekend.
#26 |
Software Hobbiest
Drives: 2015 FRS
Agreed i wouldn't go too low on CP ratio but like 10.5 or 11 would be way better. I'm running 12.5:1 forged internals and the max boost limit of the turbo before knock is approximately 8-10psi.
Im not sure why but more boost = more power even though the overall cp is the same. My guess is that its less of a fighting force as the piston comes up so less power is waited on the compression stroke. More power in boost less power out of boost. |
#27 | |
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#28 | |
Software Hobbiest
Drives: 2015 FRS
Are you running E85 only or 91 also. The reason im stuck at 8-10 is because i enjoy my flex fuel and dont want a dedicated e85 car. If you are chasing those numbers over dailyability then e85 can yield higher boosts |
| Tags |
| 500 whp, 550 whp |
| Who makes a good AOS for our cars? | D K | Engine, Exhaust, Transmission | 17 | 05-28-2014 03:24 PM |
| GReddy Scion FR-S Makes First USA Public Appearance at Cars & Coffee in Irvine, CA | Moto-P | Scion FR-S / Toyota 86 GT86 General Forum | 172 | 01-16-2014 01:28 AM |
| How do I use A2DP conveniently and reliably? | qoncept | Electronics | Audio | NAV | Infotainment | 6 | 06-04-2013 12:35 PM |
| Got a ride in a 550hp C5 Vette...meh. | Superhatch | Other Vehicles & General Automotive Discussions | 8 | 11-06-2012 02:32 AM |
| Aftermarket hood supports | fasteddy | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 14 | 10-13-2012 11:01 PM |
