Old 07-22-2012, 02:36 AM   #15
Rurounimidnight
Rurounimidnight's Avatar
Drives: Past S13 S14 350Z, Future FRS
Its funny when people think spacers are unsafe to drive on.
Rurounimidnight is offline   Reply With Quote
The Following 4 Users Say Thank You to Rurounimidnight For This Useful Post:
636 (08-26-2013), F3dzo (07-22-2012), FRS8SIX (08-11-2012), GenkiElite (07-22-2012)
Old 07-22-2012, 03:51 AM   #16
F3dzo
F3dzo's Avatar
Drives: 13 fr-s whiteout
The unknown has been the cause of fear for many throughout humanity... Whats it called nowadays?
I'll be back!!
F3dzo is offline   Reply With Quote
Old 07-22-2012, 04:14 AM   #17
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
Originally Posted by F3dzo View Post
Yea I meant to torque them! I'll do it this weekend. 17x7.5 et48
wow, are you mad? I'd torque anything having to do with wheels right away.
anyway, I ask because there is always tons of FUD going around when it comes to spacers
dori. is offline   Reply With Quote
Old 07-22-2012, 04:17 AM   #18
F3dzo
F3dzo's Avatar
Fud? What's that?
Yea i should have torqued...
I'll be back!!
Old 07-23-2012, 06:01 PM   #19
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Well I've seen them fail, more than once. If they are torqued properly there is little risk, but you are adding an extra part to fail on a heavily stressed area. Would I run them on the street? Yup (and have)! Would I run them on the track? HELL NO!
Old 07-23-2012, 11:46 PM   #20
Entropy
Oversteer > Understeer
Entropy's Avatar
Drives: GT86
I would trust a "slip-on" spacer with longer studs over a "bolt-on" spacer. The amount of material that the lugs (the ones bolting the spacer to the hub) are gripping on to is really thin, not to mention it's aluminum.
Entropy is offline   Reply With Quote
Old 07-24-2012, 01:24 AM   #21
Mo707
Mo707's Avatar
Originally Posted by CBR600RR View Post
When you put the coil overs on don't park over the curb like that.
I hate it when I see people doing that in their nice cars and the front lip is meet millimeters above the curb.
I always park far from the curb. ALWAYS made it a habit when I was driving my first car.
Mo707 is offline   Reply With Quote
Old 07-24-2012, 11:32 AM   #22
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
You open up to centering issues, clamping force issues, risk of low quality (not held to OE tolerances on surface smoothness/flatness), stress changes to hub area, not enough threads to secure wheel, failing wheel bearings...
But who cares, hellaflush is important yo!
Properly torqued they are not going to kill you, but the OP said himself he hasn't even used a torque wrench.
As long as the wheel, hub, and spacer are stiff enough to prevent flexing and loss of clamp force, the cause of most wheel stud failures is under tightened lug nuts (not enough clamping force) or over tightened lug nuts (the stud has been stretched past it's elastic limit, so the clamping force goes away).
(3-10mm is still meh but whatever - you can't defend 25+mm spacers, plus he'll probably be tempted to put another spacer on the spacer!)
:happy0180:
Khyron686 is offline   Reply With Quote
The Following 3 Users Say Thank You to Khyron686 For This Useful Post:
F3dzo (07-25-2012), illmatic (08-10-2012), SkullWorks (08-10-2012)
Old 07-24-2012, 03:32 PM   #23
Nepenthe
Drives: 2013 Argento Silver Automatic FR-S
Originally Posted by Khyron686 View Post
(...plus he'll probably be tempted to put another spacer on the spacer!)
This seems ideal to me. The more spacers you add, the more lug nuts are in play to spread out the load. Five hardly seems sufficient per wheel. Three, four spacers per wheel and you're spreading the force across twenty or twenty-five lug nuts per wheel, so each one is under only a small amount of stress. Like lying down on a bed of densely-packed nails versus only a few nails. Plus you can then have those wheels as wide as you want for the flattest cornering stance.
Nepenthe is offline   Reply With Quote
The Following User Says Thank You to Nepenthe For This Useful Post:
F3dzo (07-25-2012)
Old 07-24-2012, 03:41 PM   #24
ayau
Drives: Some rust bucket
The Following User Says Thank You to ayau For This Useful Post:
F3dzo (07-25-2012)
Old 08-09-2012, 08:12 PM   #25
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
What's the proper torquing on our wheels? I think the manual says 89 ft lbs, but I'd like confirmation on that.
Phaedrus29 is offline   Reply With Quote
Old 08-09-2012, 09:18 PM   #26
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Originally Posted by Jeff Lange View Post
Pretty much every other Toyota model (save for M14 models like Tundra, Sequoia and Land Cruiser), use 76ft-lbs, but the FR-S uses Subaru studs with a finer thread pitch. 89ft-lbs is correct, as was mentioned.
Jeff
You're good to go! Sorry for missing your text earlier
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
The Following User Says Thank You to Laika For This Useful Post:
Phaedrus29 (08-09-2012)
Old 08-10-2012, 12:10 AM   #27
Asterisked Accolade
Pedals over Paddles.
Asterisked Accolade's Avatar
Drives: Celica GT-S | 89 Supra | 07' Accent
I work at Discount Tire and we're not even allowed to work on the car if it has spacers. It's deemed unsafe.
2002 Celica GT-S Track Car | 1989 Supra Track Car | 2007 Hyundai Accent AutoX | 2003 Cadillac CTS Daily
Asterisked Accolade is offline   Reply With Quote
The Following User Says Thank You to Asterisked Accolade For This Useful Post:
Entropy (08-10-2012)
Old 08-10-2012, 01:04 PM   #28
dori.
Señor Member
dori.'s Avatar
Fud? What's that?
FUD = Fear, Uncertainty and Doubt
ie people possibly spreading mis-information about the subject.
The problem is that nobody can come of a consesus about if (or what kind of) spacers are safe to run.
Shot these on my driveway last night Hanzo BRZ Photos, Videos, Wallpapers, Gallery Forum 108 04-02-2013 09:09 AM
wheel spacer to 5x114 derka-derka AUSTRALIA 12 07-02-2012 11:27 PM
mines13's living in the 90's boosted street DA build. My soon to be FRS driveway pal mines13 Other Vehicles & General Automotive Discussions 16 03-30-2012 03:30 PM
